Loading...
Pages: [1]   Go Down
Author Topic: IR receiver code's  (Read 128 times)
Gouda, The Netherlands
Offline Offline
Newbie
View Profile
I'm just starting out with arduino and I'm messing around with an IR receiver, a remote control, and two LED lights. I'm trying to get one of the lights to go on for a second when I press the "1" (IR HEX code=FD08F7) button and the other one when I press the "2" button (IR HEX code=FD8877). I'm using a library called IRremote.h that I found here:
http://www.pjrc.com/teensy/td_libs_IRremote.html
So far only one of the lights works when press ANY button on the remote (so not only the "1" button, as it supposed to do)
Here's my code
Code:
#include <IRremote.h>
const int RECV_PIN = 3;
int led1 = 8;
int led2 = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    if (results.value = 0xFD08F7) {
      digitalWrite(led1, HIGH);
      digitalWrite(led1, LOW);
    else if (results.value = 0xFD8877) {
      digitalWrite(led2, HIGH);
      digitalWrite(led2, LOW);
        irrecv.resume();
If somebody could take a look at it and help me, I would really appreciate it
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
This is an assignment statement (=), not an equality test (==).
Logged
Offline Offline
Newbie
View Profile
That did the trick thanks a lot!
Logged
Pages: [1]   Go Up
Print
Jump to:
