Loading...
Pages: [1]   Go Down
Author Topic: Web control problem - code  (Read 425 times)
Slovakia
Offline Offline
Newbie
View Profile
Hi Guys,
I made a code for controlling two relays (Vent, Heater) based on codes i found here on Forum.
I´d like to add more relays (Gate opener-works with push button, once pushed gate opens, second time pushed gate closes), but when I added code I can´t even open control page in web browser. What am I doing wrong?
Original (working) code:
Code:
void loop(){
//indexOf("L=")
        if (c == '\n') { //if HTTP request has ended
          Serial.println("");
          Serial.println(readString); // print for debugging
          Serial.println("");
          int Le = readString.indexOf("L="); //here is a key component of where
          int He = readString.indexOf("H="); //the status is being read by the arduino
          Serial.print("L= position: ");
          Serial.println(Le);
          Serial.print("H= position: ");
          Serial.println(He);
          //lets check if Vent should be lighted
          if (Le > 1){
          if (readString.substring(Le,(Le+3)) == "L=1") { //vent has to be turned ON
              digitalWrite(ventPin, LOW); // set the LED on
              Serial.println("ventpin paa");
              VENTON = true;
          if (readString.substring(Le,(Le+3))== "L=0") {
            //Vent has to be turned OFF
            digitalWrite(ventPin, HIGH); // set the Vent OFF
            Serial.println("ventpin av");
            VENTON = false;
           if (He > 1){
          if (readString.substring(He,(He+3)) == "H=1") { //heat has to be turned ON
              digitalWrite(heatpin, LOW); // set the heat on
              Serial.println("heatpin paa");
              HEATON = true;
          if (readString.substring(He,(He+3)) == "H=0") {
            //heat has to be turned OFF
            digitalWrite(heatpin, HIGH); // set the heat OFF
            Serial.println("heatpin av");
            HEATON = false;
  client.println("HTTP/1.1 200 OK"); //output HTML data starting with standart header
  client.println("Content-Type: text/html");
  client.println();
  client.print  ("<body style=background-color:white>"); //set background to white
  // HTML Code
  client.println("<font color=’red’><h1>Arduino 328 control</font></h1>");//send first heading
  client.println("<hr />");
  client.println("<font color=’blue’ size=’5′>Analog input: "); //output some sample data to browser
  sensorValue = analogRead(sensorPin);
  client.print(sensorValue);//Analog input.
  Serial.print(sensorValue);
  client.println("<br />");//some space between lines
  //controlling led via checkbox
  client.println("<h1>Schwitch control</h1>");
  // address will look like http://192.168.xxx.xxx/?L=1 when submited
  // this line will give the radiobuttons that give the input
  client.println("<form method=get name=VENT> <input type='radio' name='L' value='1'>VENT ON<br><input type='radio' name='L' value='0'>VENT OFF<br><input type='radio' name='H' value='1'>HEAT ON<br><input type='radio' name='H' value='0'>HEAT OFF<br><input type=submit value=submit></form>");
  //printing VENT status
  client.print("<font size=’5′>VENT status: ");
  if (VENTON == true) {
     client.println("<font color=’green’ size=’5′>ON");
     Serial.print("Vent on");
   else {
    client.println("<font color=’grey’ size=’5′>OFF");
    Serial.println("Vent off");
New code:
Code:
void loop(){
        Serial.print(c);         //output chars to serial port for debugging
         //indexOf("L=")
          Serial.println("");
          Serial.println("");
 int Do = readString.indexOf("D=");
          Serial.println(Le);
          Serial.println(He);
          Serial.print("D= position: ");
          Serial.println(Do);
//////////////////////////////////////////////////////////////////////////////////////String for VENT
          //if Vent should be turned ON
          if (Le > 1){
              digitalWrite(ventPin, LOW);                  // set the Relay on
              Serial.println("ventpin on");
              VENTON = true;
          if (readString.substring(Le,(Le+3))== "L=0") {  //Vent has to be turned OFF
            digitalWrite(ventPin, HIGH);                  // set the Relay OFF
            Serial.println("ventpin off");
            VENTON = false;
///////////////////////////////////////////////////////////////////////////////////////String for HEAT
           if (He > 1){
              digitalWrite(heatpin, LOW);                 // set the relay on
              Serial.println("heatpin onn");
              HEATON = true;
          if (readString.substring(He,(He+3)) == "H=0") { //heat has to be turned OFF
            digitalWrite(heatpin, HIGH);                  // set the relay OFF
            Serial.println("heatpin off");
            HEATON = false;
//////////////////////////////////////////////////////////////////////////////////////////String for GATE
           if (Do > 1){
          if (readString.substring(Do,(Do+3)) == "G=1") { //Gate has to be opened
     delay(800);
              DoON = true;
     digitalWrite(dopin, HIGH);
              Serial.println("gate is onening");
              DoON = true;
          if (readString.substring(Do,(Do+3)) == "D=0") { //Gate has to be closed
              digitalWrite(dopin, LOW);                 // set the relay on
     delay(800);
              DoON = true;
              Serial.println("gate is closing");
              DoON = false;
  client.println();
  client.println("<font color=’red’><h1>Arduino control</font></h1>");//send first heading
  client.println("<font color=’blue’ size=’5'>Analog input: "); //output some sample data to browser
  client.println("<form method=get name=VENT> <input type='radio' name='L' value='1'>VENT ON<br><input type='radio' name='L' value='0'>VENT OFF<br><input type='radio' name='H' value='1'>HEAT ON<br><input type='radio' name='H' value='0'>HEAT OFF<br><input type='radio' name='G' value='1'>GATE OPN<br><input type='radio' name='G' value='0'>GATE CLS<br><input type=submit value=submit></form>");
  client.print("<font size=’5'>VENT status: ");
     client.println("<font color=’green’ size=’5'>ON");
   else {
    client.println("<font color=’grey’ size=’5'>OFF");
 //printing HEAT status
  client.print("<font size=’5'>Heatpin status: ");
  if (HEATON == true) {
     Serial.print("Heat on");
   else {
    Serial.println("Heat off");
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Looks like some of your code is missing.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Slovakia
Offline Offline
Newbie
View Profile
Yes I put here just the part from where the problem started - my post had too many characters, here ist whole code:
Code:
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Client.h>
#include <Server.h>
#include <Ethernet.h>
#define ONE_WIRE_BUS 3
#define TEMPERATURE_PRECISION 12
float tempC, tempF;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress Teplotanasavania = { 0x28, 0x44, 0x33, 0x9D, 0x01, 0x00, 0x00, 0xAA };
DeviceAddress Teplotaodtahu = { 0x28, 0x49, 0x45, 0x9D, 0x01, 0x00, 0x00, 0x11 };
 byte    mac[] =     { 0x90, 0xA2, 0xDA, 0x00, 0x8D, 0x42 };   //physical mac address
 byte    ip[] =      { 192, 168, 1, 104 };                     // ip in lan
 byte    gateway[] = { 192, 168, 1, 1 };                       // the IP of the router
 byte    subnet[] =  { 255, 255, 255, 0 };                     //subnet mask
 Server  server(80);                // server port
 int     ventPin = 5;                //Ventilation pin
 int     heatpin = 6;               // Heating pin
 int     gatepin = 7;               // Gate pin
 int     sensorPin = A0;            // analog in 0 for testing
 int     sensorValue = 0;           // integer for the analog sensor
 String  readString = String(30);   // string for fetching data from address
 boolean VENTON = false;             // LED status flag
 boolean HEATON = false;             // Heat status flag
 boolean GATEON = false;             // Gate status flag
  Serial.begin(9600); //enable serial datada print
  Ethernet.begin(mac, ip, gateway, subnet); //start Ethernet
  pinMode(ventPin, OUTPUT); //Set pin 5 to output
  pinMode(heatpin, OUTPUT); //Set pin 6 to output
  pinMode(gatepin, OUTPUT); //Set pin 7 to output
   server.begin();          // Start up the sensors library
  sensors.begin();          // set the resolution
  sensors.setResolution(Teplotanasavania, TEMPERATURE_PRECISION);
  sensors.setResolution(Teplotaodtahu, TEMPERATURE_PRECISION);
  // function to get the temperature for a device
  void getTemperature(DeviceAddress deviceAddress)
  tempC = sensors.getTempC(deviceAddress);
  tempF = DallasTemperature::toFahrenheit(tempC);
  Serial.print("Starting server"); //for debugging
  Serial.println("Analog in:");   //for debugging
  Serial.println("");
  Serial.println (sensorValue);
  Serial.println("");
  Serial.println("");
void loop(){
  sensors.requestTemperatures();
  Client client = server.available();  // Create a client connection
    if (client) {
      while (client.connected()) {
        if (client.available()) {
          char c = client.read();
        if (readString.length() < 30) { //read char by char HTTP request
          readString.concat(c); } //store characters to string
         //indexOf("L=")
          Serial.println("");
          Serial.println("");
 int Ge = readstring.indexof("G=");
          Serial.println(Le);
          Serial.println(He);
          Serial.print("G= position: ");
          Serial.println(Ge);
//String for VENT
          if (Le > 1){
              VENTON = true;
            VENTON = false;
//String for HEAT
           if (He > 1){
              HEATON = true;
            HEATON = false;
///String for GATE
           if (Ge > 1){
          if (readString.substring(Ge,(Ge+3)) == "G=1") { //Gate has to be opened
     delay(800);
              GATEON = true;
     digitalwrite(gatepin, HIGH);
              GATEON = true;
          if (readString.substring(Ge,(Ge+3)) == "G=0") { //Gate has to be closed
     delay(800);
              GATEON = true;
              GATEON = false;
  client.println();
   else {
   else {
 //printing GATE status
  client.print("<font size=’5'>Gatepin status: ");
  if (GATEON == true) {
     client.println("<font color=’green’ size=’5'>OPENED");
     Serial.print("Gate opened");
   else {
    client.println("<font color=’grey’ size=’5'>Closed");
    Serial.println("Gate closed");
getTemperature(Teplotanasavania);
  client.println("HTTP/1.1 200 OK"); // Standard HTTP response
          client.println("Content-Type: text/html\n");
          client.println("<html><head><META HTTP-EQUIV=""refresh""CONTENT=""5"">\n");
          client.println("<title>Arduino Web Server</title></head>");
          client.println("<body>\n");
          client.println("<h1>Rekuperacia 328</h1>");
          client.println("<h3><font color='blue'>Teplota nasavania FRESH AIR IN</h3>");
          client.println("Temp C:");
          client.println(tempC);
          client.println("<br/>");
          client.println("Temp F:");
          client.println(tempF);
          getTemperature(Teplotaodtahu);
          client.println("<h3><font color='red'>Teplota odtahu DIRTY AIR </h3>");
  client.println("</body></html>");
readString=""; //clearing string for next read
client.stop(); //stopping client
Serial.println("stopped client"); // for debugging
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I can't get your code to compile, but you may be running out of memory. You might try the F() macro like below for the static html lines like below to save memory space.
Code:
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println(F("<HTML>"));
          client.println(F("<HEAD>"));
          client.println(F("<TITLE>Arduino GET test page</TITLE>"));
          client.println(F("</HEAD>"));
          client.println(F("<BODY>"));
Logged
Pages: [1]   Go Up
Print
Jump to:
