Johannesburg UTC+2
« on: January 17, 2013, 05:38:50 am » |
I understand what they do: gain the gain, so to speak. But presumably there are technical reasons that a transistor of "Darlingtonian gains" cannot be made made to provide that gain in one pass? If so I'd be interested to hear why that is so. Words of one syllable, please....
« Last Edit: January 17, 2013, 08:20:32 am by JimboZA »
IT Crowd: Roy... "Have you tried turning it off and on again?" Moss.. "Have you tried forcing an unexpected reboot?"
Valencia, Spain
« Reply #1 on: January 17, 2013, 05:59:26 am » |
Old transistors didn't have a very high beta so it was often necessary to get a high enough gain. With newer transistors you don't need them so much, although they're still used when you need a massive gain. http://en.wikipedia.org/wiki/Darlington_transistor
« Last Edit: January 17, 2013, 06:03:38 am by fungus »
Johannesburg UTC+2
« Reply #3 on: January 17, 2013, 08:21:29 am » |
Ah ok, so they're basically superseded.
Thanks.
Cumming, Ga
Ultimate DIY: Arduino
« Reply #4 on: January 17, 2013, 10:05:35 am » |
Historically, back in silicon dinosaur days, when the 2N3055 power transistor and the 2N2222A General purpose transistor were king... the power transistors seemed to be able to gain their current capacity at the expense of Hfe (gain). So, to create a high current solution, the darlington configuration was conceived, where a lower current/higher gain transistor would drive the base of a power transistor that had less gain... with the resulting configuration accomplishing the overall goal of hi-gain, high speed transitions, and high power.
The configuration was common enough that it eventually became a "device" you could buy, like the still popular TIP120. There is really no compelling reason "not" to use them where it makes sense to and that is why you can still purchase them. Using one "just because you have one" maybe not the best idea... but they have their uses... I use them to drive solenoids.
« Last Edit: January 17, 2013, 10:10:04 am by pwillard »
the land of sun+snow
« Reply #5 on: January 17, 2013, 12:47:01 pm » |
Some good info there. I've had many of the same experiences. On the site, you also mention "When might I use external pullup/pulldown resistors? Only when the internal 20k pullup resistor isn’t suitable, for example, if the switches are connected with long wires that pick up noise". You call this "Five things I **never** use in Arduino projects" [my emphasis], but I might add ... external pulldowns are useful for building voltage dividers to interface voltages outside the normal 0..Vcc range. This scheme is also especially useful on A/D converter input channels. the power transistors seemed to be able to gain their current capacity at the expense of Hfe (gain). This is also interesting. Older bipolar transistors might have high current gain, hFE, in the 100-200 range for low collector currents, eg a few ma, but hFE would drop to 10 or so at higher currents, eg > 100 mA. Anyone know how they fabricate newer bipolars to get around this problem?
United Kingdom
« Reply #6 on: January 17, 2013, 01:30:08 pm » |
What I actually said I don't use is "Pullups or pulldown resistors on digital input pins used for reading switches". I guess the unspecified assumption is that I have control over how I connect both ends of the switch.
Valencia, Spain
« Reply #7 on: January 17, 2013, 01:46:30 pm » |
Capacitors and debouncing on rotary encoders? I haven't seen that thread yet, but LOL anyway...
« Reply #8 on: January 17, 2013, 02:18:06 pm » |
What I actually said I don't use is "Pullups or pulldown resistors on digital input pins used for reading switches". I guess the unspecified assumption is that I have control over how I connect both ends of the switch. I realize that, but was thinking of expanding to more general cases.
Boston area, metrowest
Online
« Reply #9 on: January 17, 2013, 02:20:32 pm » |
Some Darlington arrays are pretty useful tho - ULN2803 can be quite a handy part when you need to pull lots of lines low. I use TPIC6B595 more often tho, like having a 74HC595 but with much improved current sinking ability. Can't drive high tho, need something else as the current source.
« Reply #10 on: January 17, 2013, 09:22:25 pm » |
Modern devices use ion-implantation to get far greater control on the base region dimensions and doping levels and gradients. Older technology was limited to thermal diffusion of dopant atoms. Precise base thickness and accurate doping profiles are essential to high beta and low emitter resistance I believe.
Montreal
Per aspera ad astra.
« Reply #11 on: January 17, 2013, 10:06:11 pm » |
Curiosity gets me to look at ZTX851: Collector-Emitter Saturation VCE(sat) 10 50 mV IC=0.1A, IB=5mA* Voltage 50 100 mV IC=1A, IB=50mA* 100 150 mV IC=2A, IB=50mA* 200 250 mV IC=5A, IB=200mA*
Well, quite impressive 250mV at 5A, only there is no way arduino could deliver 200 mA base current.You can't use such transistor even for 1A load, I don't know any micro with 50mA outputs driving capability. TIP120, for comparison, needs only 3 mA for 3A collector current. Other things, ztx851 according to "safe operating area" can supply 5A during 1 sec. TIP120 will run 5A forever. MOSFET's are nice alternative, same time even logic level transistor would require special high capacitance driver IC for most PWM application. It seems to me, that old TIP120 is ONLY the best friend for microprocessor application, with one nuisance - base resistor
Online
« Reply #12 on: January 17, 2013, 10:15:29 pm » |
These #s don't look good tho: Vce Saturation (Max) @ Ib, Ic: 4V @ 20mA, 5A
IC = 3A, IB = 12mA, Vcesat = 2V
P=IV = 6W, heatsink recommended I think!
Montreal
« Reply #13 on: January 17, 2013, 10:31:25 pm » |
P=IV = 6W, heatsink recommended I think! Yes, I agree with that. Same time it's applicable to any BJT, Darlingtons just have saturation little bit higher than others. So the trade is TIP120 + heatsink or MOSFET + TC426.
« Reply #14 on: January 17, 2013, 10:42:11 pm » |
So for say a TIP31 which can handle up to 2amps at the base..
Would you say to power ANY TIP31 transistor (until now i used a 200ohm base resistor) would you say it's ok to use a 2222a with a tip31 in a darlington array? (i only have 2 n mosfets)
