Loading...
Pages: [1]   Go Down
Author Topic: How to read 17bytes from a sensor via Serial?  (Read 248 times)
Offline Offline
Newbie
View Profile
I'm attached a Sensor IR-Array Sensor. With the following code I'm reading every byte it sends.
Code:
int incomingByte = 0;   // for incoming serial data
        Serial.begin(11500);     // opens serial port for console
        Serial.print("Output active");
        Serial1.begin(19200);     // opens serial port to sensor
        Serial.print("Sensor active");
        if (Serial1.available() > 0) {
                Serial1.read();
 Serial.println(incomingByte , HEX);
now the sensor has a output format of total 17bytes.  (please take look at the Picture ).
How can I read this 17bytes correctly from the beginning, so I don't grabing the data from the middle?
Please Help.
superkato
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Read two bytes. See if the first one is 0x00 and if the second one is 0xDF. If not, move byte to to byte 1, and read another byte. Repeat until the two bytes are 0x00 and 0xDF.
Then, read the next 15 bytes, as they become available.
Of course, as you read a value, you need to assign it to a variable. Discarding it (as you are doing) doesn't make sense.
Logged
Offline Offline
Newbie
View Profile
00 DF  and so on is just an example
the values could be       0x6c 0x2F            0x04 0x2F
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
What sensor is it + links to full datasheet please.
Logged
Offline Offline
Newbie
View Profile
its a custom sensor IR array, there is no official spec yet.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
What causes it to start sending serial data? Does it send data only in response to a "Hey, there" kind of command?
Logged
Offline Offline
Newbie
View Profile
after its powered on it starts sending smiley-sad  I wish there would be a start command but there is no.
could that the right way?
Code:
byte SerialData[17]; // 17byte for my Sensor Datagram
byte SensorData;
int index = 0; // Index into array; where to store the character
int T1 = 0;
int T2 = 0;
int T3 = 0;
int T4 = 0;
int T5 = 0;
int T6 = 0;
int T7 = 0;
int T8 = 0;
  // initialize serial communications
  Serial.begin(115200); //console
  Serial1.begin(19200); //sensor
   while(Serial.available() > 0) // Don't read unless
      for(index = 0; index == 16; index++) //0 to 16 is 17
        SensorData = Serial.read();
        SerialData[index] = SensorData;
   byte Pix1_0 = int(SerialData[0]);
   byte Pix1_1 = int(SerialData[1]);
   byte Pix2_0 = int(SerialData[2]);
   byte Pix2_1 = int(SerialData[3]);
   byte Pix3_0 = int(SerialData[4]);
   byte Pix3_1 = int(SerialData[5]);
   byte Pix4_0 = int(SerialData[6]);
   byte Pix4_1 = int(SerialData[7]);
   byte Pix5_0 = int(SerialData[8]);
   byte Pix5_1 = int(SerialData[9]);
   byte Pix6_0 = int(SerialData[10]);
   byte Pix6_1 = int(SerialData[11]);
   byte Pix7_0 = int(SerialData[12]);
   byte Pix7_1 = int(SerialData[13]);
   byte Pix8_0 = int(SerialData[14]);
   byte Pix8_1 = int(SerialData[15]);
   byte Checksum = int(SerialData[16]);
 //calculate Temperature Pixel 1
 T1 = 256*Pix1_0+Pix1_1;
 T1 = T1/10;
 //calculate Temperature Pixel 2
 T2 = 256*Pix2_0+Pix2_1;
 T2 = T2/10;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Code:
If there is at least one byte available, read all 17 of them. Hardly seems useful to store 16 -1s in the array.
That won't read a complete packet, anyway. It will simply, assuming that there are 17 or more bytes available, grab 17 bytes. Not necessarily the correct 17 to make a packet.
How often does the device send data? Is is a continuous stream, or is there a long (relatively) gap between the spaced parts that make up a packet?
Logged
Offline Offline
Newbie
View Profile
its sending continuously with a gap of 388msec.
I will try the Serial.readBytes class.
( Damn I wish I had more knowledge smiley-sad  Im just a beginner  and I wanted to do this for my dads project.)
« Last Edit: January 15, 2013, 09:18:47 am by superkato » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
So, you could read and discard serial data until the buffer is empty. Record that happens. When there is serial data again, record when that happens. If the time between events is greater than 360 milliseconds, you are at the start of a new packet.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
As PaulS says to wait for the 388ms delay, record 17 bytes then confirm by re-calculating the 16 byte checksum and comparing to be sure you have read valid data.
Logged
Offline Offline
Newbie
View Profile
how would I do that function ?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
It appears with your sensor the end of transmission marker is basically the 388msec. delay. Below is a simple setup that uses a small delay to allow the input buffer to be filled until the sensor delay occurrs.
Code:
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(2);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    readString="";
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
