Topic: Is there such a thing as a 1 amp, DC circuit breaker? (Read 901 times) previous topic - next topic
David82
I've tried googling it but found nothing that meets the requirement. I have an autonomous robot that uses servos. On rare occasion, it gets stuck in some weird position that will cause the servo to burn up. If I had a circuit breaker or even a low amp automotive fuse, I could save myself some money.
LarryD
You could look into "foldback current limiting"
https://www.google.ca/search?q=foldback+current+limiting&hl=en&tbo=u&rlz=1T4GZAZ_enCA411CA411&tbm=isch&source=univ&sa=X&ei=ipz0UMjcLuK2iwKmhIDABg&ved=0CDcQsAQ&biw=979&bih=401
No technical PMs.
The last thing you did is where you should start looking.
zoomkat
Check radioshack
http://www.radioshack.com/category/index.jsp?categoryId=2032234
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
David82
Check radioshack
I appreciate the help but that's obviously not it. I did finally find the answer though for anyone else that finds this thread. You use what is called a polyfuse (aka, polyswitch). They are perfect. They are cheap and open the circuit when they get hot while closing the circuit when they cool down. Perfect.
http://en.wikipedia.org/wiki/Resettable_fuse
retrolefty
Check radioshack
Yes I was just about to post about these:
http://www.epcos.com/inf/55/db/PTC_09/OC_Leaded_12V_160_C2_B0C_C_B599_5.pdf
Lefty
zoomkat
Check radioshack
:smiley-roll-blue:
http://www.radioshack.com/family/index.jsp?categoryId=12573697
David82
yea, that's them. that wasn't your original link. Anyway, those are just online and are, of course, going to be over priced since it's radioshack.
http://www.digikey.com/catalog/en/partgroup/polyfuse-60r-series/10877
zoomkat
Quote
Sure they are, on the left side of the linked page is a listing of various types of fuses. I'd think you would start with a more conventional fuse for testing, but good luck with your polyfuse choise.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
