« on: January 14, 2013, 05:57:12 am » |
I write thing a menu structuur and ther i use a case. But now for changing the menu I use some buttons. I use a LCDEdit and there I change my settings. And with lcdItem I choce the case item. void lcdDisplay(){ if (lcdEdit == 0){ lcdItem = loopConstrain(lcdUpDownControl(lcdItem),0,8); I have now only the problem if I connect the power on the arduino my arduino is starting in to case 8. I think my problem is in this part of the sketch. int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } } is there anyone who can help me how I can solve this? Many thanks. Gr .
« Last Edit: January 14, 2013, 07:03:16 am by bjoang »
« Reply #1 on: January 14, 2013, 06:09:12 am » |
You need to read the sticky thread about how to post a programming question...
« Reply #2 on: January 14, 2013, 07:04:47 am » |
dear Mark,
I have change the post and I hope that now the post is good.
Let me now otherwise i changed a gain.
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: January 14, 2013, 07:12:47 am » |
I have change the post and I hope that now the post is good. It's not. You need to post ALL of your code.
« Reply #4 on: February 07, 2013, 03:39:01 pm » |
After some commentar I have post my code in total. I hope that som bodycan help me now. If I start the arduino than he come in to case 8. I think that the porblem is on: int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } } This is the total code of my menu structure. #include <LiquidCrystal_I2C.h> #include <Wire.h> #include <SPI.h> const int cs=8; LiquidCrystal_I2C lcd(0x27,16,2);
const int buttonPinUp = 2; const int buttonPinDown = 3; const int buttonPinEsc = A0; const int buttonPinEnter = 9; const int Sensormicro = A2;
boolean LastValUp = true; boolean LastValDown = true; boolean LastValEsc = true; boolean LastValEnter = true; boolean autoEnabled = true;
int lcdItem = 0; int lcdEdit = 0;
boolean timeEnabled[] = {false,false,false}; int timeHours[] = {0,0,0}; int timeMinutes[] = {0,0,0};
int Weight = 0; byte Value_E1 = 150; byte Value_E2 = 100; int C_Day=25; int C_Month=6; int C_Year=12; int C_Hour=14; int C_Min=49; int C_second=55;
byte lcdCharUpDown[8] = { 0b00100, 0b01110, 0b11111, 0b00000, 0b00000, 0b11111, 0b01110, 0b00100 };
void setup(){ lcd.init(); lcd.backlight(); pinMode(buttonPinUp, INPUT); pinMode(buttonPinDown, INPUT); pinMode(buttonPinEnter, INPUT); pinMode(buttonPinEsc, INPUT); }
void loop(){
if (lcdEdit == 0){ lcdItem = loopConstrain(lcdUpDownControl(lcdItem),0,8); } lcdButtonControl(); lcdMenu(); lcdEditValues(); }
void lcdButtonControl(){ boolean ValEnter=digitalRead(buttonPinEnter);
if (ValEnter !=LastValEnter){ if (ValEnter==LOW){ Serial.print("ENTER"); lcd.clear(); lcdEdit ++; } } LastValEnter=ValEnter; boolean ValEsc=digitalRead(buttonPinEsc);
if (ValEsc !=LastValEsc){ if (ValEsc==LOW){ lcd.clear(); lcdItem = 0; } }
LastValEsc=ValEsc; }
boolean lcdUpDownControl(int oldValue){ boolean ValUp=digitalRead(buttonPinUp);
if (ValUp !=LastValUp){ if (ValUp==LOW){ Serial.println("plus"); LastValUp=ValUp; lcd.clear(); return oldValue + 1; } }
LastValUp=ValUp;
boolean ValDown=digitalRead(buttonPinDown); if (ValDown !=LastValDown){ if (ValDown==LOW){ LastValDown=ValDown; lcd.clear(); return oldValue - 1; } } LastValDown=ValDown; return oldValue; } void lcdMenu(){ switch (lcdItem){ case 0:
lcd.setCursor(0,0); if (autoEnabled){ lcd.print("A "); } else{ lcd.print("M "); } lcd.print("1:12:15"); lcd.setCursor(0,1); lcd.print("Temp "); lcd.print("25"); lcd.print(" C "); delay(10); break; case 1:
lcd.setCursor (0,0); lcd.print ("Time"); break; case 2:
lcd.setCursor (0,0); lcd.print ("Time"); break; case 3:
lcd.setCursor (0,0); lcd.print ("Time"); break; case 4:
lcd.setCursor (0,0); lcd.print ("Weight"); break; case 5:
lcd.setCursor (0,0); lcd.print ("Speed"); break; case 6:
lcd.setCursor (0,0); lcd.print ("Set time"); break; case 7:
lcd.setCursor (0,0); lcd.print ("Set date"); break; case 8:
lcd.setCursor (0,0); lcd.print ("Sample run"); break; } } void lcdEditValues(){ byte timeId = 0; lcd.setCursor (0,1); switch(lcdItem){ case 0: lcdEdit = 0; break; case 1: case 2: case 3: timeId = lcdItem-1; if (timeEnabled[timeId]){ lcd.print("on"); } else{ lcd.print("off"); } if (lcdEdit == 1){ lcd.print('\x00'); timeEnabled[timeId] = loopConstrain(lcdUpDownControl(timeEnabled[timeId]), 0, 1); } else{ lcd.print(" "); } lcd.print(timeHours[timeId]); if (lcdEdit == 2){ lcd.print('\x00'); timeHours[timeId] = loopConstrain(lcdUpDownControl(timeHours[timeId]),0,23);//constrain(, 0, 23); } else{ lcd.print(" "); } lcd.print(":"); lcd.print(timeMinutes[timeId]); if (lcdEdit == 3){ lcd.print('\x00'); timeMinutes[timeId] = loopConstrain(lcdUpDownControl(timeMinutes[timeId]), 0, 59); } else{ lcd.print(" "); } if (lcdEdit == 4){ lcdEdit = 0; } break; case 4: lcd.print(Weight); if (lcdEdit == 1){ lcd.print('\x00'); Weight = loopConstrain(lcdUpDownControl(Weight), 0, 1000); } if (lcdEdit == 2){ lcdEdit = 0; } break; case 5: lcd.print(Value_E2); if (lcdEdit == 1){ lcd.print('\x00'); Value_E2 = loopConstrain(lcdUpDownControl(Value_E2), 0, 255); } if (lcdEdit == 2){ lcdEdit = 0; } break; case 6: lcd.print(C_Hour); if (lcdEdit == 1){ lcd.print('\x00'); C_Hour = loopConstrain(lcdUpDownControl(C_Hour), 0, 23); } else{ lcd.print(" "); } lcd.print(":"); lcd.print(C_Min); if (lcdEdit == 2){ lcd.print('\x00'); C_Min = loopConstrain(lcdUpDownControl(C_Min), 0, 59); } if (lcdEdit == 3){ SetTimeDate(C_Day,C_Month,C_Year,C_Hour,C_Min,C_second); lcdEdit = 0; } break; case 7: lcd.print(C_Day); if (lcdEdit == 1){ lcd.print('\x00'); C_Day= loopConstrain(lcdUpDownControl(C_Day), 1, 31); } else{ lcd.print(" "); } lcd.print("/"); lcd.print(C_Month); if (lcdEdit == 2){ lcd.print('\x00'); C_Month = loopConstrain(lcdUpDownControl(C_Month), 1, 12); } else{ lcd.print(" "); } lcd.print("/"); lcd.print(C_Year); if (lcdEdit == 3){ lcd.print('\x00'); C_Year = loopConstrain(lcdUpDownControl(C_Year), 0, 99); } if (lcdEdit == 4){ SetTimeDate(C_Day,C_Month,C_Year,C_Hour,C_Min,C_second); lcdEdit = 0; } break; case 8: lcd.print("Press enter to run"); if (lcdEdit == 1){ lcdEdit = 0; } break; } }
