Topic: Unable to use pass HardwareSerial to classes in due (Read 3586 times) previous topic - next topic
brickmaster32000
I have a Due that is using a gps and I am trying to build a library to simplify its use. I actually am going to reuse the code on a couple of Dues so I want to be able to pass a specific serial port to use for communication so I can change it based on what pins I use. For now I have a simple class set up that accepts a HardwareSerial pointer in the constructor and a function to print a test message. The code compiles fine and on a Uno it actually works as expected. When I compile it for the Due I get the following warning.
sketch_jan14a.cpp.o: In function `SerialTest::begin(long)':
C:\Users\pepi0003\Downloads\arduino-1.5.1r2/sketch_jan14a.ino:29: warning: undefined reference to `HardwareSerial::begin(unsigned long)'
Binary sketch size: 9,720 bytes (of a 524,288 byte maximum)
The code still compiles and can be uploaded to the due but doesn't actually print anything on the serial port. Here is the code I am using. Any help would be appreciated.
class SerialTest{
  public:
    SerialTest(HardwareSerial *ser);
    void begin(long baud);
    void printHelloWorld();
  private:
    HardwareSerial *hwSerial;
SerialTest test(&Serial);
void setup(){
  test.begin(9600);
void loop(){
  test.printHelloWorld();
SerialTest::SerialTest(HardwareSerial *ser){
  hwSerial = ser;
void SerialTest::begin(long baud){
  hwSerial->begin(baud);
void SerialTest::printHelloWorld(){
  hwSerial->println("Hello world!");
drobe011
#1
Jan 15, 2013, 02:20 am Last Edit: Jan 15, 2013, 01:34 pm by drobe011 Reason: 1
Not sure if this helps, but here is how I have done it in my endeavours:
I originally tried to use HardwareSerial Class to pass, but seems it wasn't the right object.  In the compiler error output it complained about trying to convert UARTClass to HardwareSerial.  Once I dug around a few, I found the actual two classes I needed to be able to pass a HardwareSerial object.
[Updated]
UARTClass *ucTx;
ucTx = &Serial;
[/Updated]
USARTClass *ucTx;
ucTx = &Serial1; // Can be Serial 1-3 [s]Could just use Serial for HardwareSerial0[/s]
-Dave
Edit: USARTClass is for HardwareSerial1-3(Serial1-Serial3).
HardwareSerial0(Serial) is of class UARTClass (virtual COM port via ATmega16U2 to PC).
main.cpp includes Arduino.h
Arduino.h includes HardwareSerial.h and variant.h
variant.h includes both UARTClass.h and USARTClass.h
lloyddean
#2
Jan 15, 2013, 02:50 am Last Edit: Jan 15, 2013, 03:00 am by lloyddean Reason: 1
class SerialDevice
   HardwareSerial&     _serial;
public:
   SerialDevice(HardwareSerial& serial)
       : _serial(serial)
   void begin(long baud)   { _serial.begin(baud);             }
   void printHelloWorld()  { _serial.println("Hello world!"); }
SerialDevice device(Serial);
   device.printHelloWorld();
   delay(1000UL);
   device.begin(9600);
PaulS
Where does your class learn what the HardwareSerial name refers to? You appear to missing some necessary include statements.
brickmaster32000
I tried your code Dave and it is working perfectly now. I had been poking around in the old libraries and didn't realized that the ones for the due where stored in a separate folder. Is there any drawback to passing a reference to the class like in lloydeans code as apposed to using a pointer.
drobe011
I believe in the context above pointer/reference would equal to the same thing.
The goal I was trying to achieve passing by pointer or reference was to eliminate passing by value, ie. sending the whole USARTClass object as a function param.  Save more memory just passing reference or actual memory location to USARTClass versus a (basically) literal copy of it.
Dave
lloyddean
If by reference as above the compiler will never allow you to compile without passing the Serial device.
SerialDevice device;
Will generate a compile time error/warning
ahkub
#7
Feb 10, 2014, 12:54 am Last Edit: Feb 10, 2014, 09:39 am by ahkub Reason: 1
Hello brickmaster32000,
I'm fighting the same issue on a Due as you did.
You said, when implementing Dave's workaround, it works for you.
I have a hard time figuring out where exactly you needed to place Dave's code.
May I ask you to post your code with Dave's workaround included?
Much appreciated.
Best regards,
Ahkub
Sorry for the dumb question. I looked at your code at GitHub (Century-Fablab-Projects) and found the answer:
I need to replace all "HardwareSerial" with "USARTClass" in the CPP file as well as in the H file.
Best regards,
Ahkub
