Topic: JY-MCU v1.05 Bluetooth Module with Arduino Mega 1280 (Read 1 time) previous topic - next topic
Hi all,
I'm having trouble getting this Bluetooth module to work. Using Android's Amarino app, a connection with the module can be established, but the module doesn't receive any data sent to it from the app. The code I have been working with is as follows:
Code: [Select]
#include <MeetAndroid.h>
#include <SoftwareSerial.h>
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
String readString;
int runOnce = 1;
SoftwareSerial mySerial(19, 18); // RX, TX
  Serial.println("Correct baud rate selected [9600]. Connection established");
  // set the data rate for the SoftwareSerial port
void loop() // run over and over
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  while (Serial.available()) {
    delay(10);  //small delay to allow input buffer to fill
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
    }  //breaks out of capture loop to print readstring
    readString += c;
  } //makes the string readString
  if (readString.length() >0) {
    Serial.println(readString); //prints string to serial port out
    readString=""; //clears variable for new input
Many thanks
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
