Topic: Digital potentiometer with op amp (Read 8151 times) previous topic - next topic
borillion
Hi I'm to take a 5V 500mA power supply and pass it  through a digital potentiometer AD5235 and then step it up through an op-amp with a gain 2 to get up to 10V output and put that into voltage based meanwell dimmer controller.
I'm a little confused on how to handle grounding with this. They are circled blue. Can I "ground" the -5V from the pot, and the -10V from the dimmer and the opamp together without damaging the pot by connecting them on the power supply -5V terminal of the wall wart l'll be using?
Also I have a couple questions about the pin meanings:
WP - Optional Write Protect. When active low, WP prevents any changes to the present contents
PR - Optional Hardware Override Preset. Refreshes the scratchpad register with current contents of the EEMEM register.  PR is activated at the logic high transition.
RDY - Ready. Active high open-drain output
what is active low vs just low, why the verb active?
what do Logic high transitions and active high open-drain output mean exactly?  :smiley-red:
Thanks you for your help!
dc42
#1
Jan 17, 2013, 01:43 pm Last Edit: Jan 17, 2013, 01:45 pm by dc42 Reason: 1
If you are driving that from an Arduino, then there is a much simpler solution. Take a PWM output pin, pass the output through an R-C filter, then use exactly the same op amp configuration to double the output from 0->5V to 0->10V.
To answer some of your questions: "active high" means the signal does what it is supposed to so when it is HIGH (i.e. voltage neat +5V or whatever Vcc is), and doesn't when it it LOW (near 0V). Active low is the reverse. So "RDY - Ready. Active high open-drain output" means that the output is HIGH when the device is ready.
"Open drain" means that the output pulls the output low, but not high. So you need a pullup resistor to Vcc to actually get a high on the pin.
"Refreshes the scratchpad register with current contents of the EEMEM register.  PR is activated at the logic high transition." means that when this input changes from LOW to HIGH, it refreshes the scratchpad register.
SirNickity
That is simply bad wording in my opinion.  As already stated, the phrase "active low" means that the pin does whatever (i.e., it's active) when the input is low.  So there's no state called "active low."  There are only high and low states, and the pin's function is either activated by being high or low.  To put it one more way:  It can't be active low, it can only be activated when low.
borillion
That's what I figured it activates a function being high or low but wasnt sure.
As for the rc filter would it look something like this? Course I would be replacing Vs here with the pwm signal source and connect the end grounds to the -5V line on the wall wart Ill be using for power? Can I leave out the resistor and cap I don't understand why would need a filter?
Sorry if I'm being stupid but this is the first time I've dealt with pwm and not put it directly to and led or servo.
majenko
Just a note on your terminology...
A 5V wall wart doesn't have a -5V line.
You have a +(whatever)V connection, and a GND connection.  The same goes for the Arduino, the op-amp power supply, etc.  You have + and GND, not + and -.
For a 5V supply you have +5V and GND.  For a 10V supply, it is +10V and GND.
If you had +5V and -5V, then the difference between them would be 10V!  (ouch).
Also, I assume you have a 10V power supply to run the op-amp from?  You do realise that you can't power the op-amp from 5V and expect a gain of 2 to give you 10V out of it...?
dc42
Yes, it would look like that. You need an op amp whose input common mode voltage goes down to ground, and whose output goes close enough to ground as well. Best is a rail-to-rail op amp, but 1/2 a LM358 or 1/4 a LM324 will do if you use a 12v supply. Making Ra and Rb quite low (say 1K each) will help ensure that the output goess close enough to zero.
The RC network is needed because the dimmer expects a voltage between 0V and 10V, not a 10V PWM digital signal. Values of e.g. 10K and 22uF should be OK using the Arduino default PWM frequency.
retrolefty
#6
Jan 18, 2013, 01:48 am Last Edit: Jan 18, 2013, 01:54 am by retrolefty Reason: 1
I don't know if there is any really accurate terminology one can use with DC wall warts that doesn't either make assumptions or needs context to be understood correctly.
 Certainly a 'wall wart' type DC voltage source has both a positive and negative terminal (just like a battery) usually terminated into a coaxial DC connector, but no standard as to if center pin is positive or outer shell is positive, they come in both flavours. And one is free to connect either the negative terminal to one's circuit common and that results is a positive 5vdc available to power the circuitry, but of course there is nothing wrong with connecting the positive terminal to one's circuit common when they do require a -5vdc voltage source as for perhaps a op-amp's negative rail. But it's certainly true that a 5 volt wall wart doesn't have both a +5vdc terminal and a -5vdc terminal, at least not at the same time.  ;)
And the term 'ground' is such an overloaded term that can have several meanings and is a major pain in the butt to determine what one really means without the specific context being explained. I prefer the term circuit common or just common, over the term ground. And calling it GND is no help as that is almost impossible to pronounce. But then again I'm a crusty old hardware type that has his idiosyncrasies.  ;)
Lefty
SirNickity
Sure a wall-wart can have both positive and negative pins!  XD  I have one originally terminated on mini-DIN with +12, -12, +5, and gro--- uh, common.  ;-)
Granted, that's not what one typically imagines when thinking "wall wart", although I think discarding preconceptions when dealing with 'warts is probably not a bad thing.  After all, is it center-positive?  Center-negative?  Regulated?  50% voltage rise under no load?  AC??
Plugging in some random black box and expecting 5.0vDC on the center pin of a barrel connector is a good way to produce magic smoke.
borillion
Thanks Guys, I got this down and understand it now!
Ill use the circuit here
retrolefty
Nice drawing. You missing a series resistor wired between the PWM input and the cap and + op-amp input to form a proper low pass filter. 10K ohms should work.
Lefty
Maciej
I'm using the below circuit to regulate a 220V dimmer (Eltaco SUD12). It's working fine. However, the output is not 0-10V but 0-9.4V.  Does anybody have an idea how to change the circuit to deliver exactly 10V as maximum output?
Grumpy_Mike
What is the op amp supply voltage?
You can increase this or get a better Op amp, one with rail to rail outputs.
polymorph
The LM324 output can go no higher than 1.5V below the supply voltage.
Also, your two 22k resistors may be outside their range in just the right direction to get you a gain of less than 2.
Another also, the 5V in your Arduino might be a little low.
Yet another also, the output of an Arduino may not go quite to 5V with any load on it.
Simplest way to fix it? Put a 1k trimmer potentiometer between the two 22k resistors, and connect the wiper arm to the inverting input of the Op Amp.
BTW, an LM324 has four sections. You -must- connect the unused sections or they may, can, and will cause problems. Best way to connect unused sections is to connect them as noninverting buffers, ie, inverting input connected to the output, then tie the noninverting inputs to ground through a 1k resistor.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - tinyurl.com/q7uqnvn
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
MarkT
In general if you are not using a digital pot to handle an analog signal originating off-board,
you don't need the digital pot, a DAC is the simplest approach.  DACs are much more
numerous and easy to source too.
ArtemKuskov
I know this topic was published a while ago, but I have a question. I am fairly new to digital electronics applications and I ran into some problems for power supplies in Op-Amps. For this very operational amplifier LM 324N I am supplying 15 Volts 300 mA to pins 4 and 11 respectively. when I do that the IC is getting heated up ALOT! I have tried to create a simple voltage divider to supply 12 volts or so, but in that case the IC is not even on. How can I overcome this issue? And also polymorph mentioned that all not connected pins have to be connected, I am curious why this is.
Thank you.
