Topic: GPS Example: Using Checksums, Altitude, HDOP (Read 3483 times) previous topic - next topic
Johnny D
We've been working with the Dexter Industries GPS Shield again and have some example code for how to use Checksums, Altitude, Satellites in use, and HDOP with a GPS sensor.
I think the most interesting part of this is the use of the checksum.  Because a GPS generally uses serial data, the data can be corrupted by interference or interruptions.  Using the checksum is a really good way to make sure you have all of the data and it hasn't been corrupted in transmission.  It can, however, slow the Arduino down.  We try to show how you can write a program here that allows a user to turn it on and off.
I've pasted the code below; you can also download it on the wiki here:  http://dexterindustries.com/manual/arduino-shields/gps-shield/
This program demonstrates the dGPS library from Dexter Industries for Arduino
For use with the Dexter Industries GPS Shield.  The dGPS can be found here:
   - http://dexterindustries.com/Arduino-GPS_Shield.html
This code was originally based on the work of others.  You can see the original work here:
   - SoftwareSerial Library:  http://www.arduino.cc/en/Reference/SoftwareSerial
   - GPS Tutorial:  http://www.arduino.cc/playground/Tutorials/GPS
See our Arduino GPS Converting Coordinates for information on converting coordinates
from GPS Style Coordinates (ddmm.ssss) to Decimal Style Coordinates (dd.mmssss).
How it works:
   - The dGPS requires the SoftwareSerial.h library.
   - The GPS is initialized in the setup function.
   - The GPS is updated: values for location, time, etc, are updated using the ".update" function.
   - The values are read using their respective calls.  These values stay the same until "update" is called again.
#include "string.h"
#include "ctype.h"
#include "SoftwareSerial.h"
#include "dGPS.h"
// Software serial TX & RX Pins for the GPS module
// Initiate the software serial connection
int ledPin = 13;                  // LED test pin
float desLat=0;                   //Destination Latitude filled by user in Serial Monitor Box
float desLon=0;                   //Destination Longitude filled by user in Serial Monitor Box
char fla[2];                      //flag (Y/N) whether to print checksum or not. Filled by user in Serial Monitor Box
char fla2[2];                     //flag (Y/N) whether to print Altitude, number of satellites used and HDOP. Filled by user in Serial Monitor Box
dGPS dgps = dGPS();               // Construct dGPS class
float getdestcoord()
  // function to get the coordinates of the destination from user
  { float result;
    while (Serial.available()==0)
    {;}// do nothing until something comes into the serial buffer
    if (Serial.available()>0)
     result=Serial.parseFloat(); //read a float value from serial monitor box, correct upto 2 decimal places
     delay(10); // the processor needs a moment to process
    return result;
void getflag(char *str)
   // function to read the flag character from the user
    int index=0;
    { if (index<2){
      str[index]=Serial.read();
      index++;
      else str[index]='\0';
      delay(10);
  pinMode(ledPin, OUTPUT);       // Initialize LED pin
  Serial.end();                  // Close any previously established connections
  Serial.begin(9600);            // Serial output back to computer.  On.
  dgps.init();                   // Run initialization routine for dGPS.
  Serial.print("Do you want to display checksum (Y/N): ");
  delay(3000);
  getflag(fla);
  Serial.println(*fla);
  *fla2=Serial.read();           // To clear rhe buffer before the actual flag value is read
  memset(fla2, 0, sizeof(fla2));
  Serial.print("Do you want to display Altitude, Satellites used and HDOP (Y/N): ");
  delay(3000);
  getflag(fla2);
  Serial.println(*fla2);
  Serial.print("Enter Destination Latitude (in degrees): ");
  delay(3000);
  desLat=getdestcoord();
  Serial.println(desLat);
  Serial.print("Enter Destination Longitude (in degrees): ");
  delay(3000);
  desLon=getdestcoord();
  Serial.println(desLon);
  dgps.update(desLat, desLon);    // Calling this updates the GPS data.  The data in dGPS variables stays the same unless
                                  // this function is called.  When this function is called, the data is updated.
  Serial.print("UTC Time: ");
  Serial.println(dgps.Time());    // .Time returns the UTC time (GMT) in HHMMSS, 24 huor format (H-Hour; M-Minute; S-Second)
  Serial.print("Status: ");
  Serial.println(dgps.Status());  // A - Satellites acquired and a valid signal.  V - No sats and not a valid signal.
  Serial.print("Latitude: ");
  Serial.print(dgps.Lat(), 6);    // Lattitude - in DD.MMSSSS format (decimal-degrees format)  (D-Degree; M-Minute; S-Second)
  Serial.println(" degrees");
  Serial.print("Longitude: ");
  Serial.print(dgps.Lon(), 6);    // Longitude - in DD.MMSSSS format (decimal-degrees format)  (D-Degree; M-Minute; S-Second)
  Serial.print("Velocity: ");
  Serial.print(dgps.Vel(), 6);    // Velocity, in knots.
  Serial.println(" knots");
  Serial.print("Heading: ");
  Serial.print(dgps.Head(), 6);   // Heading, in degrees
  Serial.print("UTC Date(DDMMYY): ");
  Serial.println(dgps.Date());    // UTC date.  Date is in format:  DDMMYY (D - Day; M - Month; Y-Year)
  Serial.print("Distance to destination: ");
  Serial.print(dgps.Dist());      // The distance to the destination in kilometers. Correct upto 2 decimal points. Radius of Earth taken as 6,378.1 kilometers
  Serial.println(" kilometers");
  Serial.print("Azimuth to destination: ");
  Serial.print(dgps.Azim());      //Azimuth of the destination coordinates from the current location in degrees. Correct upto 2 decimal points
  Serial.print("Mode Indicator: ");
  Serial.println(dgps.Mode());     //Mode Indicator (N-Data not valid,A-Autonomous mode,D-Differential mode,E-Estimated mode,M-Manual input mode,S-Simulator mode
    switch(*fla){                 //SWITCH CASE TO CHECK IF THE USER WANTS CHECKSUM OR NOT
     case 'Y':
     case 'y':
       Serial.print("Received CheckSum: ");
       Serial.println(dgps.Checks()); //Checksum received from packet
       Serial.print("Computed Checksum: ");
       Serial.println(dgps.Checked(),HEX); //Checksum computed
       break;
     case 'N':
     case 'n':
       Serial.print("");
       break;
     default: Serial.print(""); }
     switch(*fla2){               //SWITCH CASE TO CHECK IF THE USER WANTS Number Of Satellites, HDOP, and Altitude OR NOT
     case 'Y':
     case 'y':
       dgps.updategga();         //updates the values of Number of Satellites, HDOP and Altitude
       Serial.print("Number of Satellites in use: ");
       Serial.println(dgps.SatView()); // Number of Satellites in use
       Serial.print("HDOP: ");
       Serial.println(dgps.Hdop());    // HDOP
       Serial.print("Altitude: ");
       Serial.print(dgps.Alti());      // Altitude (in meters) above sea-level
       Serial.println(" meters above sea level");
       break;
     case 'N':
     case 'n':
       Serial.print("");
       break;
  Serial.println("");
michinyon
Johnny D
The battery allows for faster satellite acquisition.  The battery basically keeps the SRAM storage alive, which contains an almanac of satellite position information and data.  If you fire a GPS up for the first time, it will generally take longer while it downloads the almanac from the satellites.
The battery helps keep that Almanac in memory, thus making satellite acquisitions faster.
michinyon
I need one of those.  My GPS chip often takes 13 minutes to start up.
Johnny D
