Topic: Which library to use for 8x8 MAX7219 Blue LED module (Read 1 time) previous topic - next topic
mjkzz
Just finished building a few 8x8 Blue LED maxtrix driven by MAX7219, all hardware seems working perfectly now. But I am having hard time finding library for it, searching here yields mostly non-English posts.
I'd like to scroll it vertically and horizontally and it must support cascading because my hardware design support seamless cascading of more than one modules.
Thanks in advance.
www.mjkzz.com
www.pylin.com
Riva
If you have your matrix displays wired like this article http://playground.arduino.cc//Main/MAX72XXHardware then the LedControl library (http://playground.arduino.cc//Main/LedControl) will work with up to 8 chips. It does not do scrolling though so you will have to roll your own or use someone else's code. I have done scroll code to scroll right to left that's somewhere on this forum but have not seen multi directional scroll code.
mjkzz
#2
Jan 17, 2013, 02:37 am Last Edit: Jan 17, 2013, 02:39 am by mjkzz Reason: 1
Thank you very much, it was a success, or is it? I recorded a video running an unmodified example.
http://player.youku.com/player.php/sid/XNTAzMDI2MzUy/v.swf
www.mjkzz.com
www.pylin.com
Riva
First off I like the display matrix, where did you source a white/blue LED matrix as most seem to be red.
What code was you using to do the display as there seems to be a lot of flickering of pixels. Is this by design or due to some underlying problem?
mjkzz
These are custom made, cost about twice as much as red ones. In reality, they are actually much bluer than the video shows. The flickering is because of the video, in real world, they are much better than stimulating RED :-)
www.mjkzz.com
www.pylin.com
