Topic: power outage recovery using DS1307 Real Time Clock (Read 12122 times) previous topic - next topic
urthlight
The example code uses noise from an unused analog pin seed the random() function. I think that will be good enough. My application does not require TRUE random numbers. The repeating pattern would really be good enough.
urthlight
#16
Jan 22, 2013, 03:54 am Last Edit: Jan 22, 2013, 04:00 am by urthlight Reason: 1
Now enter maximum weirdness .
I took the older code and turned it into a couple of functions. I swear it worked last night very late. At work today this code froze at the uploading point and made  my serial programming port unreachable. I determined that the ReadRTCRAM() function is to blame. Does this make any sense to anybody
Code: [Select]
* Q(1-2) - (Q1) Memory Load  (Q2) RTC - Memory Read
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68  // This is the I2C address
// Global Variables
long randNumber;
int command = 0;       // This is the command char, in ascii form, sent from the serial port
byte zero;
int magnum1 = 90;      // dummy var
int magnum2 = 9;      //  dummy var
int  state   = 96;     // State machine variable
int  counter = 255;      // Master counter variable
  randomSeed(4);
 Wire.begin();           // join i2c bus
 Serial.begin(57600);
 zero=0x00;             // not sure what this is for
 if (Serial.available()) {      // Look for char in serial que and process if found
   command = Serial.read();
   if (command == 81 || command == 113) {      //If command = "Qq" RTC1307 Memory Functions
     delay(100);
       if (command == 49) {                //If command = "1"  load data to RAM
        WriteRTCRAM();
       else if (command == 50) {      //If command = "2" Read data from RAM
         ReadRTCRAM();
 command = 0;                 // reset command
 delay(100);
void WriteRTCRAM(){
   randNumber = random(250);
 Serial.println(randNumber);
Wire.beginTransmission(DS1307_I2C_ADDRESS);   // 255 will be the init value and 0 will be considered
         Wire.write(32);                   // Set the register pointer to before data location
         Wire.write(randNumber);              // Write magic number before storing data
         Wire.write(state);                // Store State variable
         Wire.write(counter >> 8);         // writes the high byte of counter
         Wire.write(counter & 0xFF);       // writes the low byte of counter
         Wire.write(randNumber);              // Write magic number after storing data
         Wire.endTransmission();
         Serial.println("Data Stored");
void ReadRTCRAM(){
Serial.println("Begin Read");
         Wire.write(zero);   // not sure what this is for
         Wire.write(0x20);         // not sure what this is doing
         Wire.requestFrom(DS1307_I2C_ADDRESS, 32);  // Set pointer to the first byte of data
         magnum1 = (Wire.read());  //magic number written before data write
         state = (Wire.read());    // Read state data
         counter = (Wire.read() << 8) + Wire.read(); // Read first byte shift left read second byte
         magnum2 = (Wire.read());  // Read Magic number written after data write
         Serial.print(" Magic Number = ");
         Serial.println(magnum1);
         Serial.print(" State = ");
         Serial.println(state);
         Serial.print(" Counter = ");
         Serial.println(counter);
         Serial.println(magnum2);
         Serial.println(" RTC1307 Dump end");
         if (magnum1 = magnum2){
         Serial.print (" Write Error!!!");
this is just too strange
PaulS
Code: [Select]
Why not make it easy to read this code?
Code: [Select]
    if (command == 'Q' || command == 'q') {      // No comment needed; its obvious what to type
Code: [Select]
(What's) (with) (all) (the) (parentheses) (?)
Code: [Select]
Yeah, right. An assignment in the middle of an if statement...
Code: [Select]
Don't you think you should figure these out?
urthlight
#18
Jan 22, 2013, 06:07 pm Last Edit: Jan 22, 2013, 06:11 pm by urthlight Reason: 1
Insert Quote
Code: [Select]
Quote
Ok np but this is just temp code to get it running
Code: [Select]
Quote
Ok fixed
Code: [Select]
Quote
Ah this is supposed to be
Code: [Select]
[code]
         if (magnum1 != magnum2){
[/code]
Code: [Select]
Quote
Well being new to  the TWI I dont fully understand but I did find
   Issue 527 : Stream-based Wire library doesn't accept zero
and the fix  which I used.
and still after all of this I still cannot get this to upload unless I REM out the If statement.
PaulS
Quote
and still after all of this I still cannot get this to compile unless I REM out the If statement.
Time to post new code, and the error messages.
urthlight
Code: [Select]
#include "Wire.h"
// Global Variables
long randNumber;
byte zero;
   randomSeed(analogRead(0));
      delay(100);
         WriteRTCRAM();
          ReadRTCRAM();
  delay(100);
void WriteRTCRAM(){
void ReadRTCRAM(){
          magnum1 = Wire.read();  //magic number written before data write
          state = Wire.read();    // Read state data
          counter = Wire.read() << 8 + Wire.read(); // Read first byte shift left read second byte
          magnum2 = Wire.read();  // Read Magic number written after data write
This compiles but will not upload
Code: [Select]
#include "Wire.h"
// Global Variables
long randNumber;
byte zero;
      delay(100);
         WriteRTCRAM();
          ReadRTCRAM();
  delay(100);
void WriteRTCRAM(){
void ReadRTCRAM(){
         // if (magnum1 != magnum2){
        //  Serial.print (" Write Error!!!");
This compiles and uploads
No error code green progress bar fills up to the last 3 white spaces and holds, to the left it says uploading.
Eventually I get a time out message. Waiting now so I can quote it.
urthlight
Code: [Select]
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
PaulS
Does commenting out just the Serial.print() statement make a difference? Does uncommenting that one, and commenting another make a difference?
urthlight
#23
Jan 22, 2013, 06:35 pm Last Edit: Jan 22, 2013, 06:44 pm by urthlight Reason: 1
Strangely yes commenting out the serial print statement did work.
Any Idea as to why this should act so?
urthlight
As it turns out !!! is the culprit.
Quote
Actually all arduino mega1280 and mega2560 boards both past and present suffer from the !!! bootloader monitor 'bug'. Doesn't matter what version board or version of IDE, the only fix is to upgrade the bootloader to one that has fixes that and other shortcomings of that bootloader.
Lefty
CrossRoads
PaulS, you could not have just mentioned that???
PaulS
Quote
I guess I could have,,, if I'''d read the whole statement,,, and seen that the statement contained data that was likely to cause problems...
The initial post said that commenting out three statements was required,,, to make the code upload. I was interested in finding out which of the three was the culprit...
As you can see from my reply, three punctuation marks in a row contribute nothing to the information. I don't understand why people feel it necessary to send more data than is necessary.
urthlight
Quote
What is not necessary?
