Author Topic: How to read analog 0-24V signal  (Read 348 times)
Hi.
I need to read a 0-24V signal or 0-100V. I know how to reduce the voltage using a voltage divider, but is it possible to reduce voltage in some other way, so i can feed the signal to a 5V inputpin.
In other words, I want to convert a 0-24V signal to 0-5V signal.
Montreal
Per aspera ad astra.
Resistor divider the easiest and cheapest way to reduce a voltage. If you need galvanic isolation between two circuits than look here:
http://ruggedcircuits.com/html/circuit__24.html
There are also some special made IC to measure high side voltage, do a search for BMS ( battery management system ) for example.
Valencia, Spain
A voltage divider with two resistors is best/easiest/cheapest.
No, I don't answer questions sent in private messages...
