Topic: COnvert const char to hex (Read 3283 times) previous topic - next topic
eriknyquist
Dude. post some code. for God's sake.
if you actually are sending Xbee commands in the format you speficied in your last comment-
Quote
XBee.println(ATKYWORD);
Then that's wrong. I can't speak from personal experience as I have never used an XBee, but I've used a couple of other arduino shields that recieve AT commands (3G shield, cell shield) and I know that those commands have to be enclosed in quotes within the serial.println command
i.e.
Code: [Select]
XBee.println("ATKYWORD");
nid69ita
So, you can write
#define ATCMD "ATxxx"
XBee.println(ATCMD);
and if a password is required as HEX you can write in define as hex
#define ATPWD "0A5E86"
XBee.println(ATPWD);
my name is IGOR, not AIGOR
Suriken
nid69ita your code works well. Just have some fails if you use number instead characters for password, something like this: "password11". I will try to solve it. Thank you.
I wrote XBee.println(ATKYWORD);, I already know it fails because it has not enclosure for ATKYWORD.
I have no problems to write password in define in hexadecimal but my program will be use by people who doesn't know what hexadecimal is, so I cannot do that. They can be able to write a word as their password and after that, program will convert it.
I have all my commands in defines so ATKY represents "atky" actually. WORD will be the password... I just meaned the way commands are sent to XBee.
I didn't post code just because I didn't have any code for that. I was trying to convert the sentence to start to do a function for that but I haven't the program yet.
Thank you.
nid69ita
Problem can be implicit conversion made by compiler.
Try with password with also number, like ABC123
Then add a simple Serial.println(c);
Code: [Select]
#include <stdio.h>  // for sprintf
MySend(WORD);    // c compiler see   MySend("textToConvert");
void MySend(char *pWord)
{ char buf[2];
  for(int i=0;i<=strlen(pWORD);i++)
  {  char c=*(pWord+i);  // single ascii value
     Serial.println(c);
     sprintf(buf,"%0x",c);// convert ascii value in hex
     obj.SendByte(buf[0]);    // I don't know command for send byte to xbee but I think you can send byte
     obj.SendByte(buf[1]);
If you see problems when show one numeric char, try using unsigned char or unsigned byte or also unsigned int.
Sample on internet about sprintf use only integer value.
Suriken
Nid69ita, I solved deleting '=' before strlen(pWord). Maybe it helps others...
