Topic: Arduino Act like a USB keyboard (Read 9572 times) previous topic - next topic
marloeleven
I want to make my Arduino to send array of keystrokes with a delay to my PC just like a normal keyboard was, the only difference is that, keys are already declared and an ON/OFF button to start/terminate the program when running.
what confuses me are this questions in my mind:
- and i think there's a library needed to be called to make this thing works
- can i reuse keyboard chip, control it to send button to pc?
Actually, i have no idea how arduino works.. this was just a redesigned idea of my program that i want to do. my first program works but when i want it to be applied on different application, it didn't. so i was hoping that an external like keyboard that will send keystrokes to my computer will allow me to use it in any applications i want. please help me..  ^_^
- sorry if this post is not in its right place  :smiley-eek-blue:
Grumpy_Mike
This is the arduino you want to get:-
http://arduino.cc/en/Guide/ArduinoLeonardo
This will allow you to look at key presses on external hardware and ship them off to a PC and it will look like it came from a PC keyboard.
karlok
It works with Arduino UNO as well.
I tested it successfully with mine using UnoJoy.
Paul Beaudet
#3
Feb 03, 2013, 07:11 pm Last Edit: Feb 03, 2013, 07:13 pm by Paul Beaudet Reason: 1
Isn't programming the second mcu required for this?
looks like UnoJoy is a firmware for the serial comm chip
would seem a little too much for someone just getting started
I'm with mike on this one, but I would go further to suggest the Arduino Mirco as well. Dont know about else where but they stock them at my local electronics shop
its integrated when you select leonardo, micro, lilypad usb,(MEGA34u4 chip) or due. Given you have any of these boards.
otherwise I think your in for a bit of hacking, checkout UnoJoy
karlok
Everything needed is included here
http://code.google.com/p/unojoy/
and here
http://www.atmel.com/tools/FLIP.aspx
Yes the Arduino's USB interface has to be flashed. This is done with Atmel's FLIP tool.
There is a Arduino-keyboard-0.3.hex available here:
http://hunt.net.nz/users/darran/weblog/b3029/Arduino_UNO_Keyboard_HID_version_03.html
robtillaart
The teensy2.0 has native keyboard support - http://www.pjrc.com/teensy/td_keyboard.html -
I've played with one last week and the examples work out of the box - uploading to a teensy is only slightly more difficult, but blazingly fast!
Rob Tillaart
