Topic: Hilfe Bekomme die real time clock nicht ans laufen. (Read 7054 times) previous topic - next topic
schilli84
Doch uwe aber die haben alle den gleichen fehler
Das von mde110 geht leider auch nicht da kommt
Quote
sketch_jan14a:1: error: function definition does not declare parameters
In file included from sketch_jan14a.ino:4:
C:\Users\Dominic\Documents\Arduino\arduino-1.0.3\libraries\Wire/Wire.h:76: error: 'TwoWire' does not name a type
sketch_jan14a:6: error: 'DS1307new' does not name a type
sketch_jan14a:8: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:9: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:10: error: expected constructor, destructor, or type conversion before '(' token
sketch_jan14a:11: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:12: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:13: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:14: error: expected constructor, destructor, or type conversion before '(' token
sketch_jan14a:15: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:16: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:17: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:18: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:19: error: expected constructor, destructor, or type conversion before '.' token
schilli84
#16
Jan 14, 2013, 06:51 pm Last Edit: Jan 14, 2013, 07:16 pm by schilli84 Reason: 1
So der scanner hat was gefunden
spaceball
#17
Jan 14, 2013, 07:32 pm Last Edit: Jan 14, 2013, 07:37 pm by spaceball Reason: 1
Schau mal hier nach:
https://github.com/watterott/mSD-Shield/downloads
Im Packet ist eine DS1307-Library und ein Beispiel.
Eventuell mußt Du noch die Baud-Rate (für serial) anpassen.
Mit dem weißt Du mal, obs an der Hard- oder an der Software liegt...
Gruß
Reinhard
PS.: Zum Testen einfach alle gelieferten Libraries reinhauen
schilli84
ok das geht dan kommt:
Quote
Init Display...
Init RTC...
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
Date: 165.165.2165
Time: 165:165:85
im serial monitor
schilli84
Quote
I2C Scanner
Scanning...
I2C device found at address 0x68 !
done
Mardetuino
Quote
So, habe mir jetzt extra die Arbeit gemacht und 1.0.3 neu entpackt und die Zip aus meinem Link in den Library Ordner entpackt.
Die Examples gehen. Ich vermute mal du hast an den Libs rumgespielt...
Also mach das bitte auch. Arduino 1.0.3 in ein neues Verzeichnis frisch entpacken.
Die DS1307new runterladen und in den Lib Ordner entpacken. Also da rein: arduino-1.0.3\libraries\DS1307new, sodass nacher auf jeden Fall diese Dateien vorhanden sind:
arduino-1.0.3\libraries\DS1307new\DS1307new.cpp
arduino-1.0.3\libraries\DS1307new\DS1307new.h
Dann kompiliere bitte das Example!
schilli84
hey super leute sie geht jetzt.
nur wie kann ich sie einstellen??
Mardetuino
Probiere doch mal ein bisschen rum anstatt gleich zu Fragen. So lernt man nichts...
schilli84
So danke leute es hat geklappt uhr ist auch eingestelt.
morgen versuche ich mal die temperatur mit ins lcd zu bekommen.
und eine led zu bestimten zeiten ein und aus zu schalten.
mfg
