Topic: Convert String From Serial Data to Numerical Value (Read 12098 times) previous topic - next topic
chiques
Hello Everyone,
I've been able to read and select a string of data to display on my terminal using:
Code: [Select]
for (int i=6;i<11;i=i+1) {
  Serial.print(sensorstring[i]);
Serial.println(" Liters/Minute");
My goal is to convert this value to a 'number' so I can run an algorithm on it. I tried to use
Code: [Select]
Serial.parseInt()
but am unable to figure out the syntax and the Arduino Reference site does not have any examples.
Any insight is appreciated.
billroy
HazardsMind
#2
Jan 14, 2013, 11:59 pm Last Edit: Jan 15, 2013, 12:11 am by HazardsMind Reason: 1
That "string" is an array so by using atoi(sensorstring) it will be converted to an integer.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
chiques
Thanks for that, I tried:
Code: [Select]
      int value = atoi(sensorstring);
      Serial.println(value);
Quote
error: cannot convert 'String' to 'const char*' for argument '1' to 'int atoi(const char*)'
Is it because it's reading sensorstring as '1'?
billroy
Sorry, it's probably time to show us all your code, please.  I was guessing that sensorvalue was char[] not String.
-br
chiques
-br
No Problem, here it is:
Code: [Select]
#include <SoftwareSerial.h>                                                    //add the soft serial libray
#define rxpin 2        //set the RX pin to pin 2
#define txpin 3        //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin);                                         //enable the soft serial port
String inputstring = "";                                                       //a string to hold incoming data from the PC
String sensorstring = "";                                                      //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false;                                          //have we received all the data from the PC
boolean sensor_stringcomplete = false;                                         //have we received all the data from the Atlas Scientific product
  void setup(){        //set up the hardware
     Serial.begin(38400);                                                      //set baud rate for the hardware serial port to 38400
     myserial.begin(38400);                                                    //set baud rate for software serial port to 38400
     inputstring.reserve(5);                                                   //set aside some bytes for receiving data from the PC
     sensorstring.reserve(30);                                                 //set aside some bytes for receiving data from Atlas Scientific product
   void serialEvent() {                                                         //if the hardware serial port receives a char
               char inchar = (char)Serial.read();                               //get the char we just received
               inputstring += inchar;                                           //add it to the inputString
               if(inchar == '\r') {input_stringcomplete = true;}                //if the incoming character is a <CR>, set the flag
void loop(){        //here we go....
  if (input_stringcomplete){                                                   //if a string from the PC has been recived in its entierty
      myserial.print(inputstring);                                             //send that string to the Atlas Scientific product
      inputstring = "";                                                        //clear the string:
      input_stringcomplete = false;                                            //reset the flage used to tell if we have recived a completed string from the PC
  while (myserial.available()) {                                               //while a char is holding in the serial buffer
         char inchar = (char)myserial.read();                                  //get the new char
         sensorstring += inchar;                                               //add it to the sensorString
         if (inchar == '\r') {sensor_stringcomplete = true;}                   //if the incoming character is a <CR>, set the flag
   if (sensor_stringcomplete){                                                 //if a string from the Atlas Scientific product has been received in its entirety
       Serial.print(sensorstring);                                             //use the hardware serial port to send that data to the PC
       sensorstring = "";                                                      //clear the string:
       sensor_stringcomplete = false;                                          //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
HazardsMind
#6
Jan 15, 2013, 01:04 am Last Edit: Jan 15, 2013, 01:11 am by HazardsMind Reason: 1
Oh you want sensorstring.toInt(), not sensorstring[ i ].
My GitHub:
chiques
Hi HazardMind,
I'm looking for some sample code to see how this is used. Is this something similar to what you suggest?
http://electronics.stackexchange.com/questions/38845/arduino-serial-read-to-int
HazardsMind
#8
Jan 15, 2013, 01:50 am Last Edit: Jan 15, 2013, 02:00 am by HazardsMind Reason: 1
I'm not home right now, but I will give you a sample as soon as I can.
Edit: I was able to get this from a post I did a while back. Wow my iPhone likes to stretch things out. Sorry about that.