int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } } int RTC_init(){ pinMode(cs,OUTPUT); SPI.begin(); SPI.setBitOrder(MSBFIRST); SPI.setDataMode(SPI_MODE3); digitalWrite(cs, LOW); SPI.transfer(0x8E); SPI.transfer(0x60); digitalWrite(cs, HIGH); delay(10); } //===================================== int SetTimeDate(int d, int mo, int y, int h, int mi, int s){ int TimeDate [7]={s,mi,h,0,d,mo,y}; for(int i=0; i<=6;i++){ if(i==3) i++; int b= TimeDate[i]/10; int a= TimeDate[i]-b*10; if(i==2){ if (b==2) b=B00000010; else if (b==1) b=B00000001; } TimeDate[i]= a+(b<<4); digitalWrite(cs, LOW); SPI.transfer(i+0x80); SPI.transfer(TimeDate[i]); digitalWrite(cs, HIGH); } } //===================================== String ReadTimeDate(){ String temp; int TimeDate [7]; for(int i=0; i<=6;i++){ if(i==3) i++; digitalWrite(cs, LOW); SPI.transfer(i+0x00); unsigned int n = SPI.transfer(0x00); digitalWrite(cs, HIGH); int a=n & B00001111; if(i==2){ int b=(n & B00110000)>>4; if(b==B00000010) b=20; else if(b==B00000001) b=10; TimeDate[i]=a+b; } else if(i==4){ int b=(n & B00110000)>>4; TimeDate[i]=a+b*10; } else if(i==5){ int b=(n & B00010000)>>4; TimeDate[i]=a+b*10; } else if(i==6){ int b=(n & B11110000)>>4; TimeDate[i]=a+b*10; } else{ int b=(n & B01110000)>>4; TimeDate[i]=a+b*10; } } temp.concat(TimeDate[4]); temp.concat("/") ; temp.concat(TimeDate[5]); temp.concat("/") ; temp.concat(TimeDate[6]); temp.concat(" ") ; temp.concat(TimeDate[2]); temp.concat(":") ; temp.concat(TimeDate[1]); return(temp); }
East Anglia (UK)
May all of your blinks be without delay
« Reply #5 on: February 07, 2013, 03:56:22 pm » |
Try putting some Serial.prints at the start of loopConstrain() so that you know what the values of x, a and b are.
Are they what you expect ?
« Reply #6 on: February 07, 2013, 04:30:48 pm » |
Dear UKHelibob Thanks for your comment. I have put the Serial.prints after the code int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } It give me code in the serial monitor from plus 108ENTER808108108108108108108108108108108108 And than the 108 is comming back again and again. I am not sure how it possible that the progam is doing this every time again.
East Anglia (UK)
« Reply #7 on: February 07, 2013, 05:43:31 pm » |
I know that I said Serial.print but Serial.println would make the output easier to read.
Do you get that output even before you press any buttons ?
One thing that does look wrong is the lcdUpDownControl() function. It is declared as returning a boolean, takes an int as an argument, adds or subtracts one to/from the int if a button is pressed and returns the int. Zero is false and any other value is true so most of the time the function will return true. Is that what you want to happen ?
Seattle, WA USA
Seattle, WA USA
« Reply #8 on: February 07, 2013, 05:50:51 pm » |
I know that I said Serial.print but Serial.println would make the output easier to read. Even better would be something like: Serial.print("x="); Serial.println(x); so you can see what a raw number corresponds to.
« Reply #9 on: February 10, 2013, 04:23:34 pm » |
I have do it with the code from PaulS and now it give following code back.
plus x=1 a=0 b=8 ENTERx=8 a=0 b=8 x=3
And than a=0,b=8 and x=3 repeat again and again.
Do enybody is nowing how this is possible?
Many thanks.
Seattle, WA USA
Seattle, WA USA
« Reply #10 on: February 10, 2013, 06:15:49 pm » |
Do enybody is nowing how this is possible? Paging any psychics on the forum. Without seeing any code, do you know what is wrong? Hmmm, no answers. Can you guess what you need to do?
« Reply #11 on: February 12, 2013, 02:43:09 pm » |
Sorry PaulS I thought you understood what I meant and what code I have used. Here's the code I've used #include <LiquidCrystal_I2C.h> #include <Wire.h> #include <SPI.h> const int cs=8; LiquidCrystal_I2C lcd(0x27,16,2);
void setup(){ lcd.init(); lcd.backlight(); pinMode(buttonPinUp, INPUT); pinMode(buttonPinDown, INPUT); pinMode(buttonPinEnter, INPUT); pinMode(buttonPinEsc, INPUT); Serial.begin(9600); }
void loop(){
LastValUp=ValUp;
int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); } int RTC_init(){ pinMode(cs,OUTPUT); SPI.begin(); SPI.setBitOrder(MSBFIRST); SPI.setDataMode(SPI_MODE3); digitalWrite(cs, LOW); SPI.transfer(0x8E); SPI.transfer(0x60); digitalWrite(cs, HIGH); delay(10); } //===================================== int SetTimeDate(int d, int mo, int y, int h, int mi, int s){ int TimeDate [7]={s,mi,h,0,d,mo,y}; for(int i=0; i<=6;i++){ if(i==3) i++; int b= TimeDate[i]/10; int a= TimeDate[i]-b*10; if(i==2){ if (b==2) b=B00000010; else if (b==1) b=B00000001; } TimeDate[i]= a+(b<<4); digitalWrite(cs, LOW); SPI.transfer(i+0x80); SPI.transfer(TimeDate[i]); digitalWrite(cs, HIGH); } } //===================================== String ReadTimeDate(){ String temp; int TimeDate [7]; for(int i=0; i<=6;i++){ if(i==3) i++; digitalWrite(cs, LOW); SPI.transfer(i+0x00); unsigned int n = SPI.transfer(0x00); digitalWrite(cs, HIGH); int a=n & B00001111; if(i==2){ int b=(n & B00110000)>>4; if(b==B00000010) b=20; else if(b==B00000001) b=10; TimeDate[i]=a+b; } else if(i==4){ int b=(n & B00110000)>>4; TimeDate[i]=a+b*10; } else if(i==5){ int b=(n & B00010000)>>4; TimeDate[i]=a+b*10; } else if(i==6){ int b=(n & B11110000)>>4; TimeDate[i]=a+b*10; } else{ int b=(n & B01110000)>>4; TimeDate[i]=a+b*10; } } temp.concat(TimeDate[4]); temp.concat("/") ; temp.concat(TimeDate[5]); temp.concat("/") ; temp.concat(TimeDate[6]); temp.concat(" ") ; temp.concat(TimeDate[2]); temp.concat(":") ; temp.concat(TimeDate[1]); return(temp); }
Seattle, WA USA
Seattle, WA USA
« Reply #12 on: February 12, 2013, 02:54:41 pm » |
Serial.print("ENTER"); This should be println(), to add a carriage return/line feed. int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); } Most compilers would output a warning that says that not all paths return a value. If there no constraining taking place, there is nothing returned from this function. If there is constraining, nothing is printed. You should endeavor to write functions that have exactly one return statement, and that should be the last statement in the function, like this: int loopConstrain(int x,int a,int b) { int constrainedValue = x; if (x == a-1 || x ==255) { constrainedValue = b; } else if (x == b+1) { constrainedValue = a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); Serial.print("constrainedValue="); Serial.println(constrainedValue); return constrainedValue; } The lack of the return statement in most instances of the call to your function meant that garbage was popped off the stack as the return value.
« Last Edit: February 12, 2013, 02:56:14 pm by PaulS »
« Reply #13 on: February 12, 2013, 03:29:29 pm » |
Thank you Pauls for your quick respons. I have take the code from you in the sketch int loopConstrain(int x,int a,int b) { int constrainedValue = x; if (x == a-1 || x ==255) { constrainedValue = b; } else if (x == b+1) { constrainedValue = a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); Serial.print("constrainedValue="); Serial.println(constrainedValue); return constrainedValue; } I'm not sure what happened in this piece of code If starting now the arduino noting is on the display. If I push first the escape button than the diplay is comming with case 0 the main page. I whant that the arduino is directy starting with case 0. If I looking in to the serial monitor than I see uplus x=1 a=0 b=8 constrainedValue=1 ENTERx=255 a=0 b=8 constrainedValue=8 x=8 a=0 b=8 After this than from constainedValue=8,x=8,a=0 and b=8 it is comming again and again. Sorry that I don't put the hole code here there is a limit from 9500 characters. I have change the code int loopConstrain(int x,int a,int b){ if (x == a-1 || x ==255){ return b; } if (x == b+1){ return a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); } For the code int loopConstrain(int x,int a,int b) { int constrainedValue = x; if (x == a-1 || x ==255) { constrainedValue = b; } else if (x == b+1) { constrainedValue = a; } Serial.print("x="); Serial.println(x); Serial.print("a="); Serial.println(a); Serial.print("b="); Serial.println(b); Serial.print("constrainedValue="); Serial.println(constrainedValue); return constrainedValue; }
« Last Edit: February 12, 2013, 03:45:12 pm by bjoang »
