Pages: 1 [2] 3   Go Down
Author Topic: Convert String From Serial Data to Numerical Value  (Read 1244 times)
You need to be clearer about what you want to do. There is a huge difference between a string and a String. The string is not a class and does not have a toInt() method.
Frankly, you should not be using the String class at all. It has a major problem that is going to, sooner or later, bite you.
Now I'm really lost. My goal is to convert the second string to a value so I can write some algorithms.
0.000,0.000,0.000
This looks like it's converting each ASCII character
String : ASCII
0 : 48
.  : 46
0 : 48
0 : 48
0 : 48
Ref: http://arduino.cc/en/Tutorial/ASCIITable
I know this doesn't solve my conversion problem but I'm practicing difference string conversions.
Seattle, WA USA
Seattle, WA USA
Please don't post code using the invisible font.
Queens, New York
Online Online
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
atof (Convert string to double)
double = float.
Edit.
« Last Edit: January 16, 2013, 03:11:35 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Seattle, WA USA
Seattle, WA USA
This method is used for arrays, not strings.
It most certainly is for strings. It is NOT for non-NULL-terminated arrays of chars.
This will take some time to soak in.
Thanks
I'm not understanding why I'm unable to convert the Liters/Minute to a numberical value.
7.320,4.734,284.057
4.7340 Liters/Minute
0  in HEX
   if (sensor_stringcomplete){                                                 //if a string from the Atlas Scientific product has been received in its entirety
      Serial.println(sensorstring);                                             //use the hardware serial port to send that data to the PC
  for (int i=6; i<11; i++)  {
    Serial.print(sensorstring[i]);     //print each string character to verify
    float flowLong = (sensorstring[i] - '0');
    Serial.print(flowLong);Serial.println(" Liters/Minute");
    if (flowLong < 4.5) {
    Serial.println("FLOW WARNING!!!");
       Serial.print(flowLong,HEX);Serial.println("  in HEX");
       sensorstring = "";                                                      //clear the string buffer:
       sensor_stringcomplete = false;                                          //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
California
Online Online
Start by fixing your indenting; it's atrocious and makes it very difficult to follow.
So loop through 5 characters in a string, creating a new float variable, assigning it a variable, and discarding it.
When you declare a variable like you are doing here, it is only valid inside the innermost curly braces. So the flowLong you create here isn't the same as the flowLong as you are printing to the screen. Not that fixing the scope issue will fix your issue; the algorithm you are using make absolutely no sense and will only result in floatLong containing the numeric value of the last digit.
Drop the String object. Use c style strings and atof().
Simple servo code that takes a numerical string from the serial monitor and converts it into a number for controlling a servo.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-delomit-test-22-dual-input"); // so I can keep track of what is loaded
  //expect a string like 700, or 1500, or 2000,
  //or like 30, or 90, or 180,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          myservo.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          myservo.write(n);
        //do stuff with the captured readString
        readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
put in key search words,
What is the syntax to convert to floating?
Queens, New York
Online Online
Easy, readString.toFloat();
Check this out,
http://mootools.net/docs/core/Types/Number
Check this out,
Uhm, not sure what I'm doing wrong.
int n = readString.toFloat();
error: 'class String' has no member named 'toFloat'
California
Online Online
Not included with Arduino's version of the String object library, much like sprintf() doesn't accept the %f format specifier.
Hi Arrrch,
Does this mean its not possible to convert a string to float in Arduino?
Queens, New York
Online Online
There is a patch you need to download to get .toFloat().
http://www.timewasters-place.com/arduino-string-and-float/
Also you wouldn't store a float value in an int, you would put it in a double.
So,
double n = readString.toFloat();
« Last Edit: January 17, 2013, 02:16:59 pm by HazardsMind » Logged
California
Online Online
Hi Arrrch,
Consider it a sign to stop using Strings and take a few minutes to learn about strings.
Pages: 1 [2] 3   Go Up
