Topic: 433 MHz RF - Temperature and humidity sensor (Read 112409 times) previous topic - next topic
Riva
I'm in the same case the sensor, but this analysis is not appropriate.
Tell me which direction to go?
The application record from the sensor.
I agree with your surmise in the next post that the data looks like 36 bits but you will need to log several temperature/humidity readings along with the corresponding bit data to give people a chance to decode the meaning of the bits. The make/model of sensor may also help as someone else may have already done the groundwork, potentially saving you a lot of time.
Don't PM me for help as I will ignore it.
Vitaliy86
Code has been fixed:
Code: [Select]
// Unknown 433Mhz weather sensor decoder. Untested in the real world.
// http://arduino.cc/forum/index.php/topic,142871.msg1106336.html#msg1106336
// __           ___       ___    ___
//   |_________|  |______|  |___|  |
//   |  Sync      |    1    |  0   |
//   |  8320us    | 4500us  | 2530us
// Defines
#define DataBits0 4                                       // Number of data0 bits to expect
#define DataBits1 32                                      // Number of data1 bits to expect
#define allDataBits 36                                    // Number of data sum 0+1 bits to expect
// isrFlags bit numbers
#define F_HAVE_DATA 1                                     // 0=Nothing in read buffer, 1=Data in read buffer
#define F_GOOD_DATA 2                                     // 0=Unverified data, 1=Verified (2 consecutive matching reads)
#define F_CARRY_BIT 3                                     // Bit used to carry over bit shift from one long to the other
#define F_STATE 7                                         // 0=Sync mode, 1=Data mode
// Constants
const unsigned long sync_MIN = 4300;                      // Minimum Sync time in micro seconds
const unsigned long sync_MAX = 4700;
const unsigned long bit1_MIN = 2300;
const unsigned long bit1_MAX = 2700;
const unsigned long bit0_MIN = 1330;
const unsigned long bit0_MAX = 1730;
const unsigned long glitch_Length = 300;                  // Anything below this value is a glitch and will be ignored.
// Interrupt variables
unsigned long fall_Time = 0;                              // Placeholder for microsecond time when last falling edge occured.
unsigned long rise_Time = 0;                              // Placeholder for microsecond time when last rising edge occured.
byte bit_Count = 0;                                       // Bit counter for received bits.
unsigned long build_Buffer[] = {0,0};                     // Placeholder last data packet being received.
volatile unsigned long read_Buffer[] = {0,0};             // Placeholder last full data packet read.
volatile byte isrFlags = 0;                               // Various flag bits
void PinChangeISR0(){                                     // Pin 2 (Interrupt 0) service routine
  unsigned long Time = micros();                          // Get current time
  if (digitalRead(2) == LOW) {
// Falling edge
    if (Time > (rise_Time + glitch_Length)) {
// Not a glitch
      Time = micros() - fall_Time;                        // Subtract last falling edge to get pulse time.
      if (bitRead(build_Buffer[1],31) == 1)
        bitSet(isrFlags, F_CARRY_BIT);
        bitClear(isrFlags, F_CARRY_BIT);
      if (bitRead(isrFlags, F_STATE) == 1) {
// Looking for Data
        if ((Time > bit0_MIN) && (Time < bit0_MAX)) {
// 0 bit
          build_Buffer[1] = build_Buffer[1] << 1;
          build_Buffer[0] = build_Buffer[0] << 1;
          if (bitRead(isrFlags,F_CARRY_BIT) == 1)
            bitSet(build_Buffer[0],0);
          bit_Count++;
        else if ((Time > bit1_MIN) && (Time < bit1_MAX)) {
// 1 bit
          bitSet(build_Buffer[1],0);
          bit_Count++;
        else {
// Not a 0 or 1 bit so restart data build and check if it's a sync?
          bit_Count = 0;
          build_Buffer[0] = 0;
          build_Buffer[1] = 0;
          bitClear(isrFlags, F_GOOD_DATA);                // Signal data reads dont' match
          bitClear(isrFlags, F_STATE);                    // Set looking for Sync mode
          if ((Time > sync_MIN) && (Time < sync_MAX)) {
            // Sync length okay
            bitSet(isrFlags, F_STATE);                    // Set data mode
        if (bit_Count >= allDataBits) {
// All bits arrived
          bitClear(isrFlags, F_GOOD_DATA);                // Assume data reads don't match
          if (build_Buffer[0] == read_Buffer[0]) {
            if (build_Buffer[1] == read_Buffer[1])
              bitSet(isrFlags, F_GOOD_DATA);              // Set data reads match
          read_Buffer[0] = build_Buffer[0];
          read_Buffer[1] = build_Buffer[1];
          bitSet(isrFlags, F_HAVE_DATA);                  // Set data available
digitalWrite(13,HIGH); // Used for debugging
          bit_Count = 0;
      else {
// Looking for sync
// Sync length okay
          bit_Count = 0;
digitalWrite(13,LOW); // Used for debugging
      fall_Time = micros();                               // Store fall time
  else {
// Rising edge
    if (Time > (fall_Time + glitch_Length)) {
      // Not a glitch
      rise_Time = Time;                                   // Store rise time
pinMode(13,OUTPUT); // Used for debugging
  pinMode(2,INPUT);
  Serial.println(F("ISR Pin 2 Configured For Input."));
  attachInterrupt(0,PinChangeISR0,CHANGE);
  Serial.println(F("Pin 2 ISR Function Attached. Here we go."));
  unsigned long myData0 = 0;
  unsigned long myData1 = 0;
  if (bitRead(isrFlags,F_GOOD_DATA) == 1)
    // We have at least 2 consecutive matching reads
    myData0 = read_Buffer[0]; // Read the data spread over 2x 32 variables
    myData1 = read_Buffer[1];
    bitClear(isrFlags,F_HAVE_DATA); // Flag we have read the data
    dec2binLong(myData0,DataBits0);
    dec2binLong(myData1,DataBits1);
    Serial.print(" - Battery=");
    byte H = (myData1 >> 26) & 0x3;   // Get Battery
    Serial.print(H);
    Serial.print(" Channel=");
    H = ((myData1 >> 24) & 0x3) + 1;        // Get Channel
    Serial.print(H);
    Serial.print(" Temperature=");
    byte ML = (myData1 >> 12) & 0xF0; // Get MMMM
//     Serial.print(" (M=");
//     Serial.print(ML);
    H = (myData1 >> 12) & 0xF;        // Get LLLL
//     Serial.print(" L=");
//     Serial.print(H);
    ML = ML | H;                      // OR MMMM & LLLL nibbles together
    H = (myData1 >> 20) & 0xF;        // Get HHHH
//     Serial.print(" H=");
//     Serial.print(H);
//     Serial.print(" T= ");
    byte HH = 0;
    if((myData1 >> 23) & 0x1 == 1) //23 bit
         HH = 0xF;
    int Temperature = (H << 8)|(HH << 12) | ML;  // Combine HHHH MMMMLLLL
//     Serial.print( Temperature);
//     Serial.print(") ");
    // Temperature = Temperature*3; //F // Remove Constant offset
    Serial.print(Temperature/10.0,1);
    Serial.print("C Humidity=");
    H = (myData1 >> 0) & 0xF0;        // Get HHHH
//     Serial.print(" (H=");
//     Serial.print(H);
    ML = (myData1 >> 0) & 0xF;       // Get LLLL
    ML = ML | H;                      // OR HHHH & LLLL nibbles together
    Serial.print(ML);
    Serial.println("%");
  delay(100);
void dec2binLong(unsigned long myNum, byte NumberOfBits) {
  if (NumberOfBits <= 32){
    myNum = myNum << (32 - NumberOfBits);
    for (int i=0; i<NumberOfBits; i++) {
      if (bitRead(myNum,31) == 1)
      Serial.print("1");
      Serial.print("0");
      myNum = myNum << 1;
The sensor look like to this sensor, but
station bought in China from an unknown manufacturer.
namezero
hello,
any tried to send same values ? here you dumped the data sent by sensor, but did you tried to emit data at the same way?
usefull to add sensor, a DHT on an arduino that send in the same protocol
LukasD
#63
Dec 09, 2016, 12:38 pm Last Edit: Dec 12, 2016, 09:05 am by LukasD
Could you someone to remake the code to be anrduio as a transmitter for weather station. Nonetheless, the code is decoded so well.
This is not working, help someone with it?
I'd like to show on the weather station SENCOR SWS 60 (transmitter SWS THS).
