Author Topic: Is there a fast TFT Display for the Arduino Due?  (Read 652 times)
Since the Arduino Due has a reasonable speed (84 mhz) for pixel processing on a display, I wonder if there is a display that can benefit from the performance of the new Arduino.
I had two TFT display before. The first one was veeeeery slow and the second one was the SmartGPU, which I think shouldn't show a difference when used with the Arduino Due since the calculations are done on the TFT screen GPU itself.
The question is: Is there a TFT display specifically dedicated for the Arduino?
Greetings.
Boston area, metrowest
Check out some of these
http://www.newhavendisplay.com/tfts-c-1.html
"TFT (Thin-Film Transistor) Displays are active-matrix LCDs with full RGB color screens. These screens feature bright, vivid colors and have the ability to show fast animations, complex graphics and crisp custom fonts. "
Are these compatible with Arduino i.e. are there driver sources for the Arduino? Also it would be very nice if they would be shields because it would be easier to connect.
I don't know, I've not used any displays like this yet. Too much coding for me.
Pick one, mount it on a protoboard with pins where you need connections, and a couple others for stability, shouldn't be hard.
Guaymas, Sonora, Mexico
learning never stops.
I have a Due and the SmartGPU... definitely some library work needed.
working on it now.
Quiero una vida simple en Mexico...nada mas.
From the looks of it, the Arduino Due has a USB jack for keyboards/mice and other stuff. So you should be able to connect a display device via USB, right? Well I don't know it such thing exists, but it would be awesome. Even greater if you could hook up a USB hub to the Arduino and connect keyboard AND mice AND a screen to the Due. Is that possible? Can the Arduino Due handle USB hubs?
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
You Might get an answer... In the Due forum section. Here:    http://arduino.cc/forum/index.php/board,87.0.html
Bob
« Last Edit: January 21, 2013, 10:14:55 pm by Docedison » Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Thanks.
I think I'll take a closer look at what the Gameduino can do and if it's compatible.
Bye.
