Topic: Playing simultaneous tones? (Read 6501 times) previous topic - next topic
wherewolfe
Hello-
I am working on a song with multiple buzzers and I've downloaded a library that allows me to play two simultaneous tones:
https://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
According to their manual, my Uno r3 should be able to play 3 simultaneous tones, since it has an ATmega328 chip, with three internal timers. My friend told me that one of these timers is a system timer, and it cannot be used for anything except for system processes. Is there any way around this while (preferably) still using the above mentioned library?
I already know of a couple libraries in which I can play several simultaneous tones by "hacking" one of the internal timers:
http://www.jeremyblum.com/2010/09/05/driving-5-speakers-simultaneously-with-an-arduino/
and
http://sealedabstract.com/code/bassdll-an-arduino-piezo-music-library/
However, both of these seem especially confusing, and I'd rather know what I'm working with before using it. I would also be OK if someone told me how to use these libraries, and what are the different things I can do with it.
Thanks!
cr0sh
I can't really tell whether these guy's are using multiple speakers on different pins or what - are they? If so, why?
Why not a single speaker, and a simple audio mixer?
PeterH
The timer interrupt approach described in 'driving-5-speakers-simultaneously-with-an-arduino' seems to be what you need.
If tone generation was all you wanted the sketch to do, and you don't need to generate very high frequencies, you might even be able to manage it just by polling micros() to check when it was time to toggle each output. This would use more processing power and not cope with as many outputs/as high frequencies as the interrupt based approach, but would be much easier to understand and get working. Essentially you'd use 'blink without delay' but using micros() instead of millis() to measure really short intervals.
I only provide help via the forum - please do not contact me for private consultancy.
wherewolfe
I am using three different speakers on three different pins. What's an audio mixer? (Sorry, I'm new)
This did seem like a viable solution, but the problem is that I can't understand a word of what he is saying. None of the variables are defined (I assume they are some sort of system variables), and he uses a bunch of bitwise operations that I don't understand. For using the micros() technique, how would I know which frequencies to play? I use notes in a range of an octave or two, so that might also be a factor.
As for tone generation being ALL I wanted to do, I was thinking of adding in some synchronized lights while the song was playing (if that's possible)
Thank you!
DuaneB
Why dont you just try the illutron synth ? You could output four voices/notes at a time through a single pin or two voices through two pins. The project will play a sequence which you can set by writting the midi note numbers into a file in the sketch.
It does lights as well -
http://www.youtube.com/watch?v=fTmLKKLv5cE
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
wherewolfe
I actually DID see the illutron synth thing, but I actually wanted to "do it myself", if using other people's libraries didn't count. Feeding the notes into another program didn't seem like much fun on my part.
Thanks for your input anyway!
CrossRoads
Does it have to be a library?
Or can you control NE555, NE556 chips that are setup as astable oscillators?
http://www.mouser.com/ds/2/389/CD00000479-103226.pdf
http://www.mouser.com/ds/2/389/CD00000480-103598.pdf
See figure 16 as one way to set it up - trigger a tone for a length of time.
Or replace the output of the first with the arduino output.
Set up as many oscillators as you want, use shift register outputs to control them.
Take all the tone outputs, run into a op-amp summing amplifier.
See NE555 Figure 15, use either waveform for different sounds.
cr0sh
Basically - it's a fairly simple circuit that allows you to combine multiple signals into a single signal - here's an article (you can find more on the net - just search for "audio mixer schematic"):
http://sound.westhost.com/articles/audio-mixing.htm
wherewolfe
Hello (sorry for the late response) :
I had considered using 556 timers, but it seemed a bit pricey, considering how my local electronics store prices each one at around $1.50, and I want to play a range of notes. The cheapest audio mixer also costs $30. This is out of my budget, and, in fact, I was actually looking for more of a software based approach. I think the most helpful feedback I could get right now would be if someone could explain the code in: http://www.jeremyblum.com/2010/09/05/driving-5-speakers-simultaneously-with-an-arduino/
If someone could explain what this does, how it works , and how I could use it, it would be really REALLY helpful.
Thanks!
CrossRoads
You can get DIP parts for 45 cents
http://www.mouser.com/ProductDetail/Texas-Instruments/NE556N/?qs=sGAEpiMZZMuHTYi1bHPYEC2zhCiQJdMm
and surface mount for 23 cents
http://www.mouser.com/ProductDetail/STMicroelectronics/NE556DT/?qs=sGAEpiMZZMtf0BNRzfLjAhLt9HcSj294
So $5 for 10 chips and some Rs & Cs and you have 20 'channels'
You don't need a $30 mixer - use an op-amp to make a summing amplifier to create the mixer.
http://masteringelectronicsdesign.com/how-to-derive-the-summing-amplifier-transfer-function/
Run that output into a power ampllifier to boost the sound level.
wherewolfe
Thank you- I will buy these shortly.
I still am curious - what exactly IS jeremy blum doing in http://www.jeremyblum.com/2010/09/05/driving-5-speakers-simultaneously-with-an-arduino/ Even though I probably won't need to ever use it, I still am interested in what his code would be doing, and how someone could use his code.
CrossRoads
I don't know, I usually glaze over trying to read someone else's code.
wherewolfe
LOL  :smiley-yell: Can anyone else help me out here?
DuaneB
   Its well explained in the link -
timer interrupt triggers every 64us and looks at a counter for each speaker to determine whether it needs to toggle the pin driving the speaker. Thats it.
Its very similar to the way the servo library allows you to drive 16 servos from a single timer - In fact I can't see why you could not drive 8 or more speakers, the code could easily be optimised using direct port manipulation to squeeze out some more perfomance.
Duane B
Read this
then watch this
wherewolfe
Thanks, DuaneB.
So if I were going to play more notes than the frequencies he has created, I would just add more count and toggle variables, and then add more if statements accordingly?
