Topic: Run an if-else once (Read 1 time) previous topic - next topic
guns4guitars
Hello people. I have a project involving an RC car and a "seat belt". Basically the car cannot move unless the seat belt is fastened. I am using an Arduino UNO to control whether the car moves. It checks for a logic 1 or 0 at pin 9, and controls a relay at pin 8. The program works and the car does move only when the seat belt is fastened, but when the seat belt is unfastened the car immediately slows to a halt. I needed to add a delay when the seat belt is unfastened. So I added the delay() function and tried uploading. Here's the problem. I added a delay of 60 seconds. When the seat belt is unfastened, the Arduino delays for 60 seconds before writing a LOW to the relay. This is perfect, but when I refasten the seat belt after 60 seconds, the Arduino waits another 60 seconds before re-activating the relay. So I need help. Is it possible to just run the if-else once? Like what ever is in the "else" just once?
*ignore LCD commands.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int relayOut = 8;
int receiverIn = 9;
int x = 60;
  pinMode(relayOut,OUTPUT);
  pinMode(receiverIn,INPUT);
  lcd.begin(16, 2);
  lcd.print("Welcome. Please fasten your seat belt.");
void delayCarStart()
  delay(3000);
  digitalWrite(relayOut, LOW);
  if (digitalRead(receiverIn) == HIGH)
     digitalWrite(relayOut, HIGH);
     lcd.print("You may proceed");
     lcd.print("Please fasten your seat belt!");
     delayCarStart();
holmes4
How are you de-bouncing the button. Look at the examples.
Mark
Quick5pnt0
#2
Jan 17, 2013, 01:27 pm Last Edit: Jan 17, 2013, 01:31 pm by Quick5pnt0 Reason: 1
Is this the code you tested because there is nothing there that delays for 60 seconds. I agree wih Mark, it does sound like a debounce problem. Your button is "bouncing" which cycles from high to low a few times before settling. During that time the code catches a low state and goes to the else portion of your code.
guns4guitars
#3
Jan 17, 2013, 01:36 pm Last Edit: Jan 17, 2013, 02:13 pm by AWOL Reason: 1
Oops, posted the wrong copy...
int relayOut = 8;
int receiverIn = 9;
int x = 60;
 lcd.begin(16, 2);
    delay(60000);
Moderator edit: CODE TAGS, CODE TAGS.
Quick5pnt0
Take a look at this:
http://arduino.cc/en/Tutorial/Debounce
guns4guitars
still cant get it to work ergh... need this to work by saturday!!!!
AWOL
Have a look at the blink without delay tutorial to allow you to not use "delay()", and make your code more responsive.
HazardsMind
#7
Jan 17, 2013, 04:17 pm Last Edit: Jan 17, 2013, 09:26 pm by HazardsMind Reason: 1
EDIT! Does not work properly
Try this
flagged = 0; //global variable at the top of code
       if(!flagged)
          flagged = 1;
          delayCarStart();
  else flagged = 0;
Not compiled or tested but, have use simular example in other working programs.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
Arrch
What you're looking for is called signal edge detection. You don't care that the input is LOW, you're just looking for when it goes from HIGH to LOW. To do that, you need to keep track of the last reading. If the current reading is HIGH and the last reading is LOW, you have what's called a falling edge.
Quick5pnt0
Post your new code so somebody can see what is wrong.
HazardsMind
Here this example works.
const int sensor = 2;
int flag=0;
int flag1=0;
int last = 0;
void setup(){
  Serial.println("Start");
void loop(){
  //Serial.println(digitalRead(sensor));
  if(digitalRead(sensor) == HIGH)
    if(!flag){
      Serial.println("X");
      flag = 1;
  else flag = 0;
  if(digitalRead(sensor) == LOW)
    if(!flag1){
      Serial.println("Y");
      flag1 = 1;
  else flag1 = 0;
  //delay(1000);
My GitHub:
packocrayons
Exactly as Arrch said, you need an edge trigger, google edge triggering arduino or edge triggering c++. It's a pretty easy thing to do.
