Loading...
Pages: 1 ... 6 7 [8] 9 10   Go Down
Author Topic: Menu for Display  (Read 4491 times)
Offline Offline
Sr. Member
View Profile
Great Thanks you !
So, I did you this questions because this morning i was doing the final menu and one time that I've the third menu the has stop to work ... I've tried both in serial and on lcd ... removing this menu everything was working ok ... and my sketch is only 25000 I've avaiable again 8000 byte if i not wrong ... also taking another menu from an example is the same ...
do you have any suggest for fix it ?
thanks
gnux
Logged
Offline Offline
Sr. Member
View Profile
for sure the code seems correct ... I didn't see any big changes between the other only I've used 2 Label function ... so in 4 hour that im working on that I've tried a lot's of thing change variable type from u8int to char ... but nothing to do ... Now I go for launch because Im completely fuse ...
thanks for help me,
gnux
« Last Edit: February 21, 2013, 06:14:08 am by gnusso » Logged
Offline Offline
Sr. Member
View Profile
Also I've looked inside the tutorial for pass value to the call back procedure for M2_LABELFN I but I didn't find a way :-( so could be more useful :-) below you can find the code ...
if i try to pass parameter I've back a issues with the conversion for sure i wrong to pass it ...
Code:
const char *label_what(m2_rom_void_p element)
  switch (array[u8dev][13]) {
    case 0:
         label = "Bathroom";
    case 1:
          label = "Kitchen";
    case 2:
          label = "Garage";
  return  label;
M2_LABELFN(el_labefn2, "x10y3", label_what);
Thanks for your help,
gnux
Logged
Germany
Offline Offline
God Member
If you believe something is right, you won't see what's wrong (David Straker).
View Profile
Hi
I do not see the declaration of "label"
Did you try this?
Code:
    case 0: return "Bathroom";
    case 1: return "Kitchen";
    case 2: return "Garage";
  return  "";
Oliver
Logged
Offline Offline
Sr. Member
View Profile
Ciao Oliver :-) , so now it's ok I'm working directly on lcd ...maybe it's better ...this was the code that I've used :
Code:
const char *linebuf = "";
const char *label_cb(m2_rom_void_p element)
  switch (array[u8dev][12]) {
    case 0:
         linebuf = "TurnedOff";
    case 2:
          linebuf = "BadState";
    case 32:
          linebuf = "TurnedOn";
  return linebuf;
So, now I'd like to re-use the procedure above and pass like parameter "linebuf" is there a way to pass parameter ? I've tried but without success ...
I think it's possible, I've tried in several way but I've issues in "M2_LABELFN(el_labefn2, "x10y3", label_what);"
Thanks for the support,
have nice week end,
Gnux
Logged
Germany
Offline Offline
God Member
View Profile
Hi
You can not change the prototype for the callback procedure. So, you can not pass additional arguments. You need to use global variables.
Sure, this is not a good programming style...
Oliver
Logged
Offline Offline
Sr. Member
View Profile
No problem :-) was just investigating for optimize at the top my code ... right now I'm using 28.200 byte on 32000 available ... :-) I need to look your link that you have sent to me in order to understand how to put the global variable in SRAM in order to use all Flash Memory for the program :-) I think that after that i will manage correctly my at328pu ... make sense for you ?
So, in a previous post you was mentioning this :
"You can calculate the amount of initially occupied RAM and ROM memory.
Use "avr-size" for this task. You need to locate and find the .elf file on your file system."
I've found .elf file for my sketch now is there a software to download for see how are located the variable ?
because looking the documentation it's a little bit difficult to understand sorry... i need to be little bit confident with it like did for display library :-) ... anyway i will try to read again ...
Gnux
« Last Edit: February 23, 2013, 08:49:27 am by gnusso » Logged
Germany
Offline Offline
God Member
View Profile
Hi
avr-size should be part of the Arduino Distribution:
./hardware/tools/avr/bin/avr-size
Oliver
Logged
Offline Offline
Sr. Member
View Profile
Ciao Oliver in attachment the result :-)
I need to understand now this data ... are express in byte ?
