Topic: Double Blink (Read 3085 times) previous topic - next topic
Sploosh
Ahoy there! A newbie here, just playing around with Arduino for the first time. I'm trying to figure out how to make my LED double blink, kind of like a heartbeat? Please could anyone show me how to do that, or put me in the right direction?
Thanks for any help you can give! I posted the code below.
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
djjoshuad
This probably belongs in a different forum, but here's your answer:
replace this:
Code: [Select]
with this:
Code: [Select]
  delay(400);               // wait for 400ms
  delay(100);               // wait for 100ms
  delay(500);               // wait for 500ms
This particular pattern will blink twice within one second (with the second blink slightly longer than the first, like a heartbeat), then be off for a full second.  I haven't tested it but it should be pretty close to a heartbeat style blink.  Just play with the delays until you get the pattern you want.  Enjoy!
