Pages: 1 2 [3] 4 5 ... 10   Go Down
Author Topic: Menu for Display  (Read 4524 times)
Yes for sure :-) Thanks a lots ...
The other good question for you will be :-)
- If i need print something like data and time (now printed in serial) how I can do ? I can print directly on lcd ? this is a general question for example a result of procedure or something else ...
- for example another idea for menu that i've in mind is:
- Device
     --> choose number of device (maybe i can take a part of general serial example). example led
          --> Turn On/Off
          --> Get state and print in serial on lcd
- Timer
    --> choose number of device ((maybe i can take a part of general serial example)
         --> Enable/Disable Timer
            if enable --> set start time start date and end time and end date
            if disable --> disable timer
but this part i think will be a little bit difficult because i need to implement a timer again ... so I've looked and found some documentation but after im stopped because i start to work on menu :-) ...
warm regards,
gnux
thanks
Germany
If you believe something is right, you won't see what's wrong (David Straker).
To print the menu on the LCD, just replace the serial graphics handler with the graphics handler for the character lcd. In order to show something, you could design a menu, with read only fields and only one selectable ok button. Any element can made "read only" by adding "r1" to the format string, so
M2_U8NUM(el_dt_year, "c2r1", 0,99,&dt_year);
M2_LABEL(el_dt_sep1, "b1", "-");
M2_U8NUM(el_dt_month, "c2r1", 1,12,&dt_month);
M2_LABEL(el_dt_sep2, "b1", "-");
M2_U8NUM(el_dt_day, "c2r1", 1,31,&dt_day);
will show the date but will not allow to enter any data (M2_LABEL is always read only).
Of course you can also write directly to the LCD screen, no problem.
Tutorial 6 might give a some ideas here (http://code.google.com/p/m2tklib/wiki/t06glcd)
Oliver
Ok if i not understood bad just change this " m2_es_arduino_serial" with this " m2_es_arduino" in order to enable enable the menu in LCD mode ...
then did this your advise is create a read only menu with only ok button ...
I will try and then I'll you know :-)
have nice a week,
Andrea
Hi Oliver,
I've create another items on the menu
uint8_t u8dev = 0;
uint8_t u8stato = 0;
void fn_clean_dev(m2_el_fnarg_p fnarg) {
  u8dev = 0;
void dev_ok_button(m2_el_fnarg_p fnarg) {
  Serial.println("OK");
M2_LABEL(el_num_label1, NULL, "Select Dev:");
M2_U8NUM(el_num_1, NULL, 0, 64, &u8dev);
M2_LABEL(el_num_label2,NULL, "Turn Off/On:");
M2_U8NUM(el_num_2, NULL, 0, 1, &u8stato);
M2_BUTTON(el_num_zero, "f4", " zero ", fn_clean_dev);
M2_BUTTON(el_dev_ok, NULL, "ok", dev_ok_button);
M2_ROOT(el_num_goto_top, "f4", " back ", &top_el_expandable_menu);
M2_LIST(num_list) = {
    &el_num_label1, &el_num_1,
    &el_num_label2, &el_num_2,
    &el_num_zero, &el_num_goto_top, &el_dev_ok
M2_GRIDLIST(el_num_menu, "c2", num_list);
But I cannot see the into menu the ok button ... please could you tell kindly If wrong something into the code or it depend from the only four line that I've into display ?
Or is possible define only one button ?
thx gnux
So I've found the issues :-) I've reduce the space between "zero" and "back" and now is appear :-)
M2_BUTTON(el_num_zero, "f4", "zero", fn_clean_dev);
M2_ROOT(el_num_goto_top, "f4", "back", &top_el_expandable_menu);
so I'll let you know about the next steps :-)
gnux
Good Morning Oliver,
so I've have question for you ...
Using the menu ... Is possible set Timer if yes where in which point i can set it ?
Because I've set timer but i was asking me if the timer is called, or if the software into the loop still inside the menu ...
  Timer();
  m2.checkKey();
  m2.checkKey();
  if ( m2.handleKey() )
    m2.draw();
  m2.checkKey();
thanks
Gnux
Hi just to say you that I've tried to read from eeprom and pass the value without lcd and it's working ...