Which is the maximum limit that I've have ? So I would like to understand if I've use correctly the space for the program memory and the space for the variable ...
thanks for the information,
Gnux
Logged
Germany
Offline Offline
God Member
View Profile
Hi
text    data     bss     dec     hex filename
27502      698     1078    29278    1da5 spacetrash.elf
Flash-ROM (PROGMEM) size: 27502 + 698 : This must be lower than 2^15
Required RAM: 698 + 1078 + stack : This must be lower than 2048
The problem is the required stack size. It can not be calculated, but i guess it is around 200 Bytes or more.
Oliver
Logged
Offline Offline
Sr. Member
View Profile
Hi Oliver thanks for this first explanation very useful ...
looking my avr-size result if I not understood bad kindly correct me if i wrong :-):
  27502       698      1078     29278      725e   FinalRinse.cpp.elf
 a) .text: is said the Software Code without Variable (function, case, loop,setup, cicles etc etc) - Maximum
     size - 32.000 byte
 b) .data: is said the space for variable (SRAM) that the maximum size is ?
 c) .bss: is said the space for variable (SRAM) that the maximum size is ?
 SRAM for Atmega328 is 2000 bytes --> correct ?
 d) .dex: is the sum of a + b + c in decimal
 e) .hex: is d in hex
Then:
Flash-ROM(PROGMEM) size = text + bss = 27502 + 698 = 28.200 bytes must be < 2^15 = 28.200 < 32.000 --> it's ok
Required SRAM: (.data + .bss + stack) < 2048 = 698 + 1078 + 200 =   1976 < 2048 --> I'm at the limit of Ram used.
Is there a way for see which variable are into .data memory and which into .bss zone and in my case moving the variable that are into .data zones into the .bss zone I could use the space for the code correct ?
Sorry if I have specified point to point but I think is better way to understand, so then you are very good teacher :-) thanks you again,
gnux
« Last Edit: February 24, 2013, 02:04:53 am by gnusso » Logged
Germany
Offline Offline
God Member
View Profile
Hi
We are leaving the area of menu programming, my knowledge is not that good here, but i do my best to answer this question.
Quote
     size - 32.000 byte
Flash-ROM is the code size including variables which have none-zero init values.
.text is the value for the the pure code
Quote
.data is the size of the variables which have none-zero default value such as "int x = 4;"
This value counts against flash-rom AND ram (SRAM) area size.
Quote
This is the size of those variables, which have a zero default value, such as "int y = 0;"
The stack size is not listed here, because it grows during runtime.
Conclusion for overall memory consumption:
Flash-Rom = .text + .data
SRAM = .data + .bss + stack
Quote
Well yes, the datasheet will be a more reliable source, but if i remember correctly then it is 2048.
Quote
You took the right numbers, but your text is wrong: "size = text + data"
Quote
Yes, i think so too. Especially i do not know if stack needs 100, 200 or 300 bytes.
If you need a precise answer, you will need tools like this: http://www.absint.com/stackanalyzer/index.htm
You can also do a runtime analysis by your own. I found the following threads also:
This is a nice idea for fully automatic runtime calculation:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=52249
This also has several links and lot of information:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=78518
Have fun,
Oliver
« Last Edit: February 24, 2013, 02:54:31 am by olikraus » Logged
Offline Offline
Sr. Member
View Profile
Thanks Oliver for the Information,
with you I've learned a lot of things :-) ... So, I think that very soon I will pass to Arduino Mega 2560 because the menu is very useful and I will introduce more menu ...
What I was thinking for the future is use another kind of Display (maybe touch) to use with your great library ...
So from your experience could you kindly advise me, which kind of display to use ?
thanks again for your support :-) !
Gnux
Logged
Germany
Offline Offline
God Member
View Profile
Which display? Well i like graphics displays. ST7565 based display are usually a good choice, because you can use 4 wire SPI. Unfortunately they can not be connected directly to a 5V board like the Arduino Uno or Mega (level translation needed).
Oliver
Logged
Offline Offline
Sr. Member
View Profile
It's nice ! and give you a lot's of choice vs lcd 20 x 4 :-) ... the power is not a big issues because I've another circuit that give power to lcd ... the important thing that is possible to work with your library ... :-) because now that I've understand the logical... :-)
Thanks you :-)
gnux
Logged
Pages: 1 ... 6 7 [8] 9 10   Go Up
Print
Jump to:
