Loading...
Pages: [1]   Go Down
Author Topic: MSGEQ7 function without delay statments  (Read 202 times)
Yorkshire England
Offline Offline
Sr. Member
Arduino good init
View Profile
After reading the post on BPM this morning i decided to post a function for the MSGEQ7. The example that most people first try has lots of Delay statements in it, this is ok for the demo but you will probably not want them there when you integrate it into your existing project.
I don't know if this is the best way to do it but i think it's probably easy to understand for beginners like me.
Basically you just keep calling EQScan after 14 call's it will have filled spectrumValue[] with the data. Instead of using Delay you are doing the other stuff in your program instead to cause the delay
Code:
  EQ with no delay
  evp
byte spectrumValue[7];
  pinMode(A3, INPUT); //analogPin
  pinMode(A2, OUTPUT); //strobePin
  pinMode(A1, OUTPUT); //resetPin
  analogReference(DEFAULT);
  digitalWrite(A1, LOW); //  reset
  digitalWrite(A2, HIGH);//
  // what ever you want to do, i think it would be best to do somr thing or put in a delay
  EQScan();
void EQScan(void){
  static boolean ReadStrobe=0;
  static byte Count=0;
  if(Count>6){
    Count=0;
    digitalWrite(A1, HIGH); // reset
  if(ReadStrobe==0){   /// if ReadStrobe==0 then set the strobe and return else read analog input
    digitalWrite(A2, LOW);
    ReadStrobe=1;
  else{
    spectrumValue[Count] = analogRead(A3); ///
    ReadStrobe=0;
  Count+=1;
  return;
« Last Edit: January 14, 2013, 07:34:21 am by EVP » Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
The delays matter because the MSGEQ7 decays the stored values a certain amount each time you strobe through. If your other code takes varying times to run, then your results from the MSGEQ7 will not be consistent.
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
Yorkshire England
Offline Offline
Sr. Member
Arduino good init
View Profile
True. I think the time it takes to run is quite consistent for what i used it for so it seemed to work well enogh. But i didnt think about how inconsistent delay times would affect it.
Logged
Pages: [1]   Go Up
Print
Jump to:
