Loading...
Pages: [1]   Go Down
Author Topic: Floating Point Co-Processor  (Read 1884 times)
Kansas City, MO
Offline Offline
Jr. Member
View Profile
I ran across this device that provides a 64 /32 bit floating point co-processor for arduino. No sure if this is needed, but I thought the scientific measurement forum might be the place to post the links.
product page:
http://micromegacorp.com/products.html
datasheet and other info arduino related info attached
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Thanks!
Is a known device, Nick Gammon did some testing with the 32 bit nephew of this FPU.
See - http://arduino.cc/forum/index.php/topic,101298 -
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
God Member
View Profile
I have the 32-bit one. IMHO it isn't really useful for a 16MHz Arduino. IIRC the FPU is based on a processor whose clock is only twice as fast as the Arduino and it doesn't have floating point hardware. The thing that kills it is the amount of time required to send your data to the FPU and then get the results back. If you want to offload some computations while the Arduino does something else it might be useful.
Before you buy one read the instruction timings in the data sheet, figure out how much data you have to shovel in and out and decided whether it will save you any time.
[addendum]
I should mention that it has several features that I haven't used. For example the NMEA sentence parser and 2 12-bit A/D converters
Pete
« Last Edit: January 15, 2013, 06:25:14 pm by el_supremo » Logged
Offline Offline
God Member
View Profile
I came to the same conclusion,  and figured out it was better to get a faster computer with floating point in it.
Logged
Offline Offline
God Member
View Profile
Yep, or even just a faster computer without floating point hardware. The fpu emulation might be fast enough that some apps will work without fpu hardware.
Pete
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
So that would make it useful when doing some geo-math on coordinates (e.g. distance to some point calculation involves gonio)
or for analog sensors that need some math formula applied e.g. thermistors that need some 3rd degree non linear formula.
or an FFT on 2 audio channels or ...
IN short as a preprocessor before sending the data to a duino.
Logged
Rob Tillaart
Offline Offline
God Member
View Profile
Yes,  but I don't think it is very easy to organise it as a preprocessor between some device
and the arduino.   Unless you had two arduinos,   and one of them was there just
to manage the input and output of this device.
Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
If it can do large FFT's the time saved may justify the communication overhead. If it can be programmed with user code, then it could be left alone for a while doing an expensive task of any kind.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Yes,  but I don't think it is very easy to organise it as a preprocessor between some device and the arduino.
Why not? OK maybe for some,  but the FPU has autonomous inputs serial?
Logged
Rob Tillaart
Offline Offline
God Member
View Profile
Well I read the instructions several times and it didn't seem very clear to me.  Perhaps I should
actually obtain one and get it to work.
Logged
Pages: [1]   Go Up
Print
Jump to:
