Topic: Help regarding bluetooth (serial or usb) (Read 762 times) previous topic - next topic
badri89
Hi people,
          I am thinking of establishing communication between two bots using bluetooth. Ive seen to transfer data via bluetooth, bluetooth module should be present in both the robots. It seems bluetooth with usb is cheap than serial. So is it possible to send data using this usb based bluetooth. If so, how?
thanx in advance
jluciani
#1
Oct 03, 2009, 02:07 pm Last Edit: Oct 03, 2009, 03:48 pm by jluciani Reason: 1
I used the BlueGiga WT12A in a project. The WT12A is a BT radio with a serial
interface. It is around $25.
I think you may be better off with a different radio. Something like an XBee with
more range.
(* jcl *)
Icanfly
Also if you go with xbees make sure which series you choose. series 1 should be cheaper and easier but series 2.5 you might need to do some research on.
What  range do you need?
badri89
Range of about 10 m is suffice for me
Icanfly
a series 1 xbee could be a good bet and quiet cheap about £13 when I last looked.
Bluetooth seems more expensive.
Also Xbee is quiet a cool communication device and once youve got the hang of it properly use it for loads of other projects after.
Shouldnt be too hard to set up your network simple point to point.