Code: [Select]
control test
#include<string.h>
int DRV1,DRV2,STRR,STRL;
int x = 0;
int y = 0;
int s = 0;
void move(int x = 0,int y = 0,int s = 0);
//double z;
String val = "";
String  X= "";
String  Y= "";
String  state = "";
//int state = 0;
int currentCommand = 0;
int ledpin = 13;
byte Mopen = 4;
byte Mclosed = 2;
byte M1L = 3;// PWM
byte M2L = 5;// PWM
byte M1R = 9;// PWM
byte M2R = 6;// PWM
  pinMode(ledpin, OUTPUT);  // pin 13 (on-board LED) as OUTPUT
  pinMode(Mopen, OUTPUT);
  pinMode(Mclosed, OUTPUT);
  pinMode(M1L, OUTPUT);
  pinMode(M1R, OUTPUT);
  pinMode(M2L, OUTPUT);
  pinMode(M2R, OUTPUT);
  Serial.begin(9600);       // start serial communication at 115200bps
  if( Serial.available())       // if data is available to read
    digitalWrite(ledpin, HIGH);
    char c= Serial.read();
    if (c == ','){    //look at the incoming chars, if it is a ',' then switch the case
      currentCommand++;
    else {   //if it is not ',' then store chars in string
      val += c;
      //Serial.println(val);
      switch (currentCommand) {
      case 0:
        X += val;
        val = "";
      case 1:
        Y += val;
        val = "";
      case 2:
      //Serial.println("X: "+X);
      //Serial.println("Y: "+Y);
        state = val;   // this will only receive 1 value
        currentCommand = 0;
        val = "";
        //Serial.println("state: "+state);
        //Serial.println();
        x=X.toInt();  //string to int
        y=Y.toInt();  //string to int
        s=state.toInt();  //string to int
        X=""; Y=""; state="";
        move(x, y, s);
  void move(int x, int y, int s)
      x=constrain(x, -90, 90);
      y=constrain(y, -90, 90);
  //Movement varibles
  int DRV2 = map(x, -90, 0, 255, 0);
  int DRV1 = map(x, 0, 90, 0, 255);
  int STRR = map(y, -90, 0, 255, 0);
  int STRL = map(y, 0, 90, 0, 255);
  if(x > 0)//forwards
    //Serial.println("Driving");
    analogWrite(M1L, abs(DRV1 - STRL)); analogWrite(M1R, abs(DRV1 - STRR));
    analogWrite(M2L, 0); analogWrite(M2R, 0);
  else if(x < 0)//backwards
    analogWrite(M1L, 0); analogWrite(M1R, 0);
    analogWrite(M2L, abs(DRV2 - STRR)); analogWrite(M2R, abs(DRV2 - STRL));
  else if(x == 0 && y >0)//right
    analogWrite(M1L, STRL); analogWrite(M1R, 0);
    analogWrite(M2L, 0); analogWrite(M2R, STRL);
  else if(x == 0 && y < 0)//left
    analogWrite(M1L, 0); analogWrite(M1R, STRR);
    analogWrite(M2L, STRR); analogWrite(M2R, 0);
  else //full stop
    digitalWrite(M1L, LOW); digitalWrite(M1R, LOW);
    digitalWrite(M2L, LOW); digitalWrite(M2R, LOW);
   if(s == 1)
      //Serial.println("Claw Opening");
      digitalWrite(Mopen, HIGH); digitalWrite(Mclosed, LOW);
    if(s == 2)
      //Serial.println("Claw Closing");
      digitalWrite(Mopen, LOW); digitalWrite(Mclosed, HIGH);
    if(s == 0)
      digitalWrite(Mopen, LOW);  digitalWrite(Mclosed, LOW);
   else{
    digitalWrite(ledpin, LOW);
    x=0; y=0; s=0;
My GitHub:
michinyon
You could also try something like this:
int bufsize=20 ;
char buffer[bufsize] ;
yourString.toCharArray( buffer, bufsize );
int val = atoi( &buffer[0] );
provided it is an integer  and not a number with a decimal point in it,  this might work.
if you like your strings to be simple character arrays, use C
if you like your strings to be objects, use Java
Dealing with both can be a real pain in the neck.
chiques
Code: [Select]
control test
#include<string.h>
int x = 0;
int y = 0;
int s = 0;
Hi HazardsMind,
I went through the sample you suggested and noted what "I think" each line does. The only one which I am figuring out are:
Quote
1. void move(int x = 0,int y = 0,int s = 0);  //Not sure why this needs to be done ???
Quote
2. move(x, y, s); // DO NOT UNDERSTAND "move()"
Code: [Select]
//from http://arduino.cc/forum/index.php?topic=142777.0
control test //name of program
#include<string.h> //name of library needed
int DRV1,DRV2,STRR,STRL; //declare 4 integers
int x = 0; //intialize x
int y = 0; //initialize y
int s = 0; //initialize s
//double z; //double the z variable (for more precision)
String val = ""; //set some buffer aside for val
String  X= ""; //set some buffer aside for X
String  Y= ""; //set some buffer aside for Y
String  state = ""; //set some buffer aside for state
//int state = 0; //initialize state to 0
int currentCommand = 0; //initialize current command to 0
int ledpin = 13; //set LED pin
byte Mopen = 4; //sets Mopen to B0100
byte Mclosed = 2; //sets Mclosed to B00010
byte M1L = 3;// PWM
byte M2L = 5;// PWM
byte M1R = 9;// PWM
byte M2R = 6;// PWM
 pinMode(Mopen, OUTPUT);  // pin Mopen is set as an output
 pinMode(Mclosed, OUTPUT); // pin Mclosed is set as an output
 pinMode(M1L, OUTPUT);     //pin MIL is set as an output
 pinMode(M1R, OUTPUT);  // in MIR is set as an output
 pinMode(M2L, OUTPUT);  //pin M2L is set as an output
 pinMode(M2R, OUTPUT); // pin M2R is set as an output
 if( Serial.available())       // if data is available to read, this is how to check the serial part for strings
   digitalWrite(ledpin, HIGH); // if data is detected set the pint set to ledpin to HIGH (ON)
   char c= Serial.read(); // the string in serial read() is buffered in to c as characters
     currentCommand++;  //for some reason currentCommand increments????
   else {   //if it is not ',' then store chars in string, keep storing the string until a , is found
     val += c;  // same as (val + c = c)val is the next string + the previous character stored in buffer
     switch (currentCommand) { // for each string, currentCommand appears to increment by 1
     case 0:  //in the even there was only 1 string before the ',' X is equal to the val in buffer and val buffer is cleared ""
       X += val; // same as (X + val = val), new variable X is equal to the whole string val before the ','
       val = ""; // clear the information in the val buffer
       break; // break out of case 0
     case 1: //if currentCommand equals 1
       Y += val; // same as (Y + val = val), Y is now the string waiting in the val buffer
       val = ""; // clear out the val buffer
       break; //get out of case 2
     case 2:
       currentCommand = 0; //reset currentCommand counter to 0
       //Serial.println();
       x=X.toInt();  //string to int , convert string X to integer
       y=Y.toInt();  //string to int, convert string Y to integer
       s=state.toInt();  //string to int, convert state to integer
       X=""; Y=""; state=""; //clear the X, Y and state buffer information
       break; // get out of case 3
//***ALL THIS STUFF BELOW IS FOR SERVO MOVEMENT
//***SENDS OUT VOLTAGE VALUES
 //Movement varibles
 if(x > 0)//forwards
 else //full stop
  if(s == 1)
   if(s == 2)
   if(s == 0)
  else{
   x=0; y=0; s=0;
Arrch
#11
Jan 16, 2013, 07:24 pm Last Edit: Jan 16, 2013, 07:47 pm by Arrch Reason: 1
Phew, where to begin...
Quote
This is a function prototype. The Arduino IDE handles these for you, so typically these are not necessary.
Quote
It's just a call to the function with the provided values.
Code: [Select]
characters, not strings.
Code: [Select]
the character is read, not the string
Code: [Select]
If the character is a deliminator (comma in this case) increment the number of commands received.
Code: [Select]
If it's not a comma, concatenate it onto the String val (note the difference in capitalization, String and string are not the same thing).
HazardsMind
#12
Jan 16, 2013, 07:31 pm Last Edit: Jan 16, 2013, 07:40 pm by HazardsMind Reason: 1
Quote
Its not needed, you can take it out. I originally wrote this code using a C++ based debugger software (old software), and it had to be inserted at the top. so when I brought it to arduino, I forgot to take it out.
Quote
Move() is a function I made that feeds those gotten values to my motors, it is get rid of too much cluster in my Loop function.
It is very difficult to modify code on an IPhone, so I just left everything in. I just wanted to show you an example of how to get, convert and split the data to different ints.
And they are not servos, they are DC motors. However same can be done with servos.
My GitHub:
chiques
Thanks Arrch,
I would like convert this into a floating number but I'm having a hard time finding the Reference syntax in Arduino for the following C equivalents? Would you happen to know where I can find them?
Code: [Select]
atol (Convert string to long integer) obvoiusly this is "toInt()"
atof (Convert string to double)
strtol (Convert string to long integer)
PaulS
You need to be clearer about what you want to do. There is a huge difference between a string and a String. The string is not a class and does not have a toInt() method.
Frankly, you should not be using the String class at all. It has a major problem that is going to, sooner or later, bite you.
