Loading...
Pages: [1] 2   Go Down
Author Topic: MegaBrite RGB  (Read 512 times)
Offline Offline
Full Member
View Profile
Hi All,
I piceked up a Mega Brite RGB (Tiro) From Sparkfun.com
https://www.sparkfun.com/products/10236.
The thing is am very new to all this. (about a month) and I am not sure how to use it.
I looked at the example sketch and was able to figure out the PIN's some what. But when I Run it only the Blue and red come on.
Thanks of any help given .
Code:
#define clockpin 13 // CI
#define enablepin 10 // EI
#define latchpin 9 // LI
#define datapin 11 // DI
#define NumLEDs 2
int LEDChannels[NumLEDs][3] = {0};
int SB_CommandMode;
int SB_RedCommand;
int SB_GreenCommand;
int SB_BlueCommand;
   pinMode(datapin, OUTPUT);
   pinMode(latchpin, OUTPUT);
   pinMode(enablepin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
   digitalWrite(latchpin, LOW);
   digitalWrite(enablepin, LOW);
void SB_SendPacket() {
    if (SB_CommandMode == B01) {
     SB_RedCommand = 120;
     SB_GreenCommand = 100;
     SB_BlueCommand = 100;
    SPDR = SB_CommandMode << 6 | SB_BlueCommand>>4;
    while(!(SPSR & (1<<SPIF)));
    SPDR = SB_BlueCommand<<4 | SB_RedCommand>>6;
    SPDR = SB_RedCommand << 2 | SB_GreenCommand>>8;
    SPDR = SB_GreenCommand;
void WriteLEDArray() {
    SB_CommandMode = B00; // Write to PWM control registers
    for (int h = 0;h<NumLEDs;h++) {
  SB_RedCommand = LEDChannels[h][0];
  SB_GreenCommand = LEDChannels[h][1];
  SB_BlueCommand = LEDChannels[h][2];
  SB_SendPacket();
    delayMicroseconds(15);
    digitalWrite(latchpin,HIGH); // latch data into registers
    digitalWrite(latchpin,LOW);
    SB_CommandMode = B01; // Write to current control registers
    for (int z = 0; z < NumLEDs; z++) SB_SendPacket();
   LEDChannels[0][0] = 1023;
   LEDChannels[0][1] = 0;
   LEDChannels[0][2] = 0;
   LEDChannels[1][0] = 0;
   LEDChannels[1][1] = 0;
   LEDChannels[1][2] = 1023;
   WriteLEDArray();
   delay(200);
   LEDChannels[0][0] = 0;
   LEDChannels[0][2] = 1023;
   LEDChannels[1][0] = 1023;
   LEDChannels[1][2] = 0;
   WriteLEDArray();
   delay(200);
Logged
Offline Offline
Full Member
View Profile
My Bad,
After reading more about the sketch in the supplied Doc. All it is supposed to do is blink Red and Blue.
That being said, Now I really need help.
Thanks once more.
Logged
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
What idiot designed the header angles on that board?
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
Me. They're...fun!
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
Samplefinger
Offline Offline
God Member
View Profile
Me. They're...fun!
Then I take back the idiot part.  And they are fun and interesting.  But how doesn't that kill you for using it on a breadboard?  It has to make it harder to interface it even on a custom made PCB because it's harder to verify its right before sending it off to be manufactured too.  What is the point?
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
What is the point?
You can easily put six of them together in a circle to make a GigaBrite..?
Logged
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
I really like the hexagonal shape, it tessellates quite nicely, you can make a honeycomb pattern. There are some interesting 3D polygons that you could make with a hexagon. Pentagonal would be real nice for 3D geometric shapes also.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I don't think you'd want to put both sets of pins in a breadboard anyway. One set of pins is just for daisychaining.
Logged
Offline Offline
Full Member
View Profile
Me. They're...fun!
I have a Favor, because I am new to all this and I got a lot to learn. Any way you could post or PM me some more Example code. Or explain in a dumbed down version on the code that is in the Doc.
I got some of it figured out. I can make all three LED's blink on and off and dim. But thats all.
Thanks
« Last Edit: January 17, 2013, 01:02:27 pm by kculm » Logged
Samplefinger
Offline Offline
God Member
View Profile
What is the point?
Buying enough for a gigabrite would get pricy... smiley
Logged
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
It takes 10 kilobucks to make one gigabright.
edit:
Actually, i guess thats 9.95 Kbucks.
Doh, looks more like 7.96 Kbucks if you get 100 pricing...
4th edit:
2^10, seems appropriate...
« Last Edit: January 17, 2013, 01:28:11 pm by Hippynerd » Logged
Samplefinger
Offline Offline
God Member
View Profile
edit:
It sounds like you are using 10^3 as your definition of kilo.  It may be 2^10 in this case, but I am not sure.   smiley-twist
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I can imagine a big LED snowflake made with those. You couldn't do that with square ones. smiley
Logged
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
Snowflakes make matrices look like squares.
Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
The plan was to use them with cables and mount them on objects, rather than plug them into a breadboard or solder them into a PCB. Therefore the angled headers seemed less of a problem. We never did a redesign, but making the headers parallel was definitely on the to-do list.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
