Good Morning Oliver, sorry if i didn't answer to you yestarday evening but I was completed boiled ...
So for example this below reported is a simple Combo Example Simple Sketch where Im trying to:
- at the start show nothing
- then when I press key show my combo menu
So from Theoretically stand point I've understand and I'm ok what you mean :-) at least :-), but trying to use the code below reported is not working ... So with the normal example everything is working, display, button are ok ... So maybe I did a error in some other part but I don't where to be honest because is a simple example and I've just change the condition and null element and put the condition ...
#include <LiquidCrystal.h>
#include "M2tk.h"
#include "utility/m2ghlc.h"
LiquidCrystal lcd(10, 9, 3, 2, 1, 0);
uint8_t uiKeySelectPin = 22;
uint8_t uiKeyNextPin = 26;
uint8_t select_color = 0;
uint8_t select_priority = 0;
void fn_ok(m2_el_fnarg_p fnarg) {
/* accept selection */
void fn_cancel(m2_el_fnarg_p fnarg) {
/* discard selection */
const char *fn_idx_to_color(uint8_t idx)
if ( idx == 0 )
return "red";
else if (idx == 1 )
return "green";
return "blue";
const char *fn_idx_to_priority(uint8_t idx)
switch(idx)
case 0: return "lowest";
case 1: return "low";
case 2: return "medium";
case 3: return "high";
case 4: return "highest";
return "";
M2_LABEL(el_label1, NULL, "Color:");
M2_COMBO(el_combo1, NULL, &select_color, 3, fn_idx_to_color);
M2_LABEL(el_label2, NULL, "Prio.: ");
M2_COMBO(el_combo2, "v1", &select_priority, 5, fn_idx_to_priority);
M2_BUTTON(el_cancel, NULL, "cancel", fn_cancel);
M2_BUTTON(el_ok, NULL, " ok ", fn_ok);
M2_LIST(list) = {
&el_label1, &el_combo1,
&el_label2, &el_combo2,
&el_cancel, &el_ok
M2_GRIDLIST(list_element, "c2",list);
M2tk m2(&m2_null_element, m2_es_arduino, m2_eh_2bs, m2_gh_lc);
M2_ROOT(el_switch_to_graphics, NULL, "Show Graphics", &m2_null_element);
// Serial.begin(9600);
m2_SetLiquidCrystal(&lcd, 20, 4);
m2.setPin(M2_KEY_SELECT, uiKeySelectPin);
m2.setPin(M2_KEY_NEXT, uiKeyNextPin);
void loop(void) {
if ( m2.getRoot() == &m2_null_element )
// yes, it is our manual written screen
// place your manual commands here
lcd.print("...");
// check if the user has pressed a key while manual screen is active
if ( m2.getKey() != M2_KEY_NONE )
m2.setRoot(&list_element); // refer to a suitable menu
// do normal menu display
m2.checkKey();
if ( m2.handleKey() ) {
m2.draw();
So what I've note is this :
putting a simple like "debug print" for example:
void loop(void) {
lcd.setCursor(0, 0);
lcd.print("Condition");
// // check if the user has pressed a key while manual screen is active
if ( m2.getKey() != M2_KEY_NONE ) {
lcd.setCursor(0, 4);
lcd.print("Verificata");
lcd.print(" ");
lcd.print(" ");
m2.checkKey();
The Condition is verified this ( m2.getRoot() == &m2_null_element ) one times ...then if enable also the second part
m2.checkKey();
m2.draw();
execute at one times the first one part and then the if ( m2.handleKey() is verified to but for sure i didn't press but ... also because when appear a menu is stopped on the right element ...
Thanks
Gnux
