Loading...
Pages: 1 [2]   Go Down
Author Topic: changing clock/date setting on Real Time Clock pcf8563 [solved]  (Read 570 times)
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Think about what value min has in the changeTime function just before rtc.setTime(hour, min,sec)
Looks to me that it will always be 20.
Is that what you want or do you want it to be the value you set it to by pressing the button ?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
On each pass through loop(), you are testing whether the switch connected to minButton is pressed. If it is, you set the time to 5:30:14, then increment the min variable and return.
You need to move the local variables hour, min, and sec from the function to global space.
Then, you need to call setTime AFTER incrementing min.
Logged
London-UK
Offline Offline
Jr. Member
View Profile
Thanks to all. I have it working now.
This last bit solved the issue.
Karma awarded.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
