Boston area, metrowest
Online
« Reply #1 on: January 16, 2013, 03:31:05 pm » |
Then they should use a driver that uses a single resistor to set the overall max current for the device, and offers software control of the brightness. MAX7219/7221, TLC5490, WS2801, WS2803, etc.
Thoughts 2 & 3 seem not to have anything to do with resistors.
Engineers don't like fritzing.
Central MN, USA
« Reply #2 on: January 16, 2013, 04:13:00 pm » |
I am no engineer but I didn't like fritzing either after tinkering with it a bit. That was a year or so ago. Now I find some use for fritzing. You can draw up simple diagrams with their breadboard and post the image. With an actual breadboard and parts (who has time to build a voltage divider?!), you take a shot at it, the perspective is always screwy. With pins, headers, wires and the breadboard not at the same depth of view, the picture could easily be misleading. But with fritzing it's all good.
Online
« Reply #3 on: January 16, 2013, 04:17:14 pm » |
"You can draw up simple diagrams with their breadboard and post the image." which we engineers don't like because the parts show up as block boxes with no clues as to what the wire is connected to. even a simple transistor - no way to tell if connected to Emittter, Base, Collector - all the stuff that a simple schematic shows. Post the schematic, that is so much more informative. I have yet to see a decent schematic posted that was created in fritzing.
SE USA
Online
@ssh0le
« Reply #4 on: January 16, 2013, 09:23:52 pm » |
look at the pictures and fritzing does schematics, the idea is you biuld it on your "breadboard", then it makes the schematic, then I think it can do simple PCB stuff, but no one ever makes it that far.
Online
« Reply #5 on: January 16, 2013, 11:28:08 pm » |
Look at the pictures? you biuld it on your "breadboard", then it makes the schematic There's the problem then - user gives up control - or more typically has no clue - and then autocreated schematic is just crap.
Maine
Caution: Explosives in use.
« Reply #6 on: January 16, 2013, 11:35:57 pm » |
look at the pictures and fritzing does schematics, the idea is you biuld it on your "breadboard", then it makes the schematic, then I think it can do simple PCB stuff, but no one ever makes it that far. I actually use it to design and print PCBs. Had to switch from Eagle when I decided to start selling some of my projects, didn't want to drop the $80 on a license. It does have some bugs, so I usually just use the breadboard view to drop parts on, then do my own routing in the PCB view. I have never been able to make a schematic look nice, so I usually ignore that view. Any other software recommendations? I was going to try out Eagle again, but it seems you have to actually mail them a form now (is this the 1920s?). Scratch that, found the download link.
« Last Edit: January 16, 2013, 11:38:37 pm by wizdum »
"Anyone who isn't confused really doesn't understand the situation." Arduino-based airsoft props -> www.nightscapetech.com
Johannesburg UTC+2
« Reply #7 on: January 17, 2013, 12:00:58 am » |
But back on topic, at least the Blink Tutorial has a series resistor....
IT Crowd: Roy... "Have you tried turning it off and on again?" Moss.. "Have you tried forcing an unexpected reboot?"
Central MN, USA
« Reply #8 on: January 17, 2013, 12:44:55 am » |
Eagle is more like $40 USD for lite license. I have it, wishing I could afford license upgrade but don't have the dough.
SE USA
Online
@ssh0le
« Reply #9 on: January 17, 2013, 01:14:33 am » |
Look at the pictures? you biuld it on your "breadboard", then it makes the schematic There's the problem then - user gives up control - or more typically has no clue - and then autocreated schematic is just crap. yea man, he linked two sites, if you look at the picture on them its a led with no resistor, leading back to Thoughts 2 & 3 seem not to have anything to do with resistors. yea they do, click on the link and look at the picture, no resistors on led's sheesh
Online
« Reply #10 on: January 17, 2013, 01:26:11 am » |
You're right, I hadn't opened the links. Saw /download on the first one, assumed it was a lead in to download fritzing.
Boston Suburbs
I am above your silly so-called "Laws", Mister Ohm.
« Reply #12 on: January 17, 2013, 10:10:10 am » |
I will say that the high power LED's that are sold with the current limiting already on the heatsink are awfully nice to use, even if they are a bit more expensive. I've paid as much as two dollars a watt, but usually they end up being around half that, at a buck a watt, give or take, for whites in the 2watt range. Feed them anything from 3.2 to 6v, they self limit at 500ma or thereabout. Here's a link: EDIT: Got diverted while getting the link, hehehe: http://www.ebay.com/itm/10x-2-3W-LED-3-2-6V-500mA-Warm-White-for-Camping-Light-DIY-/180857225621?pt=Lamps_US&hash=item2a1bee4195Now, I will say that it does require extra heat sinking in actual operation- but running a couple in series from 12v works great. I suppose running three ought to be fine at 12v. Its a lot of light for cheap money... The link has them at under a buck each for ten. I am not connected to it in any way other than saying I've bought them and though they seem a little dimmer than expected given the power draw, but not so much that you'd actually care much... I use an NPN transistor to switch the ground side to provide PWM.  They are awfully convenient to use, when you don't want to diddle around with constant current sources...
« Last Edit: January 17, 2013, 04:48:49 pm by focalist »
When the testing is complete there will be... cake.
Online
« Reply #13 on: January 17, 2013, 10:33:19 am » |
"Here's a link:" or not
Online
« Reply #14 on: January 17, 2013, 10:36:48 am » |
There are 12V LEDs with resistors for sure, with mounting hardware even. Pricey for experimenting, great for final installations. Some examples http://www.superbrightleds.com/cat/led-wired-bolts/
