Topic: Best Display with Arduino - to use ? (Read 896 times) previous topic - next topic
gnusso
Good Morning Folks,
I'd like to know which is the best display to use with Arduino ...
In particular in my sketch I'm using several library:
- Virtual Wire
- Keypad
- DataTime.h
- DS1307.h
I'd like to know if can be particular issues with that library,
Thanks
Andrea
johnwasser
The only issue I have heard about is some "I2C" serial LCD's not having an I2C address and therefore not playing nice with other I2C devices like the RTC.  A normal 6/10-pin parallel LCD should not cause that problem.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
If a serial display is used, there should be minimal issues.
http://www.newhavendisplay.com/serial-displays-c-253.html
Will leave you the most pins free for the keypad:
Virtualwire - 2 pins (D11, D12 are the default)
DS1307 -2 pins (A4/A5)
Display - 2 pins, can be D0, D1
Keypad - 14 left for up to a 7x7 keypad (or 8x6, 9x5, 10x4, etc).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
