« Reply #30 on: January 20, 2013, 01:04:40 pm » |
Yes for sure :-) Thanks a lots ...
The other good question for you will be :-)
- If i need print something like data and time (now printed in serial) how I can do ? I can print directly on lcd ? this is a general question for example a result of procedure or something else ...
- for example another idea for menu that i've in mind is:
- Device --> choose number of device (maybe i can take a part of general serial example). example led --> Turn On/Off --> Get state and print in serial on lcd
- Timer --> choose number of device ((maybe i can take a part of general serial example) --> Enable/Disable Timer if enable --> set start time start date and end time and end date if disable --> disable timer
but this part i think will be a little bit difficult because i need to implement a timer again ... so I've looked and found some documentation but after im stopped because i start to work on menu :-) ...
warm regards, gnux
thanks
Germany
If you believe something is right, you won't see what's wrong (David Straker).
« Reply #31 on: January 20, 2013, 04:44:27 pm » |
To print the menu on the LCD, just replace the serial graphics handler with the graphics handler for the character lcd. In order to show something, you could design a menu, with read only fields and only one selectable ok button. Any element can made "read only" by adding "r1" to the format string, so M2_U8NUM(el_dt_year, "c2r1", 0,99,&dt_year); M2_LABEL(el_dt_sep1, "b1", "-"); M2_U8NUM(el_dt_month, "c2r1", 1,12,&dt_month); M2_LABEL(el_dt_sep2, "b1", "-"); M2_U8NUM(el_dt_day, "c2r1", 1,31,&dt_day); will show the date but will not allow to enter any data (M2_LABEL is always read only). Of course you can also write directly to the LCD screen, no problem. Tutorial 6 might give a some ideas here ( http://code.google.com/p/m2tklib/wiki/t06glcd) Oliver
« Reply #32 on: January 21, 2013, 03:39:09 am » |
Ok if i not understood bad just change this " m2_es_arduino_serial" with this " m2_es_arduino" in order to enable enable the menu in LCD mode ...
then did this your advise is create a read only menu with only ok button ...
I will try and then I'll you know :-)
have nice a week, Andrea
« Reply #33 on: January 21, 2013, 04:59:42 am » |
Hi Oliver, I've create another items on the menu uint8_t u8dev = 0; uint8_t u8stato = 0;
void fn_clean_dev(m2_el_fnarg_p fnarg) { u8dev = 0; }
void dev_ok_button(m2_el_fnarg_p fnarg) { Serial.println("OK"); }
M2_LABEL(el_num_label1, NULL, "Select Dev:"); M2_U8NUM(el_num_1, NULL, 0, 64, &u8dev);
M2_LABEL(el_num_label2,NULL, "Turn Off/On:"); M2_U8NUM(el_num_2, NULL, 0, 1, &u8stato);
M2_BUTTON(el_num_zero, "f4", " zero ", fn_clean_dev); M2_BUTTON(el_dev_ok, NULL, "ok", dev_ok_button); M2_ROOT(el_num_goto_top, "f4", " back ", &top_el_expandable_menu);
M2_LIST(num_list) = { &el_num_label1, &el_num_1, &el_num_label2, &el_num_2, &el_num_zero, &el_num_goto_top, &el_dev_ok }; M2_GRIDLIST(el_num_menu, "c2", num_list);
But I cannot see the into menu the ok button ... please could you tell kindly If wrong something into the code or it depend from the only four line that I've into display ? Or is possible define only one button ? thx gnux
« Reply #34 on: January 21, 2013, 07:56:57 am » |
So I've found the issues :-) I've reduce the space between "zero" and "back" and now is appear :-) M2_BUTTON(el_num_zero, "f4", "zero", fn_clean_dev); M2_BUTTON(el_dev_ok, NULL, "ok", dev_ok_button); M2_ROOT(el_num_goto_top, "f4", "back", &top_el_expandable_menu);
so I'll let you know about the next steps :-) thanks :-) gnux
« Reply #35 on: January 23, 2013, 07:09:15 am » |
Good Morning Oliver, so I've have question for you ... Using the menu ... Is possible set Timer if yes where in which point i can set it ? Because I've set timer but i was asking me if the timer is called, or if the software into the loop still inside the menu ... void loop() { Timer(); m2.checkKey(); m2.checkKey(); if ( m2.handleKey() ) m2.draw(); m2.checkKey(); }
thanks Gnux
« Reply #36 on: January 23, 2013, 07:59:42 am » |
Hi just to say you that I've tried to read from eeprom and pass the value without lcd and it's working ... #include <Time.h> #include <TimeAlarms.h> TimeElements tm,tm1;
String readString; #include <EEPROM.h> void setup() {
Serial.begin(9600); setTime(1,3,00,23,1,13); // set time to Saturday 8:29:00am Jan 1 2011 tm.Year = (EEPROM.read(6)+2000-1970); tm.Month = EEPROM.read(5); tm.Day = EEPROM.read(4); tm.Hour = EEPROM.read(2); tm.Minute = EEPROM.read(3); tm.Second = 00; tm1.Year = (EEPROM.read(11)+2000-1970); tm1.Month = EEPROM.read(10); tm1.Day = EEPROM.read(9); tm1.Hour = EEPROM.read(7); tm1.Minute = EEPROM.read(8); tm1.Second = 00; Alarm.triggerOnce(makeTime(tm), OnceOnly); Alarm.triggerOnce(makeTime(tm1), OnceOnly1); // Alarm.timerOnce(makeTime(tm), OnceOnly) ; // Serial.println("Make Time"); Serial.println(makeTime(tm)); // Alarm.timerRepeat(15, Repeats); // timer for every 15 seconds // called once after 10 seconds }
void loop(){ digitalClockDisplay(); Alarm.delay(1000); // wait one second between clock display }
// functions to be called when an alarm triggers:
void OnceOnly(){ Serial.println("Inizio Timer"); }
void OnceOnly1(){ Serial.println("Fine Timer"); } void digitalClockDisplay() { // digital clock display of the time Serial.print(hour()); printDigits(minute()); printDigits(second()); Serial.println(); }
void printDigits(int digits) { Serial.print(":"); if(digits < 10) Serial.print('0'); Serial.print(digits); }
But with the menù doesn't work ... Thanks for the support, gnux
« Last Edit: January 23, 2013, 11:53:21 am by gnusso »
Germany
« Reply #37 on: January 23, 2013, 05:34:43 pm » |
Hi
Timer() The menu procedures will only provide a small delay. So your Timer() procedure should be called as usual in the loop().
EEPROM and m2tklib. I do not see the full code, so it is difficult to say why the menu is not working.
Oliver
« Reply #38 on: January 24, 2013, 01:37:40 am » |
Hi Oliver, here you are the code :-) #include <Time.h> #include <TimeAlarms.h> #include <LiquidCrystal.h> // ensure that the include path is set #include "M2tk.h" #include <VirtualWire.h> #include <Wire.h> #include <DS1307.h> #include <EEPROM.h> #if defined(ARDUINO) && ARDUINO >= 100 #include "Arduino.h" #else #include "WProgram.h" #endif
//Variabili Globali char dev; char testo[15];
// usata per mandare il messaggio char messaggio[15]; // usato nell'index del close del keypad int ind = 0; // usato nel keypad char Tasto; // usato nel keyoad unsigned long UltimoTasto = 0; // usato nel nella procedura seriale String LeggiStringa; byte memoria[105];
TimeElements tm0start; TimeElements tm0stop; TimeElements tm1start; TimeElements tm1stop; TimeElements tm2start; TimeElements tm2stop; TimeElements tm3start; TimeElements tm3stop; TimeElements tm4start; TimeElements tm4stop; TimeElements tm5start; TimeElements tm5stop; TimeElements tm6start; TimeElements tm6stop; TimeElements tm7start; TimeElements tm7stop;
void LeggiEeprom() { int ind; for (ind =0; ind <= 105 ; ind++) { memoria[ind] = EEPROM.read(ind); } }
void Timer() { tm0start.Hour = memoria[2]; tm0start.Minute = memoria[3]; tm0start.Second = 00; tm0start.Day = memoria[4]; tm0start.Month = memoria[5]; tm0start.Year = ((memoria[6]+2000) - 1970); Alarm.triggerOnce(makeTime(tm0start), StartTimer0); tm0stop.Hour = memoria[7]; tm0stop.Minute = memoria[8]; tm0stop.Second = 00; tm0stop.Day = memoria[9]; tm0stop.Month = memoria[10]; tm0stop.Year = ((memoria[11]+2000) - 1970); Alarm.triggerOnce(makeTime(tm0stop), StopTimer0); if ( memoria[13] != 0 ) { } if ( memoria[26] != 0 ) { } if ( memoria[39] != 0 ) { } if ( memoria[52] != 0 ) { } if ( memoria[65] != 0 ) { } if ( memoria[78] != 0 ) { } if ( memoria[91] != 0 ) { } }
void StartTimer0() { messaggio[0]='1'; messaggio[1]='0'; messaggio[2]='#'; TxMsg(messaggio); Serial.println("Start Timer 0"); }
void StopTimer0() { messaggio[0]='*'; messaggio[1]='0'; messaggio[2]='#'; TxMsg(messaggio); Serial.println("Stop Timer 0"); }
void DefinizionePin() { //Piedini Utilizzati per Gestire LCD pinMode(A0, INPUT); pinMode(A1, INPUT); pinMode(A2, INPUT); pinMode(A3, INPUT); pinMode(A4, INPUT); pinMode(A5, INPUT); pinMode(13, OUTPUT); }
void Comunicazione() { Wire.begin(); // Inizializzo la Comunicazione I2C Serial.begin(9600); // Inizializzo la Seriale vw_setup(1200); // Inizializzo al Comunicazione TTL su Virtual Wire vw_rx_start(); // Start the receiver PLL running RTC.start(); // Fai partire il clock }
void SetOrologio() { setTime(RTC.get(DS1307_HR,true),RTC.get(DS1307_MIN,false),RTC.get(DS1307_SEC,false),RTC.get(DS1307_DATE,false),RTC.get(DS1307_MTH,false),RTC.get(DS1307_YR,false)-2000); }
void TxMsg(char buffer[15]) { vw_send((uint8_t *)buffer, strlen(buffer)); vw_wait_tx(); // Wait until the whole message is gone buffer[0]='\0'; Serial.println("Comando Inviato"); }
// Forward declaration of the toplevel element M2_EXTERN_HLIST(top_el_expandable_menu);
/* SetDate 1-1 */ uint8_t dt_day = 1; uint8_t dt_month = 1; uint8_t dt_year = 12; uint8_t dt_min = 1; uint8_t dt_hour = 1;
void dt_current(void) { Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true Serial.print(":"); Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false) Serial.print(":"); Serial.print(RTC.get(DS1307_SEC,false));//read seconds Serial.print(" "); // some space for a more happy life Serial.print(RTC.get(DS1307_DATE,false));//read date Serial.print("/"); Serial.print(RTC.get(DS1307_MTH,false));//read month Serial.print("/"); Serial.print(RTC.get(DS1307_YR,false)); //read year Serial.println(); }
void dt_get_from_RTC(void) { dt_day = RTC.get(DS1307_DATE,false); dt_month = RTC.get(DS1307_MTH,false); dt_year = (RTC.get(DS1307_YR,false)-2000); dt_min = RTC.get(DS1307_MIN,false); dt_hour = RTC.get(DS1307_HR,true); }
void dt_put_to_RTC(void) { RTC.stop(); RTC.set(DS1307_DATE,dt_day); RTC.set(DS1307_MTH,dt_month); RTC.set(DS1307_YR,dt_year); RTC.start(); }
void time_put_to_RTC(void) { RTC.stop(); RTC.set(DS1307_HR,dt_hour); RTC.set(DS1307_MIN,dt_min); RTC.start(); SetOrologio(); } void dt_ok_date(m2_el_fnarg_p fnarg) { dt_put_to_RTC(); m2_SetRoot(&top_el_expandable_menu); }
