Author Topic: My First Sketch: PWM Common Annode RGB Led 7 Color Generator  (Read 824 times)
I gave up electronics for programing, now they tell me I can program electronics...
I picked up my first Arduino and I am impressed with it's capabilities. Just thought I'd share my first sketch. It uses the common annode, full color LED, Radio Shack model # 276-028. I used three PWM outputs to fade out each of the 7 basic color combination that can be made with the RGB LED. I am sure this code could be done simpler but I had so much fun getting it to work so easily! I can't wait to think up more things to make!
// RGB 7 Color Fade Out Looper
// By: CLM3S
// Define LED Color Pin Outputs
int RedPin = 11;
int GreenPin = 10;
int BluePin = 9;
  // Fade Out Red
  for (int x=0; x<256; x=x+5) {
    analogWrite (RedPin, x);
    delay(10);
  // Clear All Colors
  analogWrite (RedPin, 255);
  analogWrite (GreenPin, 255);
  analogWrite (BluePin, 255);
  delay(25);
  // Fade Out Green
    analogWrite (GreenPin, x);
    delay(10);
  // Clear All Colors
  delay(25);
  // Fade Out Blue
    analogWrite (BluePin, x);
    delay(10);
  // Clear All Colors
  delay(25);
  // Fade Out Cyan
    delay(10);
  // Clear All Colors
  delay(25);
  // Fade Out Yellow
    delay(10);
  // Clear All Colors
  delay(25);
  // Fade Out Magenta
    delay(10);
  // Clear All Colors
  delay(25);
  // Fade Out White
    analogWrite (RedPin, (x / 2) + (256 - (256 / 2)));
    delay(10);
  // Clear All Colors
  delay(25);
Enjoy!  smiley
« Last Edit: January 17, 2013, 01:02:29 am by clm3s » Logged
Topsham, Vermont USA
... in The Woods In Vermont
Hi, Looks great..
May we use your schematic on the http://ArduinoInfo.Info WIKI??
The WIKI has this now: http://arduino-info.wikispaces.com/RGB-LED
I found that having the LED point up into a pingpong ball, or better a frosted plastic egg carton (or clear that you have sandpapered) makes the effect much more interesting.
Have fun!
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Boston Suburbs
I am above your silly so-called "Laws", Mister Ohm.
Great stuff!
Now, here's a challenge for you-  instead of the seven colors and fading them out individually-can you rewrite so that ALL colors the LED are capable of are shown?
HINT:  Nesting.....
When the testing is complete there will be... cake.
How about a really realistic flickering campfire  smiley
Norfolk UK
I think the LED's are the wrong way round in the drawing. They are shown as common cathode and it's connected to 5V.
In the inimitable words of Miss Piggy, "I Knew That!"..
@clm3s, can you fix that for us all?  Otherwise I'd have to FPS it (Fire Up Photoshop)...
WHOOPS! I should have known better! For shame on me...
I'll correct it as soon as I can. Thanks for the heads up!
 smiley-lol
EDIT: I updated the image and it should be visible above. Feel free to use it.
« Last Edit: January 17, 2013, 01:05:04 am by clm3s » Logged
Maine, USA
Try this code and tell me what you think smiley
int Cred, Cgreen, Cblue, Nred, Ngreen, Nblue;
int RedPin = 10;
int GreenPin = 11;
int BluePin = 9;
int low=15;
int high=256;
int del=10;
    randomSeed(analogRead(0));
    Cred=random(low,high);
    Cgreen=random(low,high);
    Cblue=random(low,high);
    Nred=random(low,high);
    Ngreen=random(low,high);
    Nblue=random(low,high);
    while(Cred!=Nred)
      if(Cred<Nred)
        Cred++;
        Cred--;
      analogWrite (RedPin, Cred);
      delay(del);
    while(Cgreen!=Ngreen)
      if(Cgreen<Ngreen)
        Cgreen++;
        Cgreen--;
      analogWrite (GreenPin, Cgreen);
      delay(del);
    while(Cblue!=Nblue)
      if(Cblue<Nblue)
        Cblue++;
        Cblue--;
      analogWrite (BluePin, Cblue);
      delay(del);
Moderator edit: [code] [/code] tags added.
« Last Edit: February 12, 2013, 02:08:44 am by Coding Badly » Logged
