Topic: SD.exists() has weird side effect (Read 2906 times) previous topic - next topic
blowback
If I take the SD example "listfiles.ino" and run it on my Uno+Wireless SD shield, it lists the files on the SD card. So far so good.
If I add a single SD.exists call at the start, like this:
Code: [Select]
if(SD.exists("META.DAT"))    // <----- ADDED THIS
        Serial.println("EXISTS");
        Serial.println("DOESN'T EXIST");
    root = SD.open("/");
    if(root)
        Serial.println("root opened");
        printDirectory(root, 0);
then the directory listing now returns nothing at all. The SD.open() still succeeds, but the call to dir.openNextFile() inside printDirectory() always fails.
It doesn't matter if the file I'm testing for actually exists on the SD card or not - SD.exists() returns the right result, but in either case dir.openNextFile() will fail.
This looks like I bug, unless I'm misusing it in some way...
robtillaart
And did you dive into the code what could cause it?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
had a quick look at the SD lib (in your arduino path) and the exists function calls the walkpath(...) function to walk the tree to see if it exists. What I saw it traverses the whole directory so some pointers might be at the end.
can you try rewindDirectory() ?
Which version of the Arduino are you using BTW?
Rob Tillaart
fat16lib
SD.open("/") doesn't really open root.  It just gives you a pointer to the already open internal root object.
The root file is positioned by SD.exists().  printDirectory() does not position dir so its behavior depends on the current position of dir.
Try calling rewindDirectory() before calling printDirectory() like this:
Code: [Select]
  root.rewindDirectory();
blowback
It's a Uno, with a wireless SD shield. Yes, rewindDir() fixes it, thanks all.
