Offline
Jr. Member
« on: January 16, 2013, 11:33:22 am » |
Since the Arduino Due has a reasonable speed (84 mhz) for pixel processing on a display, I wonder if there is a display that can benefit from the performance of the new Arduino. I had two TFT display before. The first one was veeeeery slow and the second one was the SmartGPU, which I think shouldn't show a difference when used with the Arduino Due since the calculations are done on the TFT screen GPU itself.
The question is: Is there a TFT display specifically dedicated for the Arduino?
Greetings.
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #1 on: January 16, 2013, 12:33:52 pm » |
Check out some of these http://www.newhavendisplay.com/tfts-c-1.html"TFT (Thin-Film Transistor) Displays are active-matrix LCDs with full RGB color screens. These screens feature bright, vivid colors and have the ability to show fast animations, complex graphics and crisp custom fonts. "
Logged
Offline
Jr. Member
« Reply #2 on: January 16, 2013, 01:27:18 pm » |
Are these compatible with Arduino i.e. are there driver sources for the Arduino? Also it would be very nice if they would be shields because it would be easier to connect.
Logged
Global Moderator
Offline
Brattain Member
« Reply #3 on: January 16, 2013, 01:49:26 pm » |
I don't know, I've not used any displays like this yet. Too much coding for me.
Pick one, mount it on a protoboard with pins where you need connections, and a couple others for stability, shouldn't be hard.
Logged
Guaymas, Sonora, Mexico
Offline
Newbie
learning never stops.
« Reply #4 on: January 17, 2013, 10:33:43 pm » |
I have a Due and the SmartGPU... definitely some library work needed. working on it now.
Logged
Quiero una vida simple en Mexico...nada mas.
Offline
Jr. Member
« Reply #5 on: January 20, 2013, 03:26:37 pm » |
From the looks of it, the Arduino Due has a USB jack for keyboards/mice and other stuff. So you should be able to connect a display device via USB, right? Well I don't know it such thing exists, but it would be awesome. Even greater if you could hook up a USB hub to the Arduino and connect keyboard AND mice AND a screen to the Due. Is that possible? Can the Arduino Due handle USB hubs?
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #6 on: January 21, 2013, 10:12:03 pm » |
You Might get an answer... In the Due forum section. Here: http://arduino.cc/forum/index.php/board,87.0.htmlBob
« Last Edit: January 21, 2013, 10:14:55 pm by Docedison »
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Offline
Jr. Member
« Reply #7 on: January 22, 2013, 08:44:32 am » |
Thanks. I think I'll take a closer look at what the Gameduino can do and if it's compatible.
Bye.
Logged
Paris
Offline
Newbie
« Reply #8 on: May 20, 2013, 12:11:02 pm » |
I'm using MOD-VGA32 from Olimex (full compatible GameDuino) and is very fast. I'm using SPI connections of Arduino Due and I have not problem just impossible to compile the GD library on due. I worked with SPI.h (SPI.setClockDivider(9, 4); very fast) and write some test functions and it's ok ! read http://arduino.cc/en/Reference/SPI and http://arduino.cc/en/Reference/DueExtendedSPIEddy
Logged
