Loading...
Pages: [1]   Go Down
Author Topic: XBee not sending right away  (Read 129 times)
Offline Offline
Newbie
View Profile
Hey guys. :-)
Recently I've been trying to create some kind of simple RC using XBee's.
But I've hit a brick wall.
The problem is, that my sender (controller) sends strings of data, simply using Serial.println("");, which is fine.
But it seems that the data is not send right away. E.x i send 10x "F1" (Forward, speed=1), it doesn't receive 10x "F1", it receives something like: "F\n 1\n F1\n F1\n F1..." and so on.
I could post some code, but it's really just reading from a joystick, and then sending the strings "F1", "B1" and so on.
Anyone got an idea of why this is happening?
Thanks in advance.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Which XBees? How are they configured? It likely isn't a code issue, but one never knows without seeing the code (on both ends).
Logged
Offline Offline
Newbie
View Profile
The XBee's are of the chip-kind, I really don't know what kind they are, besides that..
Although, I think the code is actually what's messing with me.
I changed a few things in the receiver code, and that seemed to have changed a few things.
Do you have an example of a really simple receiver code? My current one is:
Code:
String str = "";
  if(Serial.available() > 1)
    while(Serial.available())
      char c = Serial.read();
      str.concat(c);
  if(str != "" && str != "\n")
    Serial.print("New: ");
    Serial.println(str);
But that still seems to kind of buggy, my output right now from the console is:
Code:
New: F1
New:
But it gets even buggier if I send more data..
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You are printing a String on each pass through loop(), whether you have received data, or not.
You are sending that data through the XBee back to the sender. Why?
You'll need to know more about the XBees than that they have a chip antenna if you expect the configure them correctly.
How are the XBees connected to the Arduinos?
Logged
Offline Offline
Newbie
View Profile
I believe this is the one: http://www.let-elektronik.dk/xbee-1mw-chip-antenne.html
The Serial.println is just for debugging purposes. It sends data back, but the 'sender' doesn't read this, so it doesn't matter. It just for me to follow in the console, when testing. And the string isn't getting printed, unless it actually contains something.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Like a line feed?
The proper ratio of answers to questions is 1+ to 1. You are quite a bit under that ratio right now.
Logged
Pages: [1]   Go Up
Print
Jump to:
