Pages: [1] 2 3   Go Down
Author Topic: People hate resistors for their LEDs  (Read 1857 times)
Central MN, USA
I found this true over the years. People just hate to use resistors with their LEDs.
Here is a popular program, Fritzing's download page:
http://fritzing.org/download/
An otherwise pretty good tutorial for arduino with LabVIEW:
http://vishots.com/getting-started-with-the-labview-interface-for-arduino/
Boston area, metrowest
Then they should use a driver that uses a single resistor to set the overall max current for the device, and offers software control of the brightness.
MAX7219/7221, TLC5490, WS2801, WS2803, etc.
Thoughts 2 & 3 seem not to have anything to do with resistors.
Engineers don't like fritzing.
Central MN, USA
I am no engineer but I didn't like fritzing either after tinkering with it a bit. That was a year or so ago. Now I find some use for fritzing. You can draw up simple diagrams with their breadboard and post the image. With an actual breadboard and parts (who has time to build a voltage divider?!), you take a shot at it, the perspective is always screwy. With pins, headers, wires and the breadboard not at the same depth of view, the picture could easily be misleading. But with fritzing it's all good.
"You can draw up simple diagrams with their breadboard and post the image."
which we engineers don't like because the parts show up as block boxes with no clues as to what the wire is connected to.
even a simple transistor - no way to tell if connected to Emittter, Base, Collector - all the stuff that a simple schematic shows.
Post the schematic, that is so much more informative.
I have yet to see a decent schematic posted that was created in fritzing.
SE USA
@ssh0le
look at the pictures
and fritzing does schematics, the idea is you biuld it on your "breadboard", then it makes the schematic, then I think it can do simple PCB stuff, but no one ever makes it that far.
Look at the pictures?
There's the problem then - user gives up control - or more typically has no clue - and then autocreated schematic is just crap.
Maine
Caution: Explosives in use.
I actually use it to design and print PCBs. Had to switch from Eagle when I decided to start selling some of my projects, didn't want to drop the $80 on a license. It does have some bugs, so I usually just use the breadboard view to drop parts on, then do my own routing in the PCB view. I have never been able to make a schematic look nice, so I usually ignore that view.
Any other software recommendations? I was going to try out Eagle again, but it seems you have to actually mail them a form now (is this the 1920s?). Scratch that, found the download link.
« Last Edit: January 16, 2013, 11:38:37 pm by wizdum » Logged
"Anyone who isn't confused really doesn't understand the situation."
Arduino-based airsoft props -> www.nightscapetech.com
Johannesburg UTC+2
But back on topic, at least the Blink Tutorial has a series resistor....
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Central MN, USA
Eagle is more like $40 USD for lite license. I have it, wishing I could afford license upgrade but don't have the dough.
SE USA
@ssh0le
yea man, he linked two sites, if you look at the picture on them its a led with no resistor, leading back to
yea they do, click on the link and look at the picture, no resistors on led's
sheesh  smiley-razz
You're right, I hadn't opened the links.
Saw /download on the first one, assumed it was a lead in to download fritzing.
Durham UK
aka Craig Turner
Hi Guys,
hope this isn't a proverbial grandma-egg-sucking  moment, but you can get leds suitable for 5v use with built in resistors
UK: http://www.rapidonline.com/Electronic-Components/5mm-Red-LED-5V-60-150mcd-Diffused-55-2670/?source=googleps&utm_source=googleps
I think there are 12v ones too.
I don't like fritzing either, I prefer circuit diagrams every time.
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
Boston Suburbs
I am above your silly so-called "Laws", Mister Ohm.
I will say that the high power LED's that are sold with the current limiting already on the heatsink are awfully nice to use, even if they are a bit more expensive.  I've paid as much as two dollars a watt, but usually they end up being around half that, at a buck a watt, give or take, for whites in the 2watt range.  Feed them anything from 3.2 to 6v, they self limit at 500ma or thereabout.  Here's a link:
EDIT: Got diverted while getting the link, hehehe:
http://www.ebay.com/itm/10x-2-3W-LED-3-2-6V-500mA-Warm-White-for-Camping-Light-DIY-/180857225621?pt=Lamps_US&hash=item2a1bee4195
Now, I will say that it does require extra heat sinking in actual operation- but running a couple in series from 12v works great.  I suppose running three ought to be fine at 12v.  Its a lot of light for cheap money... The link has them at under a buck each for ten.  I am not connected to it in any way other than saying I've bought them and though they seem a little dimmer than expected given the power draw, but not so much that you'd actually care much...  I use an NPN transistor to switch the ground side to provide PWM.
They are awfully convenient to use, when you don't want to diddle around with constant current sources...
« Last Edit: January 17, 2013, 04:48:49 pm by focalist » Logged
When the testing is complete there will be... cake.
"Here's a link:"  or not smiley-wink
There are 12V LEDs with resistors for sure, with mounting hardware even.
Pricey for experimenting, great for final installations.
Some examples
http://www.superbrightleds.com/cat/led-wired-bolts/
Pages: [1] 2 3   Go Up