#include <Time.h>
#include <TimeAlarms.h>
TimeElements tm,tm1;
String readString;
#include <EEPROM.h>
  setTime(1,3,00,23,1,13); // set time to Saturday 8:29:00am Jan 1 2011
  tm.Year = (EEPROM.read(6)+2000-1970);
  tm.Month = EEPROM.read(5);
  tm.Day = EEPROM.read(4);
  tm.Hour =  EEPROM.read(2);
  tm.Minute =  EEPROM.read(3);
  tm.Second = 00;
  tm1.Year = (EEPROM.read(11)+2000-1970);
  tm1.Month = EEPROM.read(10);
  tm1.Day = EEPROM.read(9);
  tm1.Hour = EEPROM.read(7);
  tm1.Minute = EEPROM.read(8);
  tm1.Second = 00;
  Alarm.triggerOnce(makeTime(tm), OnceOnly);
  Alarm.triggerOnce(makeTime(tm1), OnceOnly1);
  // Alarm.timerOnce(makeTime(tm), OnceOnly) ;
  // Serial.println("Make Time");
  Serial.println(makeTime(tm));
  // Alarm.timerRepeat(15, Repeats);            // timer for every 15 seconds
               // called once after 10 seconds
void  loop(){
  digitalClockDisplay();
  Alarm.delay(1000); // wait one second between clock display
// functions to be called when an alarm triggers:
void OnceOnly(){
  Serial.println("Inizio Timer");
void OnceOnly1(){
  Serial.println("Fine Timer");
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.println();
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
But with the menù doesn't work ...
Thanks for the support,
gnux
« Last Edit: January 23, 2013, 11:53:21 am by gnusso » Logged
Germany
Hi
Timer()
The menu procedures will only provide a small delay. So your Timer() procedure should be called as usual in the loop().
EEPROM and m2tklib.
I do not see the full code, so it is difficult to say why the menu is not working.
Oliver
Hi Oliver,
here you are the code :-)
#include <Time.h>
#include <LiquidCrystal.h> // ensure that the include path is set
#include "M2tk.h"
#include <VirtualWire.h>
#include <Wire.h>
#include <DS1307.h>
#include <EEPROM.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
//Variabili Globali
char dev;
char testo[15];
// usata per mandare il messaggio
char messaggio[15];
// usato nell'index del close del keypad
int ind = 0;
// usato nel keypad
char Tasto;
// usato nel keyoad
unsigned long UltimoTasto = 0;
// usato nel nella procedura seriale
String LeggiStringa;
byte memoria[105];
TimeElements tm0start;
TimeElements tm0stop;
TimeElements tm1start;
TimeElements tm1stop;
TimeElements tm2start;
TimeElements tm2stop;
TimeElements tm3start;
TimeElements tm3stop;
TimeElements tm4start;
TimeElements tm4stop;
TimeElements tm5start;
TimeElements tm5stop;
TimeElements tm6start;
TimeElements tm6stop;
TimeElements tm7start;
TimeElements tm7stop;
void LeggiEeprom()
  int ind;
   for (ind =0; ind <= 105 ; ind++)
        memoria[ind] = EEPROM.read(ind);
void Timer()
     tm0start.Hour =   memoria[2];
     tm0start.Minute = memoria[3];
     tm0start.Second = 00;
     tm0start.Day =   memoria[4];
     tm0start.Month = memoria[5];
     tm0start.Year = ((memoria[6]+2000) - 1970);
     Alarm.triggerOnce(makeTime(tm0start), StartTimer0);
     tm0stop.Hour =   memoria[7];
     tm0stop.Minute = memoria[8];
     tm0stop.Second = 00;
     tm0stop.Day =   memoria[9];
     tm0stop.Month = memoria[10];
     tm0stop.Year = ((memoria[11]+2000) - 1970);
    Alarm.triggerOnce(makeTime(tm0stop), StopTimer0);
  if ( memoria[13] != 0 )
  if ( memoria[26] != 0 )
  if ( memoria[39] != 0 )
  if ( memoria[52] != 0 )
  if ( memoria[65] != 0 )
  if ( memoria[78] != 0 )
  if ( memoria[91] != 0 )
void StartTimer0()
  messaggio[0]='1';
  messaggio[1]='0';
  messaggio[2]='#';
  TxMsg(messaggio);
  Serial.println("Start Timer 0");
void StopTimer0()
  messaggio[0]='*';
  messaggio[1]='0';
  messaggio[2]='#';
  TxMsg(messaggio);
  Serial.println("Stop Timer 0");
void DefinizionePin()
  //Piedini Utilizzati per Gestire LCD
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(A4, INPUT);
  pinMode(A5, INPUT);
  pinMode(13, OUTPUT);
void Comunicazione()
   Wire.begin();         // Inizializzo la Comunicazione I2C
   Serial.begin(9600); // Inizializzo la Seriale
   vw_setup(1200); // Inizializzo al Comunicazione TTL su Virtual Wire
   vw_rx_start();        // Start the receiver PLL running
   RTC.start();          // Fai partire il clock
void SetOrologio()
  setTime(RTC.get(DS1307_HR,true),RTC.get(DS1307_MIN,false),RTC.get(DS1307_SEC,false),RTC.get(DS1307_DATE,false),RTC.get(DS1307_MTH,false),RTC.get(DS1307_YR,false)-2000);
void TxMsg(char buffer[15])
   vw_send((uint8_t *)buffer, strlen(buffer));
   vw_wait_tx(); // Wait until the whole message is gone
   buffer[0]='\0';
   Serial.println("Comando Inviato");
// Forward declaration of the toplevel element
M2_EXTERN_HLIST(top_el_expandable_menu);
/* SetDate 1-1  */
uint8_t dt_day = 1;
uint8_t dt_month = 1;
uint8_t dt_year = 12;
uint8_t dt_min = 1;
uint8_t dt_hour = 1;
void dt_current(void)
  Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
  Serial.print(":");
  Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
  Serial.print(":");
  Serial.print(RTC.get(DS1307_SEC,false));//read seconds
  Serial.print("      ");                 // some space for a more happy life
  Serial.print(RTC.get(DS1307_DATE,false));//read date
  Serial.print("/");
  Serial.print(RTC.get(DS1307_MTH,false));//read month
  Serial.print("/");
  Serial.print(RTC.get(DS1307_YR,false)); //read year
  Serial.println();
void dt_get_from_RTC(void)
  dt_day = RTC.get(DS1307_DATE,false);
  dt_month = RTC.get(DS1307_MTH,false);
  dt_year = (RTC.get(DS1307_YR,false)-2000);
  dt_min = RTC.get(DS1307_MIN,false);
  dt_hour = RTC.get(DS1307_HR,true);
void dt_put_to_RTC(void)
  RTC.stop();
  RTC.set(DS1307_DATE,dt_day);
  RTC.set(DS1307_MTH,dt_month);
  RTC.set(DS1307_YR,dt_year);
  RTC.start();
void time_put_to_RTC(void)
  RTC.stop();
  RTC.set(DS1307_HR,dt_hour);
  RTC.set(DS1307_MIN,dt_min);
  RTC.start();
  SetOrologio();
void dt_ok_date(m2_el_fnarg_p fnarg)
  dt_put_to_RTC();
  m2_SetRoot(&top_el_expandable_menu);
void time_ok_button(m2_el_fnarg_p fnarg)
  time_put_to_RTC();
void view_ok_button(m2_el_fnarg_p fnarg)
  dt_current();
M2_U8NUM(el_dt_year, "c2", 0,99,&dt_year);
M2_U8NUM(el_dt_month, "c2", 1,12,&dt_month);
M2_U8NUM(el_dt_day, "c2", 1,31,&dt_day);
M2_LIST(list_date) = { &el_dt_year, &el_dt_sep1, &el_dt_month, &el_dt_sep2, &el_dt_day };
M2_HLIST(el_date, NULL, list_date);
M2_ROOT(el_dt_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_dt_ok, NULL, "ok", dt_ok_date);
M2_LIST(list_dt_buttons) = {&el_dt_cancel, &el_dt_ok };
M2_HLIST(el_dt_buttons, NULL, list_dt_buttons);
M2_LIST(list_dt) = {&el_date, &el_dt_buttons };
