Topic: Is it possible to write a pin open? (Read 538 times) previous topic - next topic
NFrank89
Is it possible to switch a pin open and high as opposed to high or ground?
analog or digital, can either one write open?
PaulS
A pin is either INPUT or OUTPUT. In either configuration, it is either HIGH or LOW.
What do you mean by open? Files and doors can be open. Pins can't.
Krodal
#2
Jan 15, 2013, 11:51 am Last Edit: Jan 15, 2013, 12:00 pm by Krodal Reason: 1
Yes.
If a pin is INPUT, the impedance is very high. So the pin is floating.
If a pin is OUTPUT, it can be set HIGH or LOW.
So it it possible to use a pin as a open collector by switching it between INPUT and OUTPUT LOW. However two instructions are needed for the microcontroller, and using the pull-up resistor should be avoided. You have to read the datasheet for that.
The 'open collector' is not a real open collector, since the voltage on the pin may not be above 5V.
If you want to switch between open/floating and high 5V. You need a few instructions:
const int myPin 10;
// pin open/floating
// set as input, no pull-up in Arduino 1.0.1 and higher.
pinMode( myPin, INPUT);
// pin HIGH
// first set the pullup,
// to be sure the output is high at the moment the pin is set as OUTPUT
pinMode( myPin, INPUT_PULLUP);
pinMode( myPin, OUTPUT);
digitalWrite( myPin, HIGH);
The analog inputs can be set as digital input or digital output pins.
So it is the same for analog inputs.
http://arduino.cc/en/Reference/pinMode
http://arduino.cc/en/Reference/digitalWrite
GoForSmoke
const int myPin 10;
// pin HIGH
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
GoForSmoke
It is only floating if you don't connect it to anything and have it set LOW.
And who reads a disconnected INPUT except someone looking for randoms in a weird way?
You can connect a pin to ground through a switch, set the pin to INPUT and digitalWrite it HIGH then when you close the switch it will ground to LOW **through the pullup resistor**. That makes a nice, safe button/switch circuit which at no time is floating but does need to be debounced.
liudr
It seems like your term "OPEN" is not well understood. When I encounter this, I would try to explain why I want a pin "OPEN". You could help us understand your need to "OPEN" a pin if you tell us the why. Complete your story.
