Topic: IR receiver code's (Read 838 times) previous topic - next topic
Mubanga
I'm just starting out with arduino and I'm messing around with an IR receiver, a remote control, and two LED lights. I'm trying to get one of the lights to go on for a second when I press the "1" (IR HEX code=FD08F7) button and the other one when I press the "2" button (IR HEX code=FD8877). I'm using a library called IRremote.h that I found here:
http://www.pjrc.com/teensy/td_libs_IRremote.html
So far only one of the lights works when press ANY button on the remote (so not only the "1" button, as it supposed to do)
Here's my code
Code: [Select]
#include <IRremote.h>
const int RECV_PIN = 3;
int led1 = 8;
int led2 = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    if (results.value = 0xFD08F7) {
      digitalWrite(led1, HIGH);
      digitalWrite(led1, LOW);
    else if (results.value = 0xFD8877) {
      digitalWrite(led2, HIGH);
      digitalWrite(led2, LOW);
        irrecv.resume();
If somebody could take a look at it and help me, I would really appreciate it
PaulS
Code: [Select]
This is an assignment statement (=), not an equality test (==).
Mubanga
That did the trick thanks a lot!
