Topic: Keypad Library... Returning a string after user pressed a certain character (Read 2210 times) previous topic - next topic
FallenEvangellic
Jan 17, 2013, 06:40 am Last Edit: Jan 17, 2013, 09:01 am by FallenEvangellic Reason: 1
Hi all,
I just started with the Keypad library and I think I got the basics. I was able to build my own keypad 3X2
using push button and assigning characters "A-F". What I'm trying to do now is store these characters from
getKey() in an array and return them as a string when user press "F". I have searched the forum for 2 days and haven't really find anything that will help.
Any help will be appreciated.
Thanks for your time.
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
const byte ROWS = 2; //four rows
const byte COLS = 3; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'A','B','C'},
  {'D','E','F'}
byte rowPins[ROWS] = {9,8 }; //connect to the row pinouts of the keypad
byte colPins[COLS] = {7, 6, 5}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
  char customKey = customKeypad.getKey();
  if (customKey){
    Serial.println(customKey);
That's what I have right now.
larryd
Do you understand this tutorial?
http://playground.arduino.cc//Main/KeypadTutorial
No technical PMs.
The last thing you did is where you should start looking.
CrossRoads
Pointing back to keypad tutorial doesn't help - there is nothing about putting data into arrays in there.
Arrch
You need a char array to store the characters, and an index variable to keep track of where in the array you are. Every time a key is pressed, you put it in the array, increment the index variable, and null terminate the array.
FallenEvangellic
#4
Jan 17, 2013, 08:40 am Last Edit: Jan 17, 2013, 08:43 am by FallenEvangellic Reason: 1
Hey guys,
and thank you Arrch
Well so far i took matter in my hands and started writing.
I was able to store characters in a buffer and have it return a string when the buffer is full and clearing the buffer. I will now just need to get the butter return when a certain key is pressed.
Suggestions are always welcome.
Thanks again
the code so far
|| @version 1.0
|| @description
#include <Keypad.h>
char buffer[6];
int i;
  {'A','B','C'},
  {'D','E','F'}
void setup(){
void loop(){
  while( i < sizeof(buffer))
  buffer[i] = customKeypad.getKey();
  if (buffer[i] == '\0')
    break;
    i++;
   if ( i == sizeof(buffer))
      Serial.println(buffer);
      buffer[i]=0;
      Serial.println("-------------");
      break;
Image of serial Monitor is attached.
PaulS
What did you store here if no key was pressed? Why do you want to store that?
This is a rather poor test. The getKey() function returns a #defined value, NO_KEY, when no key is pressed. Assuming that NO_KEY is equivalent to NULL is a poor assumption.
UKHeliBob
I understand that getKey() is non blocking.  What does it return if no key is pressed ?
PaulS
HazardsMind
Look at this post, http://arduino.cc/forum/index.php/topic,137352.30.html it does work and it compiles. Tweak it for your needs.
There are two codes, the one by dcr_inc will only display the numbers once " * " is pressed, and the one I corrected will display the numbers every time a button is pressed.
Keep in mind that they both use the LCD, so just fix it so that it goes to the serial monitor.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
UKHeliBob
This will read keys until either 6 have been entered each followed by Return, or you enter an F followed by Return
char buffer[7];
char newChar;
int i;
#define NO_KEY '!'
  i = 0;
  buffer[0] = '\0';  //terminator in first position just in case
  while (i < sizeof(buffer) - 1)  //leave space for terminator
    newChar = getChar();
    if (newChar == 'F')
      break;
    else if (newChar != NO_KEY)
      buffer[i] = newChar;
      i++;
      buffer[i] =  '\0'; //terminate string in case we finish next time
char getChar()
  if (Serial.available() == 0 )
    newChar = NO_KEY;
    newChar = Serial.read();
  return newChar;
I don't have a keypad so it reads input from the serial port.  Set the monitor to no termination if you try it.
NOTE - the routine as written is not bullet proof and is quite happy to accept F as the first character as well as a string longer than 6 characters from the serial input with no Return after each but it illustrates the concept of terminating input on receipt of a particular character.
FallenEvangellic
#10
Jan 17, 2013, 10:01 pm Last Edit: Jan 17, 2013, 10:03 pm by FallenEvangellic Reason: 1
Thanks for all the replies  :)
I have spend some time getting info from each one of the messages and have a working code that does what it is meant to do. I took into consideration NO_Key, which return nothing when the user press ' F ' with no inputs in the buffer.
Working code
|| @version 1.0
|| @description
#include <Keypad.h>
char key;
char buffer[7];
int i;
  {'A','B','C'},
  {'D','E','F'}
void setup(){
void loop(){
  i = 0;
  buffer[0] = '\0';
  while( i < sizeof(buffer) - 1)
  key = getChar();
  if (key == 'F')
    break;
   else if ( key != NO_KEY)
      buffer[i] = key;
      i++;
      buffer[i]= '\0';
   char getChar()
  char key = customKeypad.getKey();
  if (key != NO_KEY)
     return key;
  else {
  return NO_KEY;
Screenshot of Serial Monitor
Image of setup
Thanks again to all the replies.
UKHeliBob
You should be able to replace
  key = getChar();
with
I only used the getChar() function because I do not have a keypad and needed to use Serial.read()
FallenEvangellic
Agreed.
And I kept your function because it is a nicer way to have a separate function to get input and return values instead of having it in the main.
Thanks again for your help :)