M2_VLIST(el_top_dt, NULL, list_dt);
/* Set time 1-2 ---------------------------------------------------------------------*/
M2_U8NUM(el_dt_hour, "c2", 0,23,&dt_hour);
M2_LABEL(el_dt_c, "b1", ":");
M2_U8NUM(el_dt_min, "c2", 0,59,&dt_min);
M2_LIST(list_time) = { &el_dt_hour, &el_dt_c, &el_dt_min};
M2_HLIST(el_time, NULL, list_time);
M2_ROOT(el_time_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_time_ok, NULL, "ok", time_ok_button);
M2_LIST(list_time_buttons) = {&el_time_cancel, &el_time_ok };
M2_HLIST(el_time_buttons, NULL, list_time_buttons);
M2_LIST(list_t) = {&el_time, &el_time_buttons};
M2_VLIST(el_top_time, NULL, list_t);
/* View DateTime 1-3  */
M2_LABEL(el_dt_view, "b1", "DateTimeNow");
M2_LIST(list_view) = {&el_dt_view};
M2_HLIST(el_view, NULL, list_view);
M2_ROOT(el_view_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_view_ok, NULL, "ok", view_ok_button);
M2_LIST(list_view_buttons) = {&el_view_cancel, &el_view_ok };
M2_HLIST(el_view_buttons, NULL, list_view_buttons);
M2_LIST(list_v) = {&el_view, &el_view_buttons};
M2_VLIST(el_top_view, NULL, list_v);
/* -------------- DEVICE 2 ----------------------*/
uint8_t u8dev = 0;
  u8dev = 0;
  if (u8dev <= 9)
     messaggio[1] = u8dev + 48;
     messaggio[2] = '#';
     messaggio[3] = '\0';
    if (u8dev > 9)
      int x,y;
      y = u8dev/10;
      messaggio[1] = y + 48;
      x = u8dev % 10;
      messaggio[2] = x + 48;
      messaggio[3] = '#';
      messaggio[4] = '\0';
    if (u8stato == 0)
      messaggio[0] ='*';
    if (u8stato == 1)
      messaggio[0] ='1';
  TxMsg(messaggio);
  messaggio[0] = '\0';
void dev_stato_button(m2_el_fnarg_p fnarg) {
 // procedura per recuperare lo stato della periferica
M2_BUTTON(el_dev_stato, NULL, "stato", dev_stato_button);
    &el_dev_ok, &el_num_zero, &el_num_goto_top,&el_dev_stato
/* main menu */
m2_menu_entry m2_2lmenu_data[] =
  { "DATE/TIME 1", NULL },
  { ". SetDate 1-1", &el_top_dt },
  { ". SetTime 1-2", &el_top_time},
  { ". View DateTime 1-3", &el_top_view},
  { "DEVICES 2", NULL},
  { ". Manage 2-1", &el_num_menu},
  { NULL, NULL },
uint8_t m2_2lmenu_first;
uint8_t m2_2lmenu_cnt;
M2_2LMENU(el_2lmenu,"l4e1w12",&m2_2lmenu_first,&m2_2lmenu_cnt, m2_2lmenu_data,'+','-','\0');
M2_VSB(el_vsb, "l4w1r1", &m2_2lmenu_first, &m2_2lmenu_cnt);
M2_LIST(list_2lmenu) = { &el_2lmenu, &el_vsb };
M2_HLIST(top_el_expandable_menu, NULL, list_2lmenu);
// m2 object and constructor
M2tk m2(&top_el_expandable_menu, m2_es_arduino_serial, m2_eh_2bs, m2_gh_arduino_serial);
  LeggiEeprom();
  Comunicazione();
  Timer();
  m2.checkKey();
  m2.checkKey();
    m2.draw();
  m2.checkKey();
  Timer();
gnux
Germany
After a quick review of your code i do not yet see a big mistake.
Is the Menu working without EEPROM?
Maybe there is a RAM overflow (too much of RAM consumption).
Oliver
Hi Oliver,
without EEPROM the menu is working ... so it's working also with EEPROM,
but only the timer doesn't works ... so now What I've in mind to try is that:
a) check timer alone --> it's working
b) check the timer with DS1307 and see if it working
c) check timer with DS1307 + a little bit menu and see it's working
d) check timer with EEPROM+DS1307+MENU and see it's working
make sense for you ?
Thanks
Andrea
Hi Oliver ...
I've tried steps by step ... this result ...
a) check timer alone --> it's working --> Ok
b) check the timer with DS1307 and see if it working --> Ok
c) check the timer with eeprom+DS1307 --> Ok
d) check timer with DS1307 + a little bit menu and see it's working -->WITHOUT EEPROM--> not ok
e) check timer with DS1307 + a little bit menu WITH EEPROM --> not ok
So I've tried to move the timer from loop to setup and from setup to loop without any success ....
this below is an example without no more complicated ... maybe you have one sketch that it's working with timer ?
to be honest at this point and don't know what check ... seems that the timer routine is never call ...
 * TimeAlarmExample.pde
 * This example calls alarm functions at 8:30 am and at 5:45 pm (17:45)
 * and simulates turning lights on at night and off in the morning
 * A weekly timer is set for Saturdays at 8:30:30
 * A timer is called every 15 seconds
 * Another timer is called once only after 10 seconds
 * At startup the time is set to Jan 1 2011  8:29 am
#include <Wire.h>
#include <DS1307.h>
#include <Time.h>
#include "M2tk.h"
/* number entry */
uint8_t u8num = 0;
uint32_t u32num = 0;
void fn_num_zero(m2_el_fnarg_p fnarg) {
  u8num = 0;
  u32num = 0;
M2_LABEL(el_num_label1, NULL, "U8:");
M2_U8NUM(el_num_1, NULL, 0, 255, &u8num);
M2_LABEL(el_num_label2, NULL, "U32:");
M2_U32NUM(el_num_2, "c5", &u32num);
M2_BUTTON(el_num_zero, "f4", " zero ", fn_num_zero);
/* edit date dialog */
uint8_t dt_day = 1;
void dt_ok_fn(m2_el_fnarg_p fnarg)  {
M2_BUTTON(el_dt_ok, NULL, "ok", dt_ok_fn);
/* radio */
uint8_t select_color = 0;
void fn_radio_ok(m2_el_fnarg_p fnarg) {
  /* accept selection */
void fn_radio_cancel(m2_el_fnarg_p fnarg) {
  /* discard selection */
M2_LABEL(el_radio_label1, NULL, "red");
M2_RADIO(el_radio_radio1, "v0", &select_color);
M2_LABEL(el_radio_label2, NULL, "green");
M2_RADIO(el_radio_radio2, "v1", &select_color);
M2_LABEL(el_radio_label3, NULL, "blue");
M2_RADIO(el_radio_radio3, "v2", &select_color);
M2_BUTTON(el_radio_cancel, NULL, "cancel", fn_radio_cancel);
M2_BUTTON(el_radio_ok, NULL, "ok", fn_radio_ok);
M2_LIST(list_radio) = {
    &el_radio_label1, &el_radio_radio1,
    &el_radio_label2, &el_radio_radio2,
    &el_radio_label3, &el_radio_radio3,
    &el_radio_cancel, &el_radio_ok
M2_GRIDLIST(top_el_radio, "c2",list_radio);
/* combo */
uint8_t select_priority = 0;
void fn_combo_ok(m2_el_fnarg_p fnarg) {
void fn_combo_cancel(m2_el_fnarg_p fnarg) {
const char *fn_idx_to_color(uint8_t idx)
  if ( idx == 0 )
    return "red";
  else if (idx == 1 )
    return "green";
  return "blue";
const char *fn_idx_to_priority(uint8_t idx)
  switch(idx)
    case 0: return "lowest";
    case 1: return "low";
    case 2: return "medium";
    case 3: return "high";
    case 4: return "highest";
  return "";
M2_LABEL(el_combo_label1, NULL, "Color:");
M2_COMBO(el_combo_combo1, NULL, &select_color, 3, fn_idx_to_color);
M2_LABEL(el_combo_label2, NULL, "Prio.: ");
M2_COMBO(el_combo_combo2, "v1", &select_priority, 5, fn_idx_to_priority);
M2_BUTTON(el_combo_cancel, NULL, "cancel", fn_combo_cancel);
M2_BUTTON(el_combo_ok, NULL, " ok ", fn_combo_ok);
M2_LIST(list_combo) = {
    &el_combo_label1, &el_combo_combo1,
    &el_combo_label2, &el_combo_combo2,
    &el_combo_cancel, &el_combo_ok
M2_GRIDLIST(top_el_combo, "c2",list_combo);
/* main menu */
// Left entry: Menu name. Submenus must have a '.' at the beginning
// Right entry: Reference to the target dialog box (In this example all menus call the toplevel element again
  { "Numeric", NULL },
  { ". U8 U32", &el_num_menu },
  { ". Date", &el_top_dt },
  { "Radio", &top_el_radio },
  { "Combo", &top_el_combo },
  { NULL, NULL },
// The first visible line and the total number of visible lines.
// Both values are written by M2_2LMENU and read by M2_VSB
// M2_2LMENU definition
// Option l4 = four visible lines
// Option e1 = first column has a width of 1 char
// Option w12 = second column has a width of 12 chars
M2tk m2(&top_el_expandable_menu, m2_es_arduino_serial, m2_eh_4bs, m2_gh_arduino_serial);
byte memoria[105];
String readString;
#include <EEPROM.h>
  LeggiEeprom();
  RTC.stop();
  RTC.set(DS1307_DATE,23);
  RTC.set(DS1307_MTH,01);
  RTC.set(DS1307_YR,2013);
  RTC.set(DS1307_HR,1);
  RTC.set(DS1307_MIN,3);
  RTC.start();
  int c;
  // setTime(1,3,00,23,1,13); // set time to Saturday 8:29:00am Jan 1 2011
  tm.Year = (memoria[6]+ 2000) - 1970;
  tm.Month = (memoria[5]);
  tm.Day = memoria[4];
  tm.Hour =  memoria[2];
  tm.Minute =  memoria[3];
  tm.Second = 00;
  tm1.Year = (memoria[11]+2000) -1970;
  tm1.Month = (memoria[10]);
  tm1.Day = (memoria[9]);
  tm1.Hour = (memoria[7]);
  tm1.Minute = (memoria[8]);
  tm1.Second = 00;
void  loop(){
   m2.checkKey();
  m2.checkKey();
    m2.draw();
  m2.checkKey();
  // digitalClockDisplay();
  // Alarm.delay(1000); // wait one second between clock display
void OnceOnly(){
void OnceOnly1(){
  Serial.println();
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
void LeggiEeprom()
  int ind;
thanks
gnux
Hi Oliver,
after one day that work on that ... I can say this:
- RTC and Arduino Clock are correctly set
- Without use a timer but only put a standard clock for example clock that change in working
- With timer for sure the timer are correct but stop to work ...
it's possible that timer is not compatible with menu or viceversa ?
gnux
Germany
Hi
Excause me for not reading this thread more often.
I do not know much about the timer itself. What i can say: M2tklib will use
- digitalRead
- Serial interface for the Monitor Simulation
Can this do any harm to your system?
What you could do is to comment out
  m2.checkKey();
  m2.checkKey();
    m2.draw();
  m2.checkKey();
and check if things are working again.
Maybe you can also check the timer procedures with some small menu.
If this is working, that it is probably a memory issue.
Which Arduino do you use?
Oliver
No problem Oliver don't worry :-) thanks for your help and time :-) I was writing you because during this day I was free time for do the try just it :-) ...
So due the fact I've note this ... for example without set a timer retriving date and time from RTC it's working ...
    // Alarm.triggerOnce(makeTime(tm0start), StartTimer0);
     // Alarm.triggerOnce(makeTime(tm0stop), StopTimer0);
  Serial.print(":");
  Serial.print(":");
  Serial.print("/");
  Serial.print("/");
  Serial.println();
  m2.checkKey();
  m2.checkKey();
    m2.draw();
  m2.checkKey();
Then what i mean it that execute the instruction into the loop also ...
I think that is necessary troubleshoot Time.h library , but i don't know if i will be able to this ...
the library menu use some particular resources sorry if I ask you but could be useful tomorrow when i'll try to compare the 2 library ....
so I'm using arduino 2560 mega ...
Thanks for the big support,
have a good night ...
gnux
Pages: 1 2 [3] 4 5 ... 10   Go Up
