Topic: Correct symbols (Read 793 times) previous topic - next topic
SouthernAtHeart
http://en.wikipedia.org/wiki/Mosfet
Are the N & P channel Mosfet symbols correct in the 4th column of the table at this wiki site?
CrossRoads
Could be - little hard to find a datasheet for a part like that.
oric_dan
#2
Jan 16, 2013, 11:16 pm Last Edit: Jan 16, 2013, 11:18 pm by oric_dan(333) Reason: 1
Yes, I remember those from a while back. In those the arrows are showing the direction of
current-flow. You'll notice the similarity to the JFETs. Also, similar to NPN/PNP bipolar symbols.
Nowadays, the arrows are used to illustrate the type of substrate, eg, arrow points inward
[ala "cathode"] to indicate n-channel type.
majenko
#3
Jan 17, 2013, 02:41 am Last Edit: Jan 17, 2013, 02:43 am by majenko Reason: 1
Tip for remembering it:  N stands for Near.
NPN transistor, the arrow Not Point Near.
PNP transistor?  Point Near, Please!
oric_dan
#4
Jan 17, 2013, 02:53 am Last Edit: Jan 17, 2013, 02:59 am by oric_dan(333) Reason: 1
Ok, here's your challenge. Invent something like this for MOSFETs, based upon the direction
of the diode in the middle of the symbol, :-).
I also seem to recall they used to originally show NPN transistors as analogous to 2
anode-to-anode diodes [opposite for PNP], with the base lead coming out the middle,
although that hardly explains how they amplify. It does however explain why you can
take an ohm-meter and determine the type of transistor you have without knowing its
part number.
SouthernAtHeart
Hmmmmm.....  Seems quite strange that in these two punctures, one is a P channel and one is an N channel.  I'll always have to reference a chart to figure them out! The arrows both point in, they both point from the S
SirNickity
Yeah, that one's a pet peeve of mine.  Pick one and let the other die gracefully.  I don't even care which!  :-)  My schematics software uses one, and sim software the other.  I always have to hover over it for the labels to make sure I'm not getting them mixed up.
SouthernAtHeart
That's kinda it for me too. This new software uses n the old one that's backwards...
oric_dan
#8
Jan 17, 2013, 07:09 am Last Edit: Jan 17, 2013, 07:12 am by oric_dan(333) Reason: 1
I already explained this in post #2. Originally, all 3 transistor types, jfet, bipolar, and mosfet used similar
[read: consistent] direction-of-arrow diagrams. Now the MOSFETs have a new standard.
