Topic: Change shiftOut() Clock Speed (Read 3684 times) previous topic - next topic
tms8c8
Jan 15, 2013, 06:30 pm Last Edit: Jan 15, 2013, 06:32 pm by tms8c8 Reason: 1
I've put the following code in my sketch to speed up the shiftOut() function. I'm using the typical MC74HC595 shift register but the maximum  clock frequency for my application is (conservatively) 4 MHz. If my code works, my clock frequency will be considerably faster (see thread below - I'm using Stimmer's code; it takes about 24 nS to write a pin high). I need a "delay" of say ... 250 nS between each clock write cycle. So ... can I modify an existing (e.g. micros()) or write my own function to have better 100 nS resolution? Or a better way to accomplish what I want?
Code: [Select]
inline void digitalWriteDirect(int pin, boolean val){
 if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
 else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
inline int digitalReadDirect(int pin){
 return !!(g_APinDescription[pin].pPort -> PIO_PDSR & g_APinDescription[pin].ulPin);
//High speed shift register function
void shiftOutFast( uint32_t ulDataPin, uint32_t ulClockPin, uint32_t ulBitOrder, uint32_t ulVal )
 uint8_t i ;
 for ( i=0 ; i < 8 ; i++ ){
   if ( ulBitOrder == LSBFIRST ){
     digitalWriteDirect( ulDataPin, !!(ulVal & (1 << i)) );
   else{
     digitalWriteDirect( ulDataPin, !!(ulVal & (1 << (7 - i))) );
   digitalWriteDirect( ulClockPin, HIGH );
    //need to delay 200 nS
   digitalWriteDirect( ulClockPin, LOW );
http://arduino.cc/forum/index.php/topic,129868.15.html
CrossRoads
#1
Jan 15, 2013, 07:14 pm Last Edit: Jan 15, 2013, 10:16 pm by CrossRoads Reason: 1
I think the best you can do is use SPI.transfer( ) instead of shiftclk( ).
There are some clock divisors you can use, fastest is 1/2 processor clock speed, or 133nS.
http://arduino.cc/en/Reference/SPI
[Edit - right answer, wrong processor]
stimmer
Here's a useful macro:
Code: [Select]
#define MNOP(x) asm volatile (" .rept " #x "\n\t nop \n\t .endr \n\t")
It outputs nop instructions - each nop wastes approx. 1 clock cycle which is about 12nS. So use MNOP(16); for about 200nS.
Beware that doing delays this way isn't very deterministic, you might find that you add a line somewhere completely different in the code and it changes the length of the delay!
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
CrossRoads
How is 1 clock cycle 12nS when  ...
Ah, never mind, didnt realize this was a Due question.
tms8c8
Code: [Select]
Thanks Stimmer. Saved me twice today! The digitalWriteDirect() is super handy and the MNOP is exactly what I needed.
