Topic: Uno Reference Voltage of 1.1v (Read 10926 times) previous topic - next topic
gggggggg
Hello, I am told the Reference Voltage of 1.1v exists on the UNO, but can someone please tell me which pin I need to connect my multi meter to, to read it.
thanks
Coding Badly
http://arduino.cc/forum/index.php/topic,38119.msg282514.html#msg282514
gggggggg
Perfect, thank you.  1.071v
gggggggg
Follow up question:  if my voltage is 1.071, and the system is expecting 1.1, does that mean I can hook up the Positive of my battery power source to A1, read the value, and get 97.36363636363636% of that value as the current voltage in my battery source?
Or would I need to get 102.7077497665733%  of it, to get the current battery source voltage.
2.7% is a fair amount to be out.  Aside from the above example, where else would you use a value like this?  I have a triply axis gyro/accel/temp in my project (connected to A4 and A5  - https://www.sparkfun.com/products/11028) does that mean I should expect my results there are 2.7% out also?
Or is it even more complex than that, and I have to apply the 2.7% to the current battery volt.  Check that against 5v (or 3.3v), and use that new ratio or 'something' against my values based on if my module is using 3.3v or 5v source from the arduino.
mauried
Its important to read the spec sheet for the Atmega328 when looking at the internal voltage referance specs.
The 1.1 volt referance can vary anywhere between 1.0 to 1.2 volts, which is 20% variation.
Its not a stabilised voltage referance.
If you want a stabilised referance voltage for things like calibrating voltmeters, then you need something like this.
http://www.analog.com/en/special-linear-functions/voltage-references/adr4525/products/product.html
Voltage guaranteed to be stable within 0.02%.
They aint cheap though.
Coding Badly
You are not reading the specifications correctly.  The variation is due to manufacturing differences.
retrolefty
I'm not sure I can agree with you that the internal voltage reference is not a stabilized voltage reference. There can be device to device variation for the nominal 1.1vdc band-gap reference, but for any specific chip it will be a stable voltage reference that will be somewhere within that stated range. And once one does actually measure the specific bandgap voltage of their specific chip then steps can be developed a calibration factor one might apply to ADC readings.
Lefty
Coding Badly
...hook up the Positive of my battery power source to A1, read the value, and get 97.36363636363636% of that value as the current voltage in my battery source?
Your "battery power source" has a voltage less than 1.071?
gggggggg
No my source is ~5v.   My reference voltage is 1.071v
mauried
The spec sheet is here.
http://www.atmel.com/Images/doc8161.pdf
Sect 28.8 ADC Characteristics.
Vint Internal Voltage Ref   Min 1.0 Typical 1.1 Max 1.2
Seems pretty clear to me.
Coding Badly
The spec sheet is here. ... Seems pretty clear to me.
In that case you should have no problem explaining when the internal reference would be 1.0 volts and when it would be 1.2 volts.
Coding Badly
So you'll be using the technique described in that post?  Using the battery voltage as a reference to measure the 1.071V bandgap?
dhenry
Not sure what those Atmel guys were thinking when they designed that sucker.
retrolefty
Well to me that spec is giving the nominal band-gap voltage allowable range for any specific chip you might obtain, not the stablity spec of the band-gap voltage which is not specified in the datasheet. It's been my first hand observation that the band-gap voltage is very stable, just different nominal values for different chips.
Lefty
olf2012
Lefty
It is specified, data sheet page 525, and it is "quite stable"