void time_ok_button(m2_el_fnarg_p fnarg) { time_put_to_RTC(); m2_SetRoot(&top_el_expandable_menu); }
void view_ok_button(m2_el_fnarg_p fnarg) { dt_current(); m2_SetRoot(&top_el_expandable_menu); }
M2_U8NUM(el_dt_year, "c2", 0,99,&dt_year); M2_LABEL(el_dt_sep1, "b1", "-"); M2_U8NUM(el_dt_month, "c2", 1,12,&dt_month); M2_LABEL(el_dt_sep2, "b1", "-"); M2_U8NUM(el_dt_day, "c2", 1,31,&dt_day);
M2_LIST(list_date) = { &el_dt_year, &el_dt_sep1, &el_dt_month, &el_dt_sep2, &el_dt_day }; M2_HLIST(el_date, NULL, list_date);
M2_ROOT(el_dt_cancel, NULL, "cancel", &top_el_expandable_menu); M2_BUTTON(el_dt_ok, NULL, "ok", dt_ok_date); M2_LIST(list_dt_buttons) = {&el_dt_cancel, &el_dt_ok }; M2_HLIST(el_dt_buttons, NULL, list_dt_buttons);
M2_LIST(list_dt) = {&el_date, &el_dt_buttons }; M2_VLIST(el_top_dt, NULL, list_dt);
/* Set time 1-2 ---------------------------------------------------------------------*/
M2_U8NUM(el_dt_hour, "c2", 0,23,&dt_hour); M2_LABEL(el_dt_c, "b1", ":"); M2_U8NUM(el_dt_min, "c2", 0,59,&dt_min);
M2_LIST(list_time) = { &el_dt_hour, &el_dt_c, &el_dt_min}; M2_HLIST(el_time, NULL, list_time);
M2_ROOT(el_time_cancel, NULL, "cancel", &top_el_expandable_menu); M2_BUTTON(el_time_ok, NULL, "ok", time_ok_button); M2_LIST(list_time_buttons) = {&el_time_cancel, &el_time_ok }; M2_HLIST(el_time_buttons, NULL, list_time_buttons);
M2_LIST(list_t) = {&el_time, &el_time_buttons}; M2_VLIST(el_top_time, NULL, list_t);
/* View DateTime 1-3 */ M2_LABEL(el_dt_view, "b1", "DateTimeNow"); M2_LIST(list_view) = {&el_dt_view}; M2_HLIST(el_view, NULL, list_view);
M2_ROOT(el_view_cancel, NULL, "cancel", &top_el_expandable_menu); M2_BUTTON(el_view_ok, NULL, "ok", view_ok_button); M2_LIST(list_view_buttons) = {&el_view_cancel, &el_view_ok }; M2_HLIST(el_view_buttons, NULL, list_view_buttons);
M2_LIST(list_v) = {&el_view, &el_view_buttons}; M2_VLIST(el_top_view, NULL, list_v);
/* -------------- DEVICE 2 ----------------------*/
void dev_ok_button(m2_el_fnarg_p fnarg) { if (u8dev <= 9) { messaggio[1] = u8dev + 48; messaggio[2] = '#'; messaggio[3] = '\0'; } if (u8dev > 9) { int x,y; y = u8dev/10; messaggio[1] = y + 48; x = u8dev % 10; messaggio[2] = x + 48; messaggio[3] = '#'; messaggio[4] = '\0'; } if (u8stato == 0) { messaggio[0] ='*'; } if (u8stato == 1) { messaggio[0] ='1'; } TxMsg(messaggio); messaggio[0] = '\0'; }
void dev_stato_button(m2_el_fnarg_p fnarg) { // procedura per recuperare lo stato della periferica }
M2_BUTTON(el_num_zero, "f4", "zero", fn_clean_dev); M2_BUTTON(el_dev_ok, NULL, "ok", dev_ok_button); M2_BUTTON(el_dev_stato, NULL, "stato", dev_stato_button); M2_ROOT(el_num_goto_top, "f4", "back", &top_el_expandable_menu);
M2_LIST(num_list) = { &el_num_label1, &el_num_1, &el_num_label2, &el_num_2, &el_dev_ok, &el_num_zero, &el_num_goto_top,&el_dev_stato }; M2_GRIDLIST(el_num_menu, "c2", num_list);
/* main menu */ m2_menu_entry m2_2lmenu_data[] = { { "DATE/TIME 1", NULL }, { ". SetDate 1-1", &el_top_dt }, { ". SetTime 1-2", &el_top_time}, { ". View DateTime 1-3", &el_top_view}, { "DEVICES 2", NULL}, { ". Manage 2-1", &el_num_menu}, { NULL, NULL }, };
uint8_t m2_2lmenu_first; uint8_t m2_2lmenu_cnt;
M2_2LMENU(el_2lmenu,"l4e1w12",&m2_2lmenu_first,&m2_2lmenu_cnt, m2_2lmenu_data,'+','-','\0'); M2_VSB(el_vsb, "l4w1r1", &m2_2lmenu_first, &m2_2lmenu_cnt); M2_LIST(list_2lmenu) = { &el_2lmenu, &el_vsb }; M2_HLIST(top_el_expandable_menu, NULL, list_2lmenu);
// m2 object and constructor M2tk m2(&top_el_expandable_menu, m2_es_arduino_serial, m2_eh_2bs, m2_gh_arduino_serial);
void setup() { LeggiEeprom(); Comunicazione(); }
void loop() { Timer(); m2.checkKey(); m2.checkKey(); if ( m2.handleKey() ) m2.draw(); m2.checkKey(); Timer(); }
Germany
« Reply #39 on: January 24, 2013, 01:59:14 am » |
After a quick review of your code i do not yet see a big mistake.
Is the Menu working without EEPROM? Maybe there is a RAM overflow (too much of RAM consumption).
Oliver
« Reply #40 on: January 24, 2013, 03:26:36 am » |
Hi Oliver, without EEPROM the menu is working ... so it's working also with EEPROM, but only the timer doesn't works ... so now What I've in mind to try is that:
a) check timer alone --> it's working b) check the timer with DS1307 and see if it working c) check timer with DS1307 + a little bit menu and see it's working d) check timer with EEPROM+DS1307+MENU and see it's working
make sense for you ?
Thanks Andrea
« Reply #41 on: January 24, 2013, 05:47:18 am » |
Hi Oliver ... I've tried steps by step ... this result ... a) check timer alone --> it's working --> Ok b) check the timer with DS1307 and see if it working --> Ok c) check the timer with eeprom+DS1307 --> Ok d) check timer with DS1307 + a little bit menu and see it's working -->WITHOUT EEPROM--> not ok e) check timer with DS1307 + a little bit menu WITH EEPROM --> not ok So I've tried to move the timer from loop to setup and from setup to loop without any success .... this below is an example without no more complicated ... maybe you have one sketch that it's working with timer ? to be honest at this point and don't know what check ... seems that the timer routine is never call ... /* * TimeAlarmExample.pde * * This example calls alarm functions at 8:30 am and at 5:45 pm (17:45) * and simulates turning lights on at night and off in the morning * A weekly timer is set for Saturdays at 8:30:30 * * A timer is called every 15 seconds * Another timer is called once only after 10 seconds * * At startup the time is set to Jan 1 2011 8:29 am */ #include <Wire.h> #include <DS1307.h> #include <Time.h> #include <TimeAlarms.h> #include <LiquidCrystal.h> // ensure that the include path is set #include "M2tk.h"
/*======================================================================*/ /* number entry */
uint8_t u8num = 0; uint32_t u32num = 0;
void fn_num_zero(m2_el_fnarg_p fnarg) { u8num = 0; u32num = 0; }
M2_LABEL(el_num_label1, NULL, "U8:"); M2_U8NUM(el_num_1, NULL, 0, 255, &u8num);
M2_LABEL(el_num_label2, NULL, "U32:"); M2_U32NUM(el_num_2, "c5", &u32num);
M2_BUTTON(el_num_zero, "f4", " zero ", fn_num_zero); M2_ROOT(el_num_goto_top, "f4", " back ", &top_el_expandable_menu);
M2_LIST(num_list) = { &el_num_label1, &el_num_1, &el_num_label2, &el_num_2, &el_num_zero, &el_num_goto_top }; M2_GRIDLIST(el_num_menu, "c2", num_list);
/*=========================================================================*/ /* edit date dialog */
void dt_ok_fn(m2_el_fnarg_p fnarg) { m2_SetRoot(&top_el_expandable_menu); }
M2_ROOT(el_dt_cancel, NULL, "cancel", &top_el_expandable_menu); M2_BUTTON(el_dt_ok, NULL, "ok", dt_ok_fn); M2_LIST(list_dt_buttons) = {&el_dt_cancel, &el_dt_ok }; M2_HLIST(el_dt_buttons, NULL, list_dt_buttons);
/*=========================================================================*/ /* radio */
uint8_t select_color = 0;
void fn_radio_ok(m2_el_fnarg_p fnarg) { /* accept selection */ m2_SetRoot(&top_el_expandable_menu); }
void fn_radio_cancel(m2_el_fnarg_p fnarg) { /* discard selection */ m2_SetRoot(&top_el_expandable_menu); }
M2_LABEL(el_radio_label1, NULL, "red"); M2_RADIO(el_radio_radio1, "v0", &select_color);
M2_LABEL(el_radio_label2, NULL, "green"); M2_RADIO(el_radio_radio2, "v1", &select_color);
M2_LABEL(el_radio_label3, NULL, "blue"); M2_RADIO(el_radio_radio3, "v2", &select_color);
M2_BUTTON(el_radio_cancel, NULL, "cancel", fn_radio_cancel); M2_BUTTON(el_radio_ok, NULL, "ok", fn_radio_ok);
M2_LIST(list_radio) = { &el_radio_label1, &el_radio_radio1, &el_radio_label2, &el_radio_radio2, &el_radio_label3, &el_radio_radio3, &el_radio_cancel, &el_radio_ok }; M2_GRIDLIST(top_el_radio, "c2",list_radio);
/*=========================================================================*/ /* combo */
uint8_t select_priority = 0;
void fn_combo_ok(m2_el_fnarg_p fnarg) { /* accept selection */ m2_SetRoot(&top_el_expandable_menu); }
void fn_combo_cancel(m2_el_fnarg_p fnarg) { /* discard selection */ m2_SetRoot(&top_el_expandable_menu); }
const char *fn_idx_to_color(uint8_t idx) { if ( idx == 0 ) return "red"; else if (idx == 1 ) return "green"; return "blue"; }
const char *fn_idx_to_priority(uint8_t idx) { switch(idx) { case 0: return "lowest"; case 1: return "low"; case 2: return "medium"; case 3: return "high"; case 4: return "highest"; } return ""; }
M2_LABEL(el_combo_label1, NULL, "Color:"); M2_COMBO(el_combo_combo1, NULL, &select_color, 3, fn_idx_to_color);
M2_LABEL(el_combo_label2, NULL, "Prio.: "); M2_COMBO(el_combo_combo2, "v1", &select_priority, 5, fn_idx_to_priority);
M2_BUTTON(el_combo_cancel, NULL, "cancel", fn_combo_cancel); M2_BUTTON(el_combo_ok, NULL, " ok ", fn_combo_ok);
M2_LIST(list_combo) = { &el_combo_label1, &el_combo_combo1, &el_combo_label2, &el_combo_combo2, &el_combo_cancel, &el_combo_ok }; M2_GRIDLIST(top_el_combo, "c2",list_combo);
/*=========================================================================*/ /* main menu */
// Left entry: Menu name. Submenus must have a '.' at the beginning // Right entry: Reference to the target dialog box (In this example all menus call the toplevel element again m2_menu_entry m2_2lmenu_data[] = { { "Numeric", NULL }, { ". U8 U32", &el_num_menu }, { ". Date", &el_top_dt }, { "Radio", &top_el_radio }, { "Combo", &top_el_combo }, { NULL, NULL }, };
// The first visible line and the total number of visible lines. // Both values are written by M2_2LMENU and read by M2_VSB uint8_t m2_2lmenu_first; uint8_t m2_2lmenu_cnt;
// M2_2LMENU definition // Option l4 = four visible lines // Option e1 = first column has a width of 1 char // Option w12 = second column has a width of 12 chars
// m2 object and constructor M2tk m2(&top_el_expandable_menu, m2_es_arduino_serial, m2_eh_4bs, m2_gh_arduino_serial); TimeElements tm,tm1;
byte memoria[105];
String readString; #include <EEPROM.h> void setup() { LeggiEeprom(); RTC.stop(); RTC.set(DS1307_DATE,23); RTC.set(DS1307_MTH,01); RTC.set(DS1307_YR,2013); RTC.set(DS1307_HR,1); RTC.set(DS1307_MIN,3); RTC.start(); int c; Serial.begin(9600); setTime(RTC.get(DS1307_HR,true),RTC.get(DS1307_MIN,false),RTC.get(DS1307_SEC,false),RTC.get(DS1307_DATE,false),RTC.get(DS1307_MTH,false),RTC.get(DS1307_YR,false)-2000); // setTime(1,3,00,23,1,13); // set time to Saturday 8:29:00am Jan 1 2011 tm.Year = (memoria[6]+ 2000) - 1970; tm.Month = (memoria[5]); tm.Day = memoria[4]; tm.Hour = memoria[2]; tm.Minute = memoria[3]; tm.Second = 00; tm1.Year = (memoria[11]+2000) -1970; tm1.Month = (memoria[10]); tm1.Day = (memoria[9]); tm1.Hour = (memoria[7]); tm1.Minute = (memoria[8]); tm1.Second = 00; Alarm.triggerOnce(makeTime(tm), OnceOnly); Alarm.triggerOnce(makeTime(tm1), OnceOnly1); // Alarm.timerOnce(makeTime(tm), OnceOnly) ; // Serial.println("Make Time"); // Alarm.timerRepeat(15, Repeats); // timer for every 15 seconds // called once after 10 seconds }
void loop(){ m2.checkKey(); m2.checkKey(); if ( m2.handleKey() ) m2.draw(); m2.checkKey(); // digitalClockDisplay(); // Alarm.delay(1000); // wait one second between clock display }
thanks gnux
« Reply #42 on: January 24, 2013, 12:58:29 pm » |
Hi Oliver, after one day that work on that ... I can say this:
- RTC and Arduino Clock are correctly set - Without use a timer but only put a standard clock for example clock that change in working - With timer for sure the timer are correct but stop to work ...
it's possible that timer is not compatible with menu or viceversa ?
gnux
Germany
« Reply #43 on: January 24, 2013, 02:53:42 pm » |
Hi Excause me for not reading this thread more often. I do not know much about the timer itself. What i can say: M2tklib will use - digitalRead - Serial interface for the Monitor Simulation Can this do any harm to your system? What you could do is to comment out m2.checkKey(); m2.checkKey(); if ( m2.handleKey() ) m2.draw(); m2.checkKey();
and check if things are working again. Maybe you can also check the timer procedures with some small menu. If this is working, that it is probably a memory issue. Which Arduino do you use? Oliver
« Reply #44 on: January 24, 2013, 04:39:19 pm » |
No problem Oliver don't worry :-) thanks for your help and time :-) I was writing you because during this day I was free time for do the try just it :-) ... So due the fact I've note this ... for example without set a timer retriving date and time from RTC it's working ... void loop() { // Alarm.triggerOnce(makeTime(tm0start), StartTimer0); // Alarm.triggerOnce(makeTime(tm0stop), StopTimer0); Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true Serial.print(":"); Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false) Serial.print(":"); Serial.print(RTC.get(DS1307_SEC,false));//read seconds Serial.print(" "); // some space for a more happy life Serial.print(RTC.get(DS1307_DATE,false));//read date Serial.print("/"); Serial.print(RTC.get(DS1307_MTH,false));//read month Serial.print("/"); Serial.print(RTC.get(DS1307_YR,false)); //read year Serial.println(); m2.checkKey(); m2.checkKey(); if ( m2.handleKey() ) m2.draw(); m2.checkKey(); }
Then what i mean it that execute the instruction into the loop also ... I think that is necessary troubleshoot Time.h library , but i don't know if i will be able to this ... the library menu use some particular resources sorry if I ask you but could be useful tomorrow when i'll try to compare the 2 library .... so I'm using arduino 2560 mega ... Thanks for the big support, have a good night ... gnux
