Topic: Arduino using GSM Siemens TC35i (Read 22451 times) previous topic - next topic
dan007
I have stumbled across various solutions for the interface and sketch code for an Arduino using Siemens TC35i, but I can't seem to find anything that works.
I am wondering if anyone has a basic sketch out there that can send an SMS text message from the Arduino using what I believe is AT commands.
Also seperate to this I can't make out why a supply of 2A is required, I connected a 300mA supply @ 8v and when powered up, I can ring the number on the sim card inserted to the Siemens TC35i and get a ringing noise on my mobile phone. So surely the power supply can handle sending a SMS text message.
Regards
Dan
dan007
#1
Jan 14, 2013, 08:41 pm Last Edit: Jan 15, 2013, 01:43 pm by dan007 Reason: 1
Code: [Select]
Current code:
#include <SoftwareSerial.h>
char gsm_char=0;      //Stores character from the gsmSerial
SoftwareSerial gsmSerial(0,1);  //Creates a software serial port. (rx,tx)
 //Initialize serial ports for communication.
 gsmSerial.begin(9600);
 Serial.println("Starting TC35 and debug Communication...");
 //If a character comes in from the cellular module...
 if(gsmSerial.available() > 0){
   gsm_char=gsmSerial.read();    //Store the char in gsm_char.
   Serial.print(gsm_char);  //Print it to debug serial
 //Read serial input
 if(Serial.available() > 0){
   gsm_char=Serial.read();  //Store char in gsm_char (Not really from the gsm, just saving some memory)
   delay(2000);
   //Evaluate input.
   if(gsm_char=='t'){
     gsmSerial.print("AT\r");  //Send test connection response should be OK
   } else if(gsm_char=='g'){
     gsmSerial.print("AT+CMGF=1\r"); //Set text mode.
   } else if(gsm_char=='s'){
     //Send sms!
     gsmSerial.print("AT+CMGS=+44XXXXXXXXXX"); //AT command to send SMS
     delay(100);
     gsmSerial.print("Hello World"); //Print the message
     delay(10);
     gsmSerial.print("\x1A"); //Send it ascii SUB
daveb27
Hi Dan,
Im working on a similar project, trying to get an Arduino to send an sms via TC35 and not having a lot of joy. Did you get anywhere with it?
Cheers,
Dave
romani
Hi Dan,
If you are sure the gsm module is working and you don't get any response try sending AT commands with println() instead of print(). The modem expect's CR and LF characters at the end of each AT command;
romani
KazDuzar
I had quite some problems with a TC35 board (note not the TC35i) in combination with the AT+CMGF=1\r command.
It turned out that depending on the delay ofter this command, an SMS was send (or not). The worst thing was that the required amount of delay was depending on the length of the SMS message.
The following example worked for me, when i did not change the SMS message too much: http://arjanvdbeek.nimio.info/electronics/sms-using-a-uc/siemens-tc35-gsm-board/
hugo007
#5
Feb 25, 2013, 12:01 am Last Edit: Feb 25, 2013, 12:16 am by HugoPT Reason: 1
Hello folks
I'm using this modem a while ago.I had made a small .h file with some functions to deal with it.
In future I will create a library but for now I'm out of time.
If you want to use it all you have to do is include this file  and then call the functions in the main program.
The file is away of be perfect, like I said it not finished and should contain some bugs
To use the functions here is an example for those don't understand how to use it:
Code: [Select]
 //setupModem();
 initModem();
 clear_SMS_Modem_Memory();
 clearSerialBuffer();
 dialNumber("9600000000");
 sendSMS("960000000","Modem Started");
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
dan007
Wowzers Hugo :-) Just D/L the header file and had a brief read of it. It looks very impressive and seems to cover most of the basic functions you would like to use a TC35i (using AT command set).
Correct me if I am wrong, but you can read a sms message with this and it extracts the data into an array? This is exactly the purpose I got my TC35i modem for, since when it recieves a message saying "heating on", I want my Arduino Uno to in turn bring in a relay which will drive my heating.
I'll have further look into the .h file, but it all looks very good so far, and neatly presented.
Regards
Dan
hugo007
Quote
Yes it can handle sms
Code: [Select]
*senderID = get_SMS_ID_Sender();//The function get_SMS_ID_Sender() will return a pointer that points to a variable containing the number of the sms sender
*messageBody = get_corpo_sms(); //this function return a pointer that points to a variable cointaining  a string
The code is not prepared to use a softserial unfortunately, so you need to use a UART Port.
I will try to implement that later.
Thanks for your feedback
If you have any trouble just ask
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
LJRob
Hi Dan,
Here's a sketch that should work for you.
Code: [Select]
Arduino 1.0.1
This sketch reads TC35 SMS to control items
connected to the Arduino.
The readTC35 and readkeyboard functions are from
Process incoming serial data without blocking by Nick Gammon
http://gammon.com.au/serial
The rest of the sketch is by me
Run this sketch and enter the folowing AT commands
in the Serial Monitor to set user profile
you only need to do this once.
AT+CMGF=1          for txt mode
AT+CNMI=2,1,0,0,1  message indication
AT^SMGO=1          SMS full indication
AT&W               store to memory
To check what you have entered
AT&V               display current configuration
SoftwareSerial gsmSerial(2,3);
//-------- TC35 GSM ---------------
int SMS_location_number;
const unsigned int MAX_INPUT = 165; // 160 characters for SMS plus a few extra
static unsigned int input_pos = 0;
  //--- turn on TC35 ---
  // wire pin 8 Arduino to IGT pin on TC35
  // it grounds IGN pin for 100 ms
  // this is the same as pressing the button
  // on the TC35 to start it up
  pinMode(8, INPUT);
  digitalWrite(8, LOW);
  pinMode(8, OUTPUT);
  delay(100);
  pinMode(8, INPUT);
}//------ End setup -------
  readTC35();
  readKeyboard();
}//------ End loop --------
//---------------------------- Read TC35 ------------------------------------
// Read data from the TC35, When a linefeed is read the data is processed
void readTC35(){
  static char input_line [MAX_INPUT];
  //static unsigned int input_pos = 0;
  if (gsmSerial.available () > 0)
    while (gsmSerial.available () > 0) {
      char inByte = gsmSerial.read ();
      switch (inByte)
      case '\n':   // end of text
        input_line [input_pos] = 0;  // terminating null byte
        // terminator reached! process input_line here ...
        process_data (input_line);
        // reset buffer for next time
        input_pos = 0;
      case '\r':   // discard carriage return
      default:
        // keep adding if not full ... allow for terminating null byte
        if (input_pos < (MAX_INPUT - 1))
          input_line [input_pos++] = inByte;
      }  // end of switch
    }  // end of while incoming data
  }  // end of if incoming data
}  // end of readTC35
//---------------------------- Read Keyboard --------------------------------
void readKeyboard(){
  if (Serial.available () > 0)
    while (Serial.available () > 0) {
      char inByte = Serial.read ();
      switch (inByte)
        // if its an AT command, send it to TC35 without processing
        // ---------------- a --------------------- A -------------------- t -------------------- T --
        if(input_line[0] == 97 || input_line[0] == 65 && input_line[1] == 116 || input_line[1] == 84){
          gsmSerial.println(input_line);
        else{
        input_pos = 0;
      default:
      }  // end of switch
}  // end of readKeyboard
//---------------------------- process_data --------------------------------
void process_data (char * data){
  // display the data
    Serial.println (data);
  if(strstr(data, "??")){    // If data contains ?? display the menu
    Serial.print("\r\n Keyboard Help Menu\r\n ??         This Menu\r\n readsms    List the SMS messages\r\n smsgone    Delete all SMS messages\r\n");
  if(strstr(data, "+CMGR:") && strstr(data, "+448080808080")){
    // Reads the +CMGR line to check if SMS is from a known Phone number
    // This if statement could cover the whole of the process_data function
    // then only known a phone number could control the Arduoino
  if(strstr(data, "readsms")){    // If data contains readsms
    gsmSerial.println("AT+CMGL=\"ALL\"");  // Read all SMS on the SIM
  if(strstr(data, "smsgone")){
    delete_All_SMS();
  if(strstr(data, "^SMGO: 2")){ // SIM card FULL
    delete_All_SMS();           // delete all SMS
  if(strstr(data, "+CMTI:")){    // An SMS has arrived
    char* copy = data + 12;      // Read from position 12 until a non ASCII number to get the SMS location
    SMS_location_number = (byte) atoi(copy);  // Convert the ASCII number to an int
    gsmSerial.print("AT+CMGR=");
    gsmSerial.println(SMS_location_number);  // Print the SMS in Serial Monitor
  }                                          // this SMS data will go through this process_data function again
                                             // any true if statements will execute
  if(strstr(data, "Heating on")){              // If data contains Heating on
    Serial.println("Heating is switched ON");  // Control your syuff here
    //delete_one_SMS();  // delete the SMS if you want
  if(strstr(data, "Heating off")){
    Serial.println("Heating is switched OFF");
    //delete_one_SMS();
  if(strstr(data, "Lights on")){
    Serial.println("Lights are ON");
    //delete_one_SMS();
  if(strstr(data, "Lights off")){
    Serial.println("Lights are OFF");
    //delete_one_SMS();
}  //--------------------------- end of process_data ---------------------------
void delete_one_SMS(){
  Serial.print("deleting SMS ");
  gsmSerial.print("AT+CMGD=");
void delete_All_SMS(){
  for(int i = 1; i <= 20; i++) {
    gsmSerial.println(i);
    Serial.println(i);
Hope this helps
dan007
#9
Feb 28, 2013, 07:37 pm Last Edit: Feb 28, 2013, 07:41 pm by dan007 Reason: 1
Looks like my weekend is sorted, I have pretty much a small snipet of code running at the moment, that can do the following;
  • Send SMS
  • Read SMS
My task was to read the sms then store into an array of some sort, then learn how to parse out the actual message content recieved.
Next step would be to make it automatically get the new message and do the same with the data. Followed by the deletion of that message making it available for the next command.
I noted the code was for TC35 not TC35i, but that neither here nor there as AT commands and functionality are pretty much all the same from various modems including phones.
Hugo and LJRob, thanks a bunch and shall keep you posted on how the project goes.
Hopefully I will eventually be able to post a YouTube video on the working solution......fingers crossed :-)
Regards
Dan
P.S both examples and coding is well written, and well documented. Makes it great for understanding the functionality.
hugo007
Quote
Great news. I want to see the final result
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
dan007
Hey guys,
All is going quite well at the moment during a debug stage and understanding of the code.
As I progress I have been editing it slightly to meet the demand and eliminate code that isn't required.
As it stands I can send an sms, heating on/off, lights on/off, and create actions based on this (currently LED change state). I added a feature so that when the heating/lighting changes state it replies with a message for example, "Heating is now on" to let the user (myself) know that it has been actioned. At a later date this will be done by a fail safe connection from a relay, so unless the relay is energised the light can't be on.
Added a general status function in which acts on the command status, and then produces "Heating ON, Lighting OFF" for example.
Going to start having a look at ripping apart a smoke alarm for fire detection, get a PIR for house alarm etc.
Regards
Dan
But I can honestly say it is coming on grand :-)
daveb27
Hi Dan,
Would you be able to post up your code for receiving SMSs messages?
I am working on a project where, when a smoke detector is activated, it sends an RF signal to my Arduino which then calls or texts (or both) my phone. It is working great but I want to be able to send an SMS containing a phone number to Arduino which then becomes the default number that is called when the smoke detector is triggered. In summary I am having no joy receiving SMSs!
Cheers,
Dave
dan007
Hi Dave, the sketch posted by LJrob will meet your needs regarding receiving a SMS, it will just need to be tweaked to how you want it to work.
Regards
Dan
jameslohara
I found this for anyone that was looking to use the siemens mc35i gsm modem for controlling your house heat remotely. I'm sure you can change the code for other uses.
Arduino based House Heater Controler with SMS User Interface in the Instructables web site.
http://www.instructables.com/id/Arduino-based-House-Heater-Controler-with-SMS-User/#intro
