Loading...
Pages: [1]   Go Down
Author Topic: 4 led chaser problems.  (Read 209 times)
Offline Offline
Newbie
View Profile
so i have 4 leds. i have a second arduino pulsing every second. the second arduino is fed straight wire into A3. i do a digital read on A3 and get a value i then use in a digital write.
the val POSA starts at 6 and needs to go up to 9, then repeat to 6.
i use a loop and i get theh led to mirror the second arduino pulsing. blink blink.
now when i add the code
posA ++;
or
posA =  posA + 1;
the program blinks the first led on pin 6, then does nothing.
please help me.
Code:
int A = 6;
int B = 7;
int C = 8;
int D = 9;
int stepA = A3;
int dirA = A2;
int stepB = A1;
int dirB = A0;
int valstepA = 0;
int valdirA = 0;
int posA = 6;
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(stepA, INPUT);
pinMode(dirA, INPUT);
pinMode(stepB, INPUT);
pinMode(dirB, INPUT);
do{
  valdirA = digitalRead(dirA);
  valstepA = digitalRead(stepA);
digitalWrite(posA, valstepA);
} while (valstepA == HIGH);
posA ++;
Logged
Offline Offline
Sr. Member
The last thing you did is where you should start looking.
View Profile
int valstepA = 0;
int valdirA = 0;
Do you want boolean ?
boolean valstepA = false;
boolean valdirA = false;
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Which part of the code does "then repeat to 6"?
Logged
Offline Offline
Newbie
View Profile
larryD, i dont know if booean works better here. im comming from ASM and am still new to C.\\
fungu, that bit of code was after "posA ++;"
but seems to have been deleted.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I suspect that if valstepA is LOW then posA is going to get incremented a lot more often that you think.
Logged
Pages: [1]   Go Up
Print
Jump to:
