Loading...
Pages: [1]   Go Down
Author Topic: Math.h log10 function bug? [not a bug finally]  (Read 895 times)
Offline Offline
Newbie
View Profile
I'm developing with the Arduino UNO a device that uses a TSL238 light-to-frequency photodiode to measure light.
Just because in astronomy the 'standard' is a negative logaritmic one unit, I use log10 function (from math.h) here to pass from Hz (output of the TSL237, measured with pulseIn as the pulses are pretty slow for FreqCounter and FreqPeriod) to the logaritmic unit system with an offset of 22.0 .
magnitude = 22.0-2.5*log10(frq);
But something isn't ok with that simple operation.
1.03hz => 21.970mag
1.01hz => 21.994mag (that's OK, decreasing frequency means higher magnitude)
0.92hz => 22.91 (that doesn't seem to be correct. I expected 22.091)
0.91hz => 22.98 (also incorrect!)
0.78hz => 22.272 (correct!)
0.64hz => 22.480 (correct!)
What is wrong in the 22.0-2.5*log10(0.92) and 22.0-2.5*log10(0.91) ?
Update. Maybe it's losing a digit between . and 9?. I mean 22.091 and 22.098 sounds pretty accurate. I'm using the printDouble function from here: http://www.getbugged.com/2008/11/22/how-to-serialprint-a-double-on-an-arduino/ (original version wrote by Mem here in the Arduino forums, http://arduino.cc/forum/index.php/topic,44216.0.html) to get a bit more decimals.
Thanks in advance,
Minaya
« Last Edit: January 15, 2013, 07:08:30 pm by minaya » Logged
Offline Offline
Newbie
View Profile
I'm pretty sure it's a bug in printDouble function (at least in the version I used).
I've simulated it in python
Code:
import sys
val = float(sys.argv[1]);
precision = int(sys.argv[2])
sys.stdout.write(str(int(val)))
sys.stdout.write('.')
if val>0:
frac = (val-int(val))*precision
else:
frac = (int(val)-val)*precision
frac1 = frac
while (frac1/10!=0):
frac1 = frac1/10
if frac1!=0:
precision=precision/10
while (precision/10!=0):
precision = precision/10
sys.stdout.write('0')
sys.stdout.write(str(int(frac))+'\n')
If I write python buggyprintDouble.py 1.057 1000 it says 1.56,
but 1.157 1000 says 1.157
My first try to fix it,
Code:
import sys
if val>0:
else:
lfact = 10
while int(lfact*(val-int(val)))==0 and lfact<precision:
lfact*=10
frac1 = frac
frac1 = frac1/10
if frac1!=0:
That's, commet the while(precision/10!=0) bucle and add before a custom lfact correction (just for printing the left zeros).
Now python newprintDouble 1.057 1000 says 1.056 and python newprintDouble 1.157 1000 says 1.057.
Lets traslate it to C++  smiley-cool
« Last Edit: January 15, 2013, 07:08:09 pm by minaya » Logged
Offline Offline
Newbie
View Profile
Based on the last version published by mem (which uses byte precision)
Code:
void printDouble( double val, byte precision){
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimial places
  // example: printDouble( 3.1415, 2); // prints 3.14 (two decimal places)
  Serial.print (int(val));  //prints the int part
  if( precision > 0) {
    Serial.print("."); // print the decimal point
    unsigned long frac;
    unsigned long mult = 1;
    byte padding = precision -1;
    while(precision--)
       mult *=10;
    if(val >= 0)
      frac = (val - int(val)) * mult;
      frac = (int(val)- val ) * mult;
    unsigned long lfact = 10;
    while(int(lfact*(val-int(val)))==0 && lfact<mult){
      lfact *= 10;
      Serial.print("0");
    unsigned long frac1 = frac;
    while( frac1 /= 10 )
      padding--;
    Serial.print(frac,DEC) ;
I need to test extensively, but the first measures seems to be pretty ok.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
It seems to be losing at least the first leading zero of the decimal part.
In Arduino you can use:  Serial.println(floatnumber, decimalplaces);   e.g. Serial.print(3.14159265, 3);
afaik it works correctly...
can you give it a try in your sketch?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
It's working as expected with print(...,3) robtillaart.
Thanks!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Can you post the final sketch? for future reference?
What you may like is the number always to be 4 digits e.g.  12.12 but 1.212
Code:
Serial.print(mag, mag<10?3:2);  // using an if then else construct (the cryptic one) to determine the #digits.
which is functional equivalent to
Code:
if (mag<10) Serial.print(mag, 3);
else Serial.print(mag, 2);
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
