« on: January 17, 2013, 12:40:00 am » |
Hi all, I just started with the Keypad library and I think I got the basics. I was able to build my own keypad 3X2 using push button and assigning characters "A-F". What I'm trying to do now is store these characters from getKey() in an array and return them as a string when user press "F". I have searched the forum for 2 days and haven't really find anything that will help. Any help will be appreciated. Thanks for your time. /* @file CustomKeypad.pde || @version 1.0 || @author Alexander Brevig || @contact alexanderbrevig@gmail.com || || @description || | Demonstrates changing the keypad size and key values. || # */ #include <Keypad.h>
const byte ROWS = 2; //four rows const byte COLS = 3; //four columns //define the cymbols on the buttons of the keypads char hexaKeys[ROWS][COLS] = { {'A','B','C'}, {'D','E','F'} }; byte rowPins[ROWS] = {9,8 }; //connect to the row pinouts of the keypad byte colPins[COLS] = {7, 6, 5}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){ Serial.begin(9600); } void loop(){ char customKey = customKeypad.getKey(); if (customKey){ Serial.println(customKey); } }
That's what I have right now.
« Last Edit: January 17, 2013, 03:01:09 am by FallenEvangellic »
The last thing you did is where you should start looking.
« Reply #1 on: January 17, 2013, 01:11:12 am » |
Boston area, metrowest
« Reply #2 on: January 17, 2013, 01:13:57 am » |
Pointing back to keypad tutorial doesn't help - there is nothing about putting data into arrays in there.
California
« Reply #3 on: January 17, 2013, 01:44:45 am » |
You need a char array to store the characters, and an index variable to keep track of where in the array you are. Every time a key is pressed, you put it in the array, increment the index variable, and null terminate the array.
« Reply #4 on: January 17, 2013, 02:40:46 am » |
Hey guys, and thank you Arrch Well so far i took matter in my hands and started writing. I was able to store characters in a buffer and have it return a string when the buffer is full and clearing the buffer. I will now just need to get the butter return when a certain key is pressed. Suggestions are always welcome. Thanks again the code so far /* @file CustomKeypad.pde || @version 1.0 || @author Alexander Brevig || @contact alexanderbrevig@gmail.com || || @description || | Demonstrates changing the keypad size and key values. || # */ #include <Keypad.h> char buffer[6]; int i; const byte ROWS = 2; //four rows const byte COLS = 3; //four columns //define the cymbols on the buttons of the keypads char hexaKeys[ROWS][COLS] = { {'A','B','C'}, {'D','E','F'} }; byte rowPins[ROWS] = {9,8 }; //connect to the row pinouts of the keypad byte colPins[COLS] = {7, 6, 5}; //connect to the column pinouts of the keypad
void setup(){ Serial.begin(9600); } void loop(){ while( i < sizeof(buffer)) { buffer[i] = customKeypad.getKey(); if (buffer[i] == '\0') break; i++; if ( i == sizeof(buffer)) { Serial.println(buffer); buffer[i]=0; Serial.println("-------------"); break; } } } Image of serial Monitor is attached.
« Last Edit: January 17, 2013, 02:43:59 am by FallenEvangellic »
Seattle, WA USA
Online
Seattle, WA USA
« Reply #5 on: January 17, 2013, 06:16:11 am » |
buffer[i] = customKeypad.getKey(); What did you store here if no key was pressed? Why do you want to store that? if (buffer[i] == '\0') This is a rather poor test. The getKey() function returns a #defined value, NO_KEY, when no key is pressed. Assuming that NO_KEY is equivalent to NULL is a poor assumption.
East Anglia (UK)
Online
May all of your blinks be without delay
« Reply #6 on: January 17, 2013, 07:14:21 am » |
I understand that getKey() is non blocking. What does it return if no key is pressed ?
Seattle, WA USA
Online
Seattle, WA USA
« Reply #7 on: January 17, 2013, 07:35:20 am » |
What does it return if no key is pressed ? The getKey() function returns a #defined value, NO_KEY, when no key is pressed.
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #8 on: January 17, 2013, 08:11:53 am » |
Look at this post, http://arduino.cc/forum/index.php/topic,137352.30.html it does work and it compiles. Tweak it for your needs. There are two codes, the one by dcr_inc will only display the numbers once " * " is pressed, and the one I corrected will display the numbers every time a button is pressed. Keep in mind that they both use the LCD, so just fix it so that it goes to the serial monitor.
« Last Edit: January 17, 2013, 08:18:35 am by HazardsMind »
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
East Anglia (UK)
Online
« Reply #9 on: January 17, 2013, 09:03:19 am » |
This will read keys until either 6 have been entered each followed by Return, or you enter an F followed by Return char buffer[7]; char newChar; int i;
#define NO_KEY '!'
void setup() { Serial.begin(9600); }
void loop() { i = 0; buffer[0] = '\0'; //terminator in first position just in case while (i < sizeof(buffer) - 1) //leave space for terminator { newChar = getChar(); if (newChar == 'F') { break; } else if (newChar != NO_KEY) { buffer[i] = newChar; i++; buffer[i] = '\0'; //terminate string in case we finish next time } } Serial.println(buffer); }
char getChar() { if (Serial.available() == 0 ) { newChar = NO_KEY; } else { newChar = Serial.read(); } return newChar; }
I don't have a keypad so it reads input from the serial port. Set the monitor to no termination if you try it. NOTE - the routine as written is not bullet proof and is quite happy to accept F as the first character as well as a string longer than 6 characters from the serial input with no Return after each but it illustrates the concept of terminating input on receipt of a particular character.
« Reply #10 on: January 17, 2013, 04:01:08 pm » |
Thanks for all the replies  I have spend some time getting info from each one of the messages and have a working code that does what it is meant to do. I took into consideration NO_Key, which return nothing when the user press ' F ' with no inputs in the buffer. Working code /* @file CustomKeypad.pde || @version 1.0 || @author Alexander Brevig || @contact alexanderbrevig@gmail.com || || @description || | Demonstrates changing the keypad size and key values. || # */ #include <Keypad.h> char key; char buffer[7]; int i; const byte ROWS = 2; //four rows const byte COLS = 3; //four columns //define the cymbols on the buttons of the keypads char hexaKeys[ROWS][COLS] = { {'A','B','C'}, {'D','E','F'} }; byte rowPins[ROWS] = {9,8 }; //connect to the row pinouts of the keypad byte colPins[COLS] = {7, 6, 5}; //connect to the column pinouts of the keypad
void setup(){ Serial.begin(9600); } void loop(){ i = 0; buffer[0] = '\0'; while( i < sizeof(buffer) - 1) { key = getChar(); if (key == 'F') { break; } else if ( key != NO_KEY) { buffer[i] = key; i++; buffer[i]= '\0'; } } Serial.println(buffer); } char getChar() { char key = customKeypad.getKey(); if (key != NO_KEY) { return key; } else { return NO_KEY; } } Screenshot of Serial Monitor  Image of setup  Thanks again to all the replies.
« Last Edit: January 17, 2013, 04:03:40 pm by FallenEvangellic »
East Anglia (UK)
Online
« Reply #11 on: January 17, 2013, 05:18:09 pm » |
You should be able to replace key = getChar(); with key = customKeypad.getKey(); I only used the getChar() function because I do not have a keypad and needed to use Serial.read()
« Reply #12 on: January 17, 2013, 07:19:57 pm » |
Agreed. And I kept your function because it is a nicer way to have a separate function to get input and return values instead of having it in the main. Thanks again for your help