Code: [Select]
    A   B                 A   B          A   B
     _a_   c.............. _a_   c....... _a_   c... ___
 ___|   |_________________|   |__________|   |______|   |
         Synchronising        Logic 1        Logic 0
    m   n                 o   p          q   r      s
int TxPin = 13;
// Constants in micro seconds
const unsigned long sync = 8320; //8600
const unsigned long logic1 = 4500; //4300
const unsigned long logic0 = 2530; //1800
const unsigned long blip_length = 300; //430                 // Anything below this value is a glitch and will be ignored.
byte data_bytes[36] = {1,0,0,0,1,0,1,1,1,0,0,0,0,0,0,0,1,1,1,0,1,0,0,1,1,1,1,1,0,0,1,0,1,0,1,1};
boolean last_transmit = false;  //if last transmit (8); cut last 4bits - not needed for this temperature
  pinMode(TxPin,OUTPUT);
  for (int x = 0; x < 8; x++) {    repeatings of sending temperature  //<8
    if (x == 7) {
      last_transmit = true;
    synch();
    for (int i = 0; i < 36; i++) {  //reading and sending bits of temerature; 36 = length of bit stream
      //Serial.print(data_bytes[i]);
      //Serial.println(i);
      switch (data_bytes[i]) {
        case 0:
          logic_0();
        case 1:
          logic_1();
      } //end switch
      /*// this temperature doesn't need this
      if ((last_transmit) && (i == 23)) {  //last transmit doesn't have last 4 bits; so skip them
        i = 28;
      } //end if
    } //end for i
    //Serial.println();
  } //end for x
  if (last_transmit) {  //just stop sending
    delay(4000);
    Serial.println("pauza");
} //end loop
//n - o
void synch() {
  blip();
  delayMicroseconds(sync);
//p - q
void logic_1() {
  blip();
  delayMicroseconds(logic1);
  Serial.print(1);
//t - s
void logic_0() {
  blip();
  delayMicroseconds(logic0);
  Serial.print(0);
//a
void blip() {
  digitalWrite(TxPin, HIGH);
  delayMicroseconds(blip_length);
  digitalWrite(TxPin,LOW);
LukasD
#64
Dec 13, 2016, 12:53 pm Last Edit: Dec 13, 2016, 01:58 pm by LukasD
I have a solution for transmitting the signal to the weather station. I have conducted its analysis using a sound card and measured times.
Here's how it works transmitting (sensor sws TSH):
glitch Length = 500us   (a)
sync            = 3870us  (b)
logic1          = 1900us  (c)
logic0          = 1000us  (d)
example: byte data_bytes[36] = {1,1,1,0,1,0,0,0,1,0,1,0,0,0,0,0,1,1,0,0,1,1,1,0,1,1,1,1,0,0,1,0,1,0,1,1}; // SWS TSH, Battery=2 Channel=3 Temperature=20.6C Humidity=43%
And here are data for sensor sws TS:
sync            = 9250us  (b)
logic1          = 3950us  (c)
logic0          = 2000us  (d)
example: byte data_bytes[36] = {0,1,0,1,1,0,0,1,1,1,1,0,1,1,0,0,0,0,0,0,1,1,1,0,0,1,1,0,0,0,0,1,0,0,1,0}; // SWS TS, Channel=1 Temperature=23C
Code: [Select]
     _a_         b         _a_      c     _a_    d   ___
links:
https://www.laser.com/dhouston/learn.html
https://n8henrie.com/2014/09/macbook-pro-sound-card-audacity-oscilloscope/
https://rayshobby.net/interface-with-remote-power-sockets-final-version/
WEBcast
Code: [Select]
// __           ___       ___    ___
//   |  Sync      |    1    |  0   |
// Defines
// Constants
// Falling edge
// Not a glitch
// Looking for Data
// 0 bit
          bit_Count++;
// 1 bit
          bit_Count++;
        else {
          bit_Count = 0;
            // Sync length okay
// All bits arrived
          bit_Count = 0;
      else {
// Looking for sync
// Sync length okay
          bit_Count = 0;
  else {
// Rising edge
      // Not a glitch
  pinMode(2,INPUT);
    Serial.print(H);
    Serial.print(H);
//     Serial.print(H);
//     Serial.print(H);
    byte HH = 0;
         HH = 0xF;
//     Serial.print(H);
    Serial.print(ML);
  delay(100);
      Serial.print("1");
      Serial.print("0");
      myNum = myNum << 1;
This code works just fine with my Digi-Tech GMBH (they pretend to be German manufacturer :) Outdoor Sensor SEMPERE 4-AM102216-T1, 02/2016 BARCODE 24729024 PLU 47506
