Topic: Why no byte I/O? (Read 1 time) previous topic - next topic
jontitus
I'm mystified about why the Arduino API doesn't include easy commands to control individual byte-wide I/O ports?  Don't people need to control several bits simultaneously rather than twiddle bits individually?  I don't mind reading the Atmel data books to find info about control registers, shared pins, and so on, but how do I send a byte to a register to control a byte-wide port if there's no register-control operation?  Apologies if I have missed something obvious. --Jon (potential Arduino Due user)
Delta_G
The sad thing on the 328 is that none of the registers are 8 pins wide.  So if you need to parallel in a whole byte it will take at least two registers, a bitshift, an OR operation, and most likely a couple of ANDs.
If at first you don't succeed, up - home - sudo - enter.
Msquare
The sad thing is none of the ports are 1 bit wide. You have to read and mask and so on. ;)
retrolefty
Port D is a full byte wide in the 328 isn't it?
https://spreadsheets.google.com/pub?key=rtHw_R6eVL140KS9_G8GPkA&gid=0
Lefty
majenko
Lefty
So is port B, but two are normally used for the crystal.
The Arduino doesn't need to provide facilities to deal with a whole byte I/O as the chip does it for you, using the PORTB or PORTD Special Function Registers.
krupski
Not true. PORTD is UNO pins 7 thru 0. Granted, using pins 1 and 0 screws up serial communications, but an 8 bit full port IS available if needed.
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
michinyon
Nobody seems to be interested in traditional parallel communications anymore,   and there doesn't seem
to be much call for it.
majenko
That's because serial communications is so fast now, and parallel communications just takes up too much room.
The only place now in a modern PC where parallel communication is "normal", is in the memory, and that is a mixture of parallel and serial (DDR, etc).
krupski
Try interfacing to a graphics LED or LCD to a microcontroller. Serial interface is so slow you can watch the pixels pour onto the screen - one at a time.
AWOL
Which do you want to give up?
Fast updates, or at least nine nine of your precious pins?
krupski
Depends on what I'm doing. If I need decent graphics performance, I'll use the pins......
AWOL
If I need decent graphics performance, I don't use a slow microcontroller.  :)
krupski
LOL! We can go back and forth on this all day.......
majenko
If I need decent graphics performance, I use a PIC24FJ256DA210 - it has 3 built-in graphics co-processors and a dedicated LCD / TFT interface.
